Old 07-08-2021, 08:52 PM   #1
2020 23' Globetrotter
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
Tongue weight of GT27 2021
The dealer measured it and gave me the result on the pic below. This is almost 50% above what the specs for this trailer are. If you took the weight of yours, did you have a similar number?
GT 27 2021, F150 Platinum 2020 (F250 2021 on order)- 2017 Audi A7S - 2020 LR Defender 110 HSE
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
“Give up adventure for safety and end up with none” (shameless plagiarism with a twist)
Vitaver is offline   Reply With Quote
Old 07-08-2021, 09:37 PM   #2
Martee's Avatar
2017 25' Flying Cloud
Waco , Texas
There are a few models in the Airstream lineup that greatly exceed specifications for tongue weight. In most cases, it's the 25FB to 30FB models that exceed hitch weights by quite a lot. Both my Sherline and the CAT scale confirmed my hitch weight was 49% greater than specs. I think some AS dealers are aware, and some I know are clueless. I am not sure about the 23FB models showing increased hitch weights.
For my 2018 FC25FBT, the listed hitch weight is 837lbs with full propane, and my actual was 1251lbs with full propane, awnings, solar panels and cargo. As a result, my Airstream tracks exceptionally well on the road, without any sway in even high cross winds. Its an extremely stable trailer. It also means I must carefully watch my payload on my tow vehicle, far more than I ever anticipated. Interestingly, I noticed my hitch weight decreased 62 lbs when I carried full tank of 39 gals fresh water.
In your specifc case, you are reading an incredible 1400lbs hitch weight, and though it's certainly possible, It may also be an inaccurate reading by a faulty Sherline scale. I weighed mine 3 times, letting it go back to zero each time, and took the average. All readings were within 25lbs of the average.
Martee is offline   Reply With Quote
Old 07-08-2021, 10:23 PM   #3
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
The 23FB also weighs more than advertised at the hitch. Airstream says it’s 439 lbs. In reality, it’s closer to 620 lbs. It is still quite lightweight, but roughly 41% more than advertised.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 07-09-2021, 08:45 PM   #4
2017 25' International
West Lake Hills , Texas
Yep. 40% to 50% higher tongue weight than specs. Basically, the axles are a few inches too far aft.
Fungus is offline   Reply With Quote
Old 07-09-2021, 09:19 PM   #5
Thanks all, that has implications on the TV, what model to get. I have a 2021 F150 hybrid ready to pick up, but I think I will have to go 250 or 350. I carry a bed slide, a topper and a honda 7000is generator, no way I can put all that on the available payload of that 150, unfortunately. Any way around it?
Old 07-09-2021, 09:21 PM   #6
Originally Posted by Vitaver View Post
Any way around it?
Nope.
Old 07-09-2021, 09:32 PM   #7
nryn's Avatar
2019 27' Globetrotter
Driftless Area , Wisconsin
FWIW, fully loaded my 2019 Globetrotter 27FBT: 1124 lbs tongue weight. The published numbers mean nothing.
Airstream adventures and enhancements thread: Traveling with Tatay
Personal blog (photography, travel, woodworking, flyfishing, food): nryn.com
nryn is offline   Reply With Quote
Old 07-10-2021, 05:55 AM   #8
Airstream - Other
Bethlehem , Pennsylvania
The tongue weight is much lower if you are using a weight distributing hitch. My Yukon Denali (1500) requires a WD hitch for trailers above 5000 pounds. My pro pride hitch effectively lowers tongue weight so I’m not too worried about the higher tongue weight measured while unhitched.
Merlintiaga is offline   Reply With Quote
Old 07-10-2021, 07:47 AM   #9
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
The WD hitch distributes some of the weight off of the the hitch and re-distributes it to the front wheels. A big concern with the weight of the AS’s tongue is payload. Whatever the number is, it adds to payload. With a 1,400lb tongue, you don’t have a lot of payload left.
- Stewart
s1000pre is offline   Reply With Quote
Old 07-10-2021, 07:53 AM   #10
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Any way around it?
