Could have not said it better. You most likely dodged a problem.
Watch KYD's latest Youtube where his friends cell phone dropped off the dash on a his new F-450, hit the 4WD electronic turn button and put it in gear, Destroyed the front axle was months waiting for parts.
I would definitely at your best connivence
get the transfer case and front diff gearlube changed, while your at it and the vehicle is on a lift the rear diff also.
Originally Posted by wulfraat
It works fine until your transfer case gears or chain implode. [emoji4]
Front axle rotation rate is different than the rear axle rotation rate when you are not driving in an exact straight line. 4wd transfer case locks the ratio forcing both axles to turn at the same rate.
On wide turns on wet pavement or snow the tires will be forced to loose grip and will slip to accommodate the transfer case forcing the front/rear axles to turn at the same speed.
Under load with tighter turns on dry pavement tires have more friction and it’s your transfer case gears that will pay the price - something needs to give, mechanically - tires will loose grip, you will break a drive shaft or the transfer case gears will fail. The energy needs to go somewhere.
Transfer case gears are about the size of your fist. That’s not much surface area to deal will the tremendous resistance of different axle speeds with high friction coefficient of dry tires on dry pavement.
https://m.youtube.com/watch?time_con...ature=emb_logo
