Old 06-07-2023, 10:10 PM   #21
2019 22' Sport
Indianola , Iowa
We also have a 2019 pilot and a 22 foot sport. Most of our trips have been less than 400 miles/day. I have not seen an issue with transmission overheating. I have installed a VCM disabler this prevents most TC issues and keeps all six cylinders running. I also use an OBD trans. temperature gauge. Some things to check is if the trans. cooler was installed correctly, it is very easy to use an incorrect hose location. I also change the ATF every year. Secondly check to see the radiator fans are operating properly
Zoom23 is offline   Reply With Quote
Old 06-07-2023, 10:42 PM   #22
2021 23' Globetrotter
VICTORIA , British Columbia
Our Porsche Cayenne is an outstanding TV up to 23 ft.
I pull our GT 23 with ease. I previously pulled our 16 ft Caravelle and hardly new it was there. The Base Cayenne apparently is the best for towing.
Lockie is offline   Reply With Quote
Old 06-08-2023, 08:38 AM   #23
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
Hi Vic
We have hundreds of customers who have towed for years with Pilots and the other Honda's with the same 3.5 drivetrain. Almost all are towing much more than a 16'. Overheating has not been an issue with them.
I would say you have a partially plugged radiator or a cooling fan is not working properly. If you change the radiator there is a slightly larger one from the Ridgeline that should drop into the same location but confirm that with a radiator shop. Finding a good mechanic to diagnose this is not always easy but they are out there.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Tow vehicle choice - F150? PNH57 Tow Vehicles 36 07-27-2017 11:18 PM
Best Tow Vehicle choice UNDER $20,000 ALANSD Towing, Tow Vehicles & Hitches 36 06-08-2017 03:37 AM
My next tow vehicle choice? WonkoTSane Tow Vehicles 1 05-31-2010 02:32 PM
Tow Capacity & Trailer Choice IronGiant Tow Vehicles 7 05-10-2009 06:36 PM
Tow Capacity & Trailer Choice IronGiant Tow Vehicles 25 05-07-2009 04:40 PM