There really is no way around it. You are within your TV specs or you are not. You would have to shed 100s of pounds of tongue weight, something you are likely not going to be able to do.
thewarden is offline   Reply With Quote
Old 07-10-2021, 07:54 AM   #11
thewarden's Avatar
Originally Posted by s1000pre View Post
Actually, hitch weight never changes with a weight distribution hitch. The WD hitch distributes some of the weight to the front wheels. The concern is payload and overloading your truck. Hitch weight contributes to payload.
Exactly correct. While I am a huge fan of the Propride hitch, it is the heaviest out there, which just adds to the problem if you are already over your TV cargo capacity.
Old 07-10-2021, 08:19 AM   #12
Half a Rivet Short
Carlisle , Pennsylvania
Hi
+1
WD does not fix a payload problem.
It *does* help get weight from the rear axle to the front axle. That way you actually *get* the full payload number. Without it, you probably don't get to the door sticker number without the rear axle being over.
Old 07-11-2021, 12:31 PM   #13
Martee's Avatar
Waco , Texas
No way around it. Now is the time to get the proper TV, as you did a good job evaluating actual hitch weight of your Airstream. Hopefully your dealer can just clear your paperwork from the F150 and move it to an F350. Check door sticker to confirm payload.
Old 07-11-2021, 03:04 PM   #14
2019 25' Flying Cloud
Houston , Texas
I'd ask the dealer whether they had the trailer level when they did that measurement.
DCPAS is offline   Reply With Quote
Old 07-12-2021, 06:34 AM   #15
Half a Rivet Short
Hi
I'd also ask how the trailer was loaded. The factory spec is on an empty trailer.
Old 07-12-2021, 08:04 AM   #16
Hi
Propane alone is ~60 lbs of tongue weight.
Old 07-12-2021, 08:06 AM   #17
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
You can reduce tongue weight and shift some of the load from the pick up to the trailer. Here are a few things you can do; move the spare tire from the front and put it under the belly pan behind the rear axles, relocate the trailer batteries to the inside of the trailer towards the rear or over the axles i.e. under the fridge, reduce the propane tank size from 30 to 20lb. Also relocate heavier items inside the trailer to the rear. This may not be enough to solve your issue. The topper, bed slide and generator are heavy items. Alternatively a lightweight folding bed cover without a bed slide and a smaller generator would really go a long way to making this work for you. If you really need these heavier accessories then a truck with a much bigger payload is inevitable.
TRIPPPIN is offline   Reply With Quote
Old 07-12-2021, 09:08 AM   #18
3rd RV, First Airstream
ETroup's Avatar
2021 27' International
Orlando , Florida
Send a message via Skype™ to ETroup
On our 2021 International 27FB the higher than spec hitch weight means that more cargo can be / should be loaded aft of the axles.
Many people talk about the dangers of loading things on the bumper for fear of creating an unstable trailer. However, if the hitch is in fact too heavy, bike carriers or even rear bumper platform to mount a generator could help reduce hitch weight back to specification.
We load lighter weight items up front and make a conscious effort to load heavy items aft of the axles. The fresh water tank is aft of the front axle. Water in that tank also helps reduce hitch weight.
We found a load plan after some experimentation that kept the hitch weight less than 1,000 lbs.
ETroup is offline   Reply With Quote
Old 07-21-2021, 09:14 AM   #19
2021 30' Globetrotter
2015 30' FB FC Bunk
Gig Harbor , Washington
This statement is incorrect! The tongue weight is the same regardless of using or not using a WD hitch. A WD hitch simply distributes the tongue weight forward on the tow vehicle. No matter what hitch you use, none of them can magically make the weight at the tongue of any trailer disappear.
kajmonty is offline   Reply With Quote
Old 07-21-2021, 09:56 AM   #20
Dick tracy's Avatar
camas , Washington
Whoa
Actually a good WD hitch will move about 20% of the tongue weight to the front axle of the TV AND 20% to the trailer, leaving 60% on the TV rear axle. No magic required. GT weigh more than either FC or internationals. And as stated before, a full fresh water tank will leverage more weight off the TV.
Weight your rig, dry, loaded, then loaded with full fresh water. Your TV rear axle rating is usually your limiting factor. Weigh it three times each for more accurate readings
Dick tracy is offline   Reply With Quote
2018 GT27 Twin VIN Question Dirtbeard 2018 - Current Globetrotter 7 03-23-2020 07:54 AM
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
