Old 06-03-2019, 11:20 AM   #1
ASLover
2007 25' Safari FB SE
Louisville , Kentucky
TV tire psi recommendation
I have F150 with Michelin Defender LTX tires. Truck says to inflate to 36 psi. Max on sidewalk is 44 psi. Towing 2007 25’ FB Safari.
Is there any advantage going above 36 psi on the TV? If so what is best psi.
gregshade is offline   Reply With Quote
Old 06-03-2019, 11:30 AM   #2
2007 27' International CCD FB
San Diego , California
Hi Greg.
Easy answer is yes, there's definitely advantages to running higher pressure when under tow.
From a load perspective, the tires swill support things just fine even at the factory recommended 36psi.
However, higher pressures will lend more sidewall stability for better tracking and resistance to sway. Potentially at a cost of incrementally rougher ride. Feel free to try a few different pressures. I would recommend 40psi as a good starting point.
I have different tires than you with large sidewalls, and are LT type tires with expanded pressure and load capabilities. As an example, I run 36psi when not towing. But 44psi when towing (my tires are rated to 65 psi max).
For your p-metric tire, I think you'll find 40 to be a good sweet spot for added stability yet good comfort.
pteck is offline   Reply With Quote
Old 06-03-2019, 12:13 PM   #3
1981 31' Excella II
New Market , Alabama
Well you are towing and loaded, I would say keep them pretty close to max pressure. How close are you to the max load on each tire? Running empty 36psi is probably ok. Are you using load distribution?
Perry
Old 06-03-2019, 04:19 PM   #4
ASLover
Yes I am using a Blue Ox WD hitch.
Thanks for the advice folks!
Old 06-04-2019, 10:23 AM   #5
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
To add, make sure to measure and add when the tires are cold. Preferably in the morning.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 06-04-2019, 01:54 PM   #6
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I run Bridgestones, not Michelins on my TV but they also have a max cold inflation pressure of 44 psi.
I run the fronts at 40 and the rears at 44 psi (cold) when towing.
GammaDog is offline   Reply With Quote
Old 06-04-2019, 11:49 PM   #7
Life is a Highway's Avatar
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Pressure
I ran 45 PSI and the handling was much improved. With the trailer on the pressure was not a problem. I even tried 50 but increased pressure when running hot had me back it down.
Life is a Highway is offline   Reply With Quote
Old 06-05-2019, 09:10 AM   #8
2020 Classic 33
Box Elder , South Dakota
Greg download the Michelin tire inflation charts and see what they suggest for a given weight. Get your weights for each axle at a truck stop CAT scale and set accordingly.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 06-05-2019, 10:33 AM   #9
This is not driven by hitch equipment or inflations charts for load rating. If one respects the door placard inflation pressures as minimums, there should be sufficient load handling.
Adding additional pressure to the tire is tuning for better stability and feel. Yes, icky subjective stuff. Objectively however, it will be more stable. To a point of diminishing returns where it now diminishes ride quality.
One still needs to respect the max inflation pressure as stated on the sidewall.
Old 06-05-2019, 10:55 AM   #10
mandolindave's Avatar
Moderation
A guy I know ( a MECHANIC!!!!) tried inflating tires on his trailer for better gas mileage, had TWO blowouts within an hour.
mandolindave is offline   Reply With Quote
Old 06-05-2019, 12:41 PM   #11
1981 31' Excella II
You can actually cause the center of the tire to overheat if you overinflate because now all the friction is in a narrow strip in the center. This is in addition to pressures that add up fast. 14.7 psi is 2100 lb/sq ft. So imagine the loads on a tire when the pressure is up around 80psi or more. Two ways to measure proper pressure. One is to mark the tire across the face with chalk and drive a few feet on pavement. The lighter areas indicate pressure. You want it even. Edges too light too little pressure. Center too light too much pressure. Another way is to run the tire till it gets to operating temperature and measure the temperature in the center and each side of the tread. Too hot in center means too much pressure too hot on edges means too little pressure.
Perry
Old 06-15-2019, 09:26 PM   #12
ASLover
40 seems to be the magic number for my rig.
I took everyone’s advice and went from 36 to 40 for my trip to CO. It worked beautifully from a stability and ride perspective. Gas mileage of 11mpg hurt but I guess that is part of the deal. 2500 miles proved everything out.
PS. I ran AS tires at max pressure of 80. During trip I monitored them with TireMinder. Never got over 89psi or 95F. Seemed to work well.
Old 07-25-2019, 12:26 PM   #13
LakeState's Avatar
2006 25' Safari
Howell , Michigan
everything changes ...
once your road temp gets above 90 to 100 plus degrees. the tires will expand greatly along with an increase in psi. i run the tow at 42 front and 46 rear. AS at 75psi over 90 degrees.
LakeState is offline   Reply With Quote
Old 07-25-2019, 01:16 PM   #14
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
My understanding is that the recommended tire pressures on the manufacturer's door sticker are not only the nominal pressures designed to provide the best combination of tire wear, handling, and fuel economy but they are also the pressures that will support the max load carrying capacity of the truck.
For example, the tires on my F250 are rated (cold) for 60PSI front and 65PSI rear. While adding pressure will theoretically increase the load capacity of the tire, it won't increase the load capacity of the truck which is already at max at the stock pressures.
Increasing tire pressure may subjectively affect ride or stability but it becomes a trade off with other issues. I've experimented with different tire pressures and have found that with my setup things seem to work pretty well if I stick to the factory recommended pressure. YMMV.
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Maximum PSI and Tire size Jase Tires 27 05-01-2017 12:12 PM
Tire Psi Butch McNabb Tires 19 12-07-2016 10:04 AM
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 10:11 AM
Manual says ST225/75R15LRC 50 psi -- PO used ST225/75R15LRD at 65 psi Driver1 Tires 3 06-23-2008 08:26 PM
Tire PSI? ldetsf Tires 9 11-10-2006 08:18 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
