Originally Posted by Tom Servo
Brian if you scroll up you値l see a post by Andy that contains a couple articles from RV Lifestyle.
The articles speak directly to your post.
I壇 be interested in your opinion on the articles.
My goal is to have some idea of what I知 doing before I head out with an AS the first time.
Your input is appreciated.
I found nearly all of the finer points and technical details in both articles to be accurate and in keeping with my understanding. The 1/2 ton trucks generally ride nicer and have better road feel so when they have the physical capability as in your case, they will be more pleasant just as Andy assures. The advice about tires and suspension improvements are great. Unlike Andy, I see a larger roll for 3/4 ton trucks when the trailer is a bit too much for the 1/2. I take issue with the grand and bombastic pronouncements of both articles, but without a little controversy who would read them? The one technical point I do disagree is the idea you can disregard trailer size and weight. The trailer's inertia moment is a primary driver to loss of control of the vehicle in serious circumstances. Yes tires and and set up helps a lot but they can only do so much. The relative size and weight of the vehicle vs. the trailer ultimately creates the situation that drives towing instability.
Again in your case, the Tundra is a good choice unless you plan to bring a lot of extra gear. Pay attention to the details, Andy probably understands better than anyone the difference they can make.
