Old 05-16-2023, 03:31 PM   #1
2019 25' International
Denver , Colorado
Weighing in: F150 Hybrid & 25' Serenity
My wife and I are headed out tomorrow for a long weekend trip and I thought this would be a good time to weigh the rig since we will be all loaded.
I'll use a CAT scale in Commerce City Colorado, a tongue scale I just bought and I will also contact Colorado State Patrol to see if one of their commercial vehicle inspectors will review the inputs. This last piece is a bit overkill but there tends to be a lot of opinions on the forums so I figured I'd have a professional review it.
I'll only be weighing the tow vehicle today since it's ready to go. Once we get the food and everything packed in the morning, we'll hit the scales again.
Tow Vehicle
2022 Ford Hybrid XLT 7.2kw 3.5L Powerboost 4x4 SuperCrew 10-Speed
3.73 ELECTRONIC LOCK RR AXLE
7350# GVWR PACKAGE
TRAILER TOW PACKAGE
INTEGRATED TRAILER BRAKE CONT
FX4 OFF-ROAD PACKAGE
SKID PLATES
GVWR: 7350
Front GAWR: 3750
Rear GAWR: 4150
Payload 1,600
Trailer Weight (distributing): 11,600
Tongue Weight (distributing) 1,160
Add-ons: Retrax Bed Cover
Cargo:
Wife and I
Weber BBQ
Computer Bag
*Since I have the hybrid, I don't have to lug around generator nor gas. I sometimes have fly fishing equipment but won't for this trip.
Hitch: 1,000/10,000 Weight Distributing Equalizer Hitch
RESULTS (WITH EQUILIZER HITCH INSTALLED 109LBS):
STEER 3560
DRIVE 2860
GROSS 6420
Name:	Screenshot 2023-05-16 at 3.21.34 PM.jpg
ID:	431902   Click image for larger version
Name:	Screenshot 2023-05-16 at 3.18.55 PM.jpg
ID:	431904   Click image for larger version
2019 25' International Serenity
4 Lithium, 380 Solar, MPPT 150/35 and Smart Shunt
2022 Ford Hybrid 7.2kw Powerboost
1000/10,000 Equalizer Hitch
Denver, Colorado
Gundogs is offline   Reply With Quote
Old 05-16-2023, 05:04 PM   #2
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
If your GVRW is 7350 and your gross vehicle weight is 6420 wouldn't your payload be 930 lbs? What is your total passenger weight? Our 25 ft Flying cloud adds 800 lbs to the total axel weights when using our Reese weight distribution hitch.
Castaway is offline   Reply With Quote
Old 05-16-2023, 05:35 PM   #3
2021 22' Caravel
Houston , Texas
I would be interested in your scale results with trailer and both with and without WD.
FredWilma is offline   Reply With Quote
Old 05-16-2023, 06:06 PM   #4
"Cloudsplitter"
Tow Vehicle
7350# GVWR PACKAGE
TRAILER TOW PACKAGE
SKID PLATES
GVWR: 7350
Front GAWR: 3750
Rear GAWR: 4150
Payload 1,600
Cargo:
Wife and I
Weber BBQ
Computer Bag
STEER 3560
DRIVE 2860
GROSS 6420
You need, at minimum, two more CAT weights.
TV alone loaded for camping.
TV & AS on the scales without WD
TV & AS on the scales with WD set with the proper weight returned to the TV steering 'axle'.
It's best to use the lightest WD bars that will move the needed weight.
Our CAT numbers...
1200lb TW on a Sherline scale.
860lb receiver with WD set
560 to the FA
160 to the AS
720 moved with 1000lb WD Bars
POI I did a MAX WD here to see if my WD bars had lost any poop...they had not and were just as capable as when new 17yrs ago.
ID:	431913   Click image for larger version
ID:	431915   Click image for larger version
"You don't know where you've been until you leave, enjoy life" RLC
Old 05-16-2023, 06:11 PM   #5
Denver , Colorado
I was basing on what the tire sticker inside the door states. My wife and I total 310lbs.
Denver, Colorado
Old 05-16-2023, 06:18 PM   #6
Denver , Colorado
Our CAT numbers...
560 to the FA
160 to the AS
Thanks, Bob. The weight quoted in original post was TV fully loaded for camping with both my wife and in the cab.
Denver, Colorado
Old 05-16-2023, 08:54 PM   #7
2017 25' International
West Lake Hills , Texas
Stop re-inventing the wheel. Use this worksheet then plug the numbers into their web app. It's not perfect but close enough.
Fungus is offline   Reply With Quote
Old 05-16-2023, 09:13 PM   #8
Denver , Colorado
Thanks. There is a very similar spreadsheet I downloaded from another thread on this forum. I reattached it here.
Denver, Colorado
Old 05-17-2023, 08:27 AM   #9
Denver , Colorado
Beautiful day in Colorado!
I just went and topped off the propane and filled the fresh water.
My wife and I got the trailer all packed with a fridge full of food, clothes, starlink and made the bed.
