Old 04-16-2018, 10:15 AM   #1
2019 27' Globetrotter
Pittsburgh , Pennsylvania
Tow vehicle
Considering either a cayenne or Nissan Armada for TV. Any thoughts from anyone which way I should go. Thanks. Open to suggestions
jdink is offline   Reply With Quote
Old 04-16-2018, 10:30 AM   #2
aftermath's Avatar
Spokane , Washington
First you need to tell us what you are planning on towing.
aftermath is offline   Reply With Quote
Old 04-16-2018, 10:36 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
And how much “stuff” you want to carry for a trip.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-16-2018, 11:10 AM   #4
2012 19' International
Southeastern MI , Michigan
And where you are planning to drive.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 04-16-2018, 01:41 PM   #5
Tow vehicle
Planning on traveling all over the country. Just 2 of us and we are considering purchasing a Globetrotter.We would like to stick with an SUV. We dont want a large truck. Thanks for your help
Old 04-16-2018, 01:55 PM   #6
aftermath's Avatar
We are making progress here JD. Now let us know what kind of Globetrotter. Will it be a new one or an older unit? How long will it be?
I hope you are getting the idea. It is almost impossible to suggest a TV not knowing how long and how heavy your trailer is going to be. You certainly can tow some Airstreams with an SUV.
Old 04-16-2018, 03:01 PM   #7
2017 28' International
Baileys Harbor , Wisconsin
What is the towing capacity of those vehicles? If the max is 7,000lbs, you do not want to be running at the max all the time. You want to some leeway. Also look at the payload. Doesn't take much to get to the payload limits of some vehicles.
The new globetrotter on the web page states it's got a hitch weight of 820lbs and dry weight of 6200lbs. Max full weight of about 7600lbs. You can pull that with an SUV, but you will want something that can probably max out at 9,000lbs of pulling capacity and has a payload of around 1500 to 2000lbs. The Armada has a pulling capacity of 8500lbs and payload of about 1700lbs. I would ask what the hitch weight max is. It might need some beefing up, which can be done. Does it have a max tow haul package? You definitely want that. Also what kind of mileage will you get pulling and what's the size of the gas tank? But based upon those stats it looks doable. You won't be tearing up the mountains though in it. A friend of mine who is driving through the mountains with his camper says most of what he sees are diesels. But he's pulling his with a 1/2 ton and is doing fine. But I believe his is rated at over 10,000lbs.
If I were to get an SUV I would consider the Ford Expedition with the 3.5 Ecoboost. It pulls 9300lbs and has 480lbs of torque at 2500rpms. That Ecoboost really pulls well. I have it in my F150 with a 10 speed transmission, and you will find that it's a good tradeoff say from a 3/4 ton gas or diesel. I have a 28' AS that has a hitch weight of 950lbs, about 7800lbs capacity on the trailer. I have no problem keeping up with traffic on the freeway or in going up hills.
Also if it were me I would consider getting a Hensely or Propride hitch to add to the towing stability. That's what I put on my F150 and it made the towing experience far more stable. Stability is the one thing that this type of vehicle will be lacking verses a heavier towing vehicle like a 3/4 ton.
Having said that if I were towing in the mountains a lot I would probably go with a 3/4 ton diesel.
But you are about to get all kinds of opinions. And I just gave you mine. Big decision. Blessings and whatever you do think safety.
Daquenzer is offline   Reply With Quote
Old 04-16-2018, 04:15 PM   #8
The 27’ is too big to pull with a mid size vehicle. Get something bigger, with a V8 gas or diesel. 3/4 ton minimum especially if you plan to drive in the mountains.
Michelin 16” tires
Hensley Arrow hitch
Old 04-16-2018, 07:13 PM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Tow vehicle
I have about 25k miles towing experience with the QX / armada platform. It did a very fine job for our 25’ which was 7,600 gvwr and 760lbs on the hitch (measured on cat scales)
When we moved to a 30’ I towed with the QX for another 3k miles. The 30’ is more akin to the globetrotter at 8,800lbs gvwr with 990 at the hitch. Globetrotter May even be heavier load on the hitch when loaded for camping - airstream specs are notoriously out of wack. Always plan for gvwr for the trailer and 1,000 lbs+ at the hitch for a 27’+ loaded and ready for camping.
Towing the heavier and longer 30’ took a lot more concentration on the highway and on windy mountain roads. The rig was more “lively” with cross winds, etc. The braking system worked noticeably harder in the mountains and so did the engine (we live at the foot of the Rockies). I’ve got some miles under my belt but even so I over heated the QX brakes on one occasion coming down from Rocky Mountain National Park.
In the end I moved up to a 3/4 ton diesel and have not looked back. Far more peaceful towing experience. Effortless. It’s a dedicated tow vehicle for the airstream and my wife shares driving duties.
You can get away with the QX / current generation armada with 850lb hitch rating and 1,450lb payload rating (assuming you don’t exceed that too much with the globetrotter tongue weight) but you will find yourself at the limit, which will definitely rattle your nerves if you are new to towing.
PS - I agree with the poster above - if you End up with an SUV invest in a propride hitch. Just remember though, it will eat up an additional 200lbs of payload capacity. 1,450 payload for the QX - 1,000lb tongue weight -200lb hitch weight leaves just 250 lbs for things like the driver and a medium sized dog and nothing else.
ID:	308861   Click image for larger version
wulfraat is offline   Reply With Quote
Tow vehicle weight to tow 19' Airstream pennylynne 2005 and newer - Bambi all models 18 02-20-2017 11:18 PM
Tow Vehicle - Jeep Wrangler to tow sport 16 iamcrazy Tow Vehicles 22 04-10-2016 07:37 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
