Originally Posted by Vic Coco
Hi all
We now pull our 16foot Bambi Sport with a Honda Pilot equipped to tow 5000 pounds, but this will occasionally overheat even with an after market larger transmission coolant. They say the 16 foot Airstream weighs only 3500 pounds. We think we need to upgrade out tow vehicle.
We are not wanting a truck or a large truck frame SUV, if possible.
Several midsize SUVs say they can work - Nissan Pathfinder [6000lbs], Grand Cherokee [6200 with V6, 7200 with V8] and Audi Q7 55 [7200]. I just don't like the Dodge Durango.
I don't want to get another wrong vehicle. Advice please. Who has had success with any of these vehicles or can suggest options. Thanks.
Vic -
If you didn't order your Pilot with the factory tow option, which includes larger radiator, trans cooler & other heavy duty upgrades - then you have a basic Pilot only rated to tow something like 3500 lbs, even if you've added aftermarket AT cooler, hitch, etc.
Second, your Bambi Sport doesn't weigh in at 3500 lbs, but I think that they're rated to tow total GTW of something like 4500 lbs. So best to load your Bambi up with everything you take to camp, fill the water, LP, grey & black tanks plus your food, dishes, pots & pans, clothes, bikes, games, whatever else, etc. - then go to a CAT or other truck scale to get it weighed with the Pilot, & do several to weigh your rig at all 3 axles/wheels (1 Bambi, F & R Pilot), & Tongue or Hitch weight.
With that info, make sure your trailer isn't overloaded, then whether you'll need a WD hitch to not overload the Pilot rear wheels, & verify that you actually have the 5000 lb towing rating.
If it is rated for 5,000, & your Bambi fully loaded is within that, then it should be able to tow it with the Pilot, although it will be slow on the hills/grades.
Then check with your manual on towing & other Pilot/Ridgeline owners as to what gear they tow in (like the "...not in overdrive" comment in another post above) - & make sure that you're in tow mode for the Pilot.
Also, take it easy, since here in CA we're mostly limited to 55 mph anyway, unless the Pilot qualifies as a truck - & then only on the roads posted as "Automobiles when towing" (vs. "All vehicles when towing" showing up more & more).
We have vintage trailer buddies who used to tow their 4,500 lb vintage Safari trailer with their mid-2010s Ridgeline (older body style era), but it was slow going up some 2 lane mountain country roads. They later changed to a RAM
1500 3.0 TDI & like that. It was about 4500 lbs fully loaded (vintage canned ham).
You don't say what year Pilot & whether it has the
factory tow option - theirs did have the factory option.
Many Vans, SUVs/CUVs & pick-ups actually have limited tow ratings unless you get one of their optional extra money tow options - even the Ford F150 1/2 ton pick-up, which is only rated for 5,000 lbs without an option upgrade.
Most Asian brands including Honda seem to be around 3500 unless you get the upgrade for their vans, CUVs & some SUVs.
Back in 2012-13 we used to tow our 4500 lb fully loaded & as options/restored vintage kin
1960 Avion T20 Tourist with the older 2012 Nissan Pathfinder 4.0L V6 AT (the older body on frame version), which was okay, but was also a bit slow on hills/grades & searched for gears at freeway speeds (i.e.: 65+).
So your Pilot should be workable - if not fast - if it has the factory tow option, & so long as your trailer is within that limit.
You should also try contacting Andy T from CanAm RV at the Cayenne/Touareg/Audi Q7 Topic linked in another post above, since he's set up a few Pilots & Ridgelines to tow, he knows & sells Airstreams, & can advise you on what to do with yours, what WD/AS hitch to use (or about what you have), etc.
Also ask him about hitch reinforcement, as he can probably have him send you photos for the reinforcement to have done locally, since he's done that for other AirForums members here in CA & other places far from his shop in Ontario Canada. But you can also swing by them if you're ever in that area to have them do any set-up adjustments, etc.
Here's that link again, & he's posted a couple of times on this pg 84. You can also look through its now 85 pages for other Pilot & Ridgeline owners to contact for advice, since that is where a lot of non-pick-up TV types tend to post.
https://www.airforums.com/forums/f46...134917-84.html
Good Luck!
Tom