As if on queue, my wife got called into a conference call so I decided to use the time to re-calibrate the Equalizer Hitch according to their instructions and use my new tongue scale to see where we are weight wise.
Re-calibration: Unhitched just under 37.25, hitched wo WD 37.75, hitched w WD just over 37.25. I'll take it.
Scale: New Simple Tongue scale gave me 3 slightly different weights on 3 different tries. 890, 870, 880. I'll settle on 880.
Hope to be on the road soon.
Denver, Colorado
Old 05-17-2023, 08:32 AM   #10
Denver , Colorado
I should note a couple things because someone will ask.
The batteries on located in the center of the bed closer to the bathroom rather than the front. We took up the small cabinet that flips open.
Under the bed we also located a couple plastic boxes with dutch oven and our outdoor supplies.
Nothing is in the battery box on the tongue.
Under the dining room table are camping chairs and starlink in a hard suitcase/backpack.
Everything else is where you would expect.
Denver, Colorado
Old 05-17-2023, 08:37 AM   #11
Denver , Colorado
Images
ID:	431940   Click image for larger version
ID:	431942   Click image for larger version
ID:	431944   Click image for larger version
Denver, Colorado
Old 05-17-2023, 11:19 AM   #12
Denver , Colorado
My numbers are a little screwed because my wife was too busy. She's 130lbs.
Name:	Screenshot 2023-05-17 at 11.18.28 AM.jpg
ID:	431952   Click image for larger version
Name:	Screenshot 2023-05-17 at 11.18.06 AM.jpg
Denver, Colorado
Old 05-17-2023, 11:22 AM   #13
Denver , Colorado
Where is what the spreadsheet says.
Name:	Screenshot 2023-05-17 at 11.21.27 AM.jpg
Denver, Colorado
Old 05-17-2023, 11:55 AM   #14
palm beach gardens , Florida
I find the easiest solution to the above is owning a 2500.
Starlight Mike is offline   Reply With Quote
Old 05-17-2023, 12:59 PM   #15
Denver , Colorado
Thats funny.
Denver, Colorado
Old 05-17-2023, 01:39 PM   #16
Denver , Colorado
Since my wife delayed us just long enough not to get on the road today, I unhitched and re-weighed the TV so all the weights are equal.
Name:	Screenshot 2023-05-17 at 1.39.33 PM.jpg
ID:	431957   Click image for larger version
Name:	Screenshot 2023-05-17 at 1.36.04 PM.jpg
Denver, Colorado
Old 05-21-2023, 03:43 PM   #17
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Not to be rude, but if you are having to worry about 50-60lbs then Don't do it!
Sometimes the risk is not worth the reward. It also has to do with stopping ability as well.
Here is my take, I had a 2017 F250 pulling my 25' international. I did not look at payload when I bought my 2023 f150 Powerboost Platnium 3 months ago. Big mistake, I am not going to worry about how much firewood I am able to load, or camping gear...bicycles etc. not worth the stress. My payload was 1355lbs. Heck my tounge weight for my Airstream is 833lbs. No way!
My result is my 2023 F250 will be here (on rail now) within two weeks. Again for me not worth my safety.
https://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 05-21-2023, 04:19 PM   #18
Denver , Colorado
I really appreciate the input. I think I'll stick with what I have. It's within the safety guidelines and works well for the way we camp.
Denver, Colorado
Old 05-21-2023, 05:11 PM   #19
Flagstaff , Arizona
An excellent discussion on a forum dedicated to the 14th Gen F-150 that the PowerBoost (particularly the PB with the HD towing option) may have most or all the structural components of the F-150 Heavy Duty Payload Package raising the F-150 GW up to 7,800lbs.
I don't have the knowledge to verify these claims but a good argument was made that the PowerBoost may be able to handle more than 7,350 GW. It certainly has the power and torque for bigger loads. There were some observations that shifting the drive train aft to allow for the integral electric motor/generator may have figured into Ford's decision to limit the PowerBoost to 7,350lbs GW. But there is no doubt the PowerBoost with the HD towing package has structural modifications over and above the other ICE F-150's.
2022 25' GlobeTrotter FB <->2021 Ford F-150 PowerBoost 7.2kW ProPower
Electric Globetrotter
goldenchase is offline   Reply With Quote
Old 05-21-2023, 07:26 PM   #20
2021 22' Caravel
Houston , Texas
Hi Goldenchase. Do you have links to the discussion ? I have a vested interest!
Many thanks!
2024 F150 only Electric or Hybrid Power kscherzi Tow Vehicles 40 08-18-2022 09:57 AM
SOLD: 2021 Ford F150 King Range Hybrid - Colorado bisrael Airstream Classifieds 0 12-31-2021 11:01 AM
Airstream Serenity and F150 PowerBoost Hybrid w/Generator - GFI Faults pnoshawn Tow Vehicles 10 05-26-2021 12:18 PM
New F150 hybrid looks pretty interesting gypsydad Airstream Trailer Forums 2 07-01-2020 05:37 PM
