Old 02-23-2021, 02:08 PM   #1
2009 23' FB Flying Cloud
2004 33' Land Yacht Gas 33
Walkerton , Virginia
Torklift rear receiver hitch
Has anyone installed this hitch? I was wondering how easy it was to install and how it was holding up. I know most people do not recommend putting on this type of hitch on a airstream trailer.
https://torkliftcentral.com/airstrea...ry-hitch-x8000
bgwath is offline   Reply With Quote
Old 04-23-2021, 05:42 PM   #2
Just installed this rear hitch. It was easy to install, the hardest part is drilling the 4 9/16” holes. The directions are very detailed and the hardware is heavy duty. It is rock solid and just what I wanted for my hitch type bike rack.[ATTACH]393952Click image for larger version
ID:	393953Click image for larger version
ID:	393952   Click image for larger version
Old 04-23-2021, 06:38 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Neat.
Watch out dragging the rear end. Those new tabs for that received cross member look to be heavy duty and reinforced. IE you could bend / crack / damage the frame on a rear end impact.
Might consider 3” dexter lift if you don’t already have one.
wulfraat is offline   Reply With Quote
Old 04-23-2021, 06:55 PM   #4
Originally Posted by wulfraat View Post
Neat.
Will keep that in mind. Thanks.
Old 04-23-2021, 09:42 PM   #5
2001 19' Bambi
kent , Washington
I have it and had it installed by Torklift 4 years ago. Works great, no problems and with bikes mounted I still have access to my bumper and rear storage compartments. Just got the 3" lift this year. I recommend both the hitch and getting the lift.
stunami is offline   Reply With Quote
Old 09-13-2021, 10:53 AM   #6
2020 20' Caravel
Minneapolis , MN
Weight limit?
I installed the Torklift rear receiver hitch without any issues. It fits nicely on the bumper.
I have a few intended uses for it; one is to use for a carrier for a small motorcycle. The bike is 350 lbs (which is below the weight limit of the hitch assembly), but I'm worried about the frame and the tongue weight loading. Has anyone carried a motorcycle or near the weight limit on their airstream? I think I might be able to front load things stored in the trailer to help offset the additional rear weight, but I definitely don't want to bend the frame.
This is on a 2020 Caravel 19CB.
Thanks!
jeezeeble is offline   Reply With Quote
Old 09-13-2021, 11:48 AM   #7
2016 16' Sport
Miami , Florida
Oh boy
Shiny16 is offline   Reply With Quote
Old 09-29-2021, 06:36 AM   #8
Any updates? Did the trailer preform any different? More sway? What bike? Any pictures with loaded bike? Travel Safe
AS30FC11 is offline   Reply With Quote
Old 09-29-2021, 07:08 PM   #9
2022 30' Flying Cloud
Apex , North Carolina
interested as well.
Ericncsu1204 is offline   Reply With Quote
Old 11-06-2021, 09:21 AM   #10
11/05/21. Currently working to install the Torklift 8001 receiver myself. Removed four self tapping metal screws for the bumper and drilled out 10-12 pop rivets for the wet-storage shelf. cutting wheel and grinding the welds for removal of the factory skids plates.
Old 11-07-2021, 07:45 AM   #11
I did not remove the factory skid plates or the bumper/storage compartment. Probably looks more tidy without the skid plates.
Old 11-07-2021, 08:58 AM   #12
2020 20' Caravel
Minneapolis , MN
Unfortunately, nothing to report. I still haven’t hauled anything on the Torklift receiver yet. I was hoping to get a confirmation of success or failure from another owner before trying it with load.
Old 11-07-2021, 08:59 AM   #13
2020 20' Caravel
Minneapolis , MN
I also did not have to grind, cut, or remove anything to install. The fit was perfect.
Old 11-07-2021, 09:48 AM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Not me….
Old 11-08-2021, 05:37 AM   #15
The 30fc has the 2x5 tube frame and the factory skids were welded rite in the middle. Could not get a good flat space to attach the new bolt on ends Taking the bumper and the pan just gave me more room to work and see what I was doing.
Old 11-08-2021, 06:07 AM   #16
ID:	407728Click image for larger version
ID:	407729Click image for larger version
Old 11-08-2021, 06:25 AM   #17
No thanks... I want nothing adding weight to the back end.
I don't believe it's a good idea for the semi-monocoque frame design.
Another TETO decision.
Old 11-08-2021, 06:38 AM   #18
2016 16' Sport
Miami , Florida
Is that the travel trailer model of the Hollywood platform rack or the one E trailer specially says is for use on anything but a travel trailer.
Old 11-08-2021, 06:41 AM   #19
2016 16' Sport
Miami , Florida
Thanks!
I’m fairly confident that it won’t be the Torklift receiver that gets damaged from this application.
Old 11-08-2021, 10:35 AM   #20
Two bicycle rack, No E bike here
torklift battery box 77domer 2016 - Current Classic (all lengths) 3 05-30-2022 06:01 PM
Installing a torklift box on my 77 Soverign Razinni Exterior Storage Compartments & Access Doors 0 09-10-2016 06:40 PM
External Battery box by Torklift Rofkrynn Batteries, Univolts, Converters & Inverters 4 08-01-2014 10:12 AM
Rear Bumper Hitch Receiver for Bike Rack Seaheart Towing, Tow Vehicles & Hitches 3 07-25-2012 12:19 PM
Rear Hitch receiver, use or remove. Wingeezer Hitches, Couplers & Balls 26 11-24-2008 06:16 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
