Old 08-07-2021, 07:34 PM   #81
2017 28' International
Jim Falls , Wisconsin
Originally Posted by thewarden View Post
Exactly correct. While I am a huge fan of the Propride hitch, it is the heaviest out there, which just adds to the problem if you are already over your TV cargo capacity.
There is some debate out there as to how much of that weight is transferred to the hitch. Do a search on the forums.
Daquenzer is offline   Reply With Quote
Old 08-08-2021, 08:09 AM   #82
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We added Firestone air bags that fit inside the rear coil springs to our 2021 Toyota Land Cruiser. This could not increase the load rating of the suspension but stiffened the spring to reduce sag when the 23D is attached. The rear axle load fully loaded for camping is still under the weight rating on the door plate and we are under the GVW rating as well.
Based upon my experience with our 2013 25FB International Serenity weights, the Land Cruiser would have the power with itís 5.7L V8 to pull the trailer (rated up to 8,000 pounds) but the Hensley hitch and the Tekonsha Prodigy RF brake controller put the literature 833 pound tongue weight to 1,150 pounds on the dealership lot. The extra roughly 250 pounds over our 23D tongue weight would have generated an overloaded condition before our camping gear was even in the car.
So the scales have the final say if a given proposed tow vehicle is legally capable of towing a specific trailer
Old 08-09-2021, 10:12 AM   #83
Dick tracy's Avatar
2021 27' International
Camas , Washington
Check your Axle weight limits
I think this statement is a bit misleading. Most of the 1/2 ton trucks I see have a payload capacity in the neighborhood of 13-1400 lbs. Trucks with higher trim packages are even less. My neighbors F150 Platinum, for example, has a cargo capacity of just over 1200 lbs based on the door jam sticker.
Given that the GT25s real-world TW (not brochure) is closer to 1000 lbs, that leaves very little for passengers and extra cargo. At best, you are at, or very close to your cargo capacity.
For short trips, on flat roads that may be just fine. But if you are traveling many miles, in hilly or mountainous terrain, I would not be comfortable that my TV was at the max all the time. Just because some truck manufacturers hype says that it can leap tall buildings in a single bound, does not mean you should.
Take that maxed-out 1/2 ton rig down a long 7% grade with a sweeping 50 mph curve at the bottom in 90-degree heat and see how comfortable that is. These are the scenarios where the built-in cargo capacity cushion of a 3/4 or 1-ton truck pays dividends. Not to mention the engine braking of a diesel.
Check your axle weight limits and use your WD hitch to move the weight around and put it on the scale for yourself. I have, multiple time, several different set ups. The man with a theory will always be at the mercy of the man with experience.
PUT it in the SCALE and find out for your self.
2021 International 27 FBT - 2019 F150 Harley Davidson
2017 FC 23 FB - 2002 Range Rover
Dick tracy is offline   Reply With Quote
Old 08-09-2021, 10:16 AM   #84
Dick tracy's Avatar
Camas , Washington
Originally Posted by jondrew55 View Post
Just imagine if they were actually designed to a 17k configuration? No options required!
d
not hard to find in the PNW, almost everyone I looked at had a 7000lbs frame and a 10-11,000 lbs tow rating. Only the low end entry level trucks were less
Old 08-09-2021, 10:23 AM   #85
Dick tracy's Avatar
Camas , Washington
From the 2021 Ford F150 docs
I saw a post or YouTube talking about this. That Ford now was excluding passenger weight from their max rating effectively giving you another 800# of payload. I canít find the reference just remember the person talking about it says it seemed too good to be true.
"Maximum towing capabilities are for properly equipped vehicles with required equipment and a 150-lb. driver and passenger and vary
based on cargo, vehicle configuration, accessories, option content and number of passengers. Maximum payload capabilities are for
properly equipped vehicles with required equipment and vary based on vehicle configuration, accessories, and option content. See label on
door jamb for carrying capacity of a specific vehicle. Horsepower, torque, payload and towing are independent attributes and may not be
achieved simultaneously. For additional information, see your Ford Dealer."
I'm not sure if this means the payload number ACCOUNTS for two 150lbs people, or not.
Regardless it all comes down to axle weight limits and load placement accordingly.
Old 08-09-2021, 11:06 AM   #86
"Cloudsplitter"
IMHO...if the weight of a hitch the determining factor in go or no go, it's time to reconsider the entire rig.
To the OP....Honda 7000= 260lb+ save there?
Iím done with ĎadultingíÖLetís go find Bigfoot.
Old 08-09-2021, 02:11 PM   #87
2017 25' International
West Lake Hills , Texas
It doesn't. The door sticker says "occupants" count as payload. The manual includes the driver and all other occupants in the examples of how to calculate payload. If you still have doubts, weigh the tow vehicle fully fueled and empty. My actual empty, zero occupant, full-fuel weight is 60# higher than it should be...meaning, I'm already 60# poorer on payload. Only extras from stock are a tiny dash cam and Roadmaster suspension.
^1
Yes. Weigh the rig.
Fungus is offline   Reply With Quote
Old 08-09-2021, 03:51 PM   #88
Freedom
KCurtis's Avatar
2023 30' Classic
Dallas , TX
I am so sick of having to think about my payload numbers that I will be buying a 1 ton as soon as I can find the one I want in stock. I am still debating dully vs single wheel though. I am inclined to go with a dully to prevent me from ever regretting not doing so. Like those times on the road when all hell breaks lose.
2023 30 Foot Classic
2022 Ram 3500 Dually
KCurtis is offline   Reply With Quote
Old 08-09-2021, 06:09 PM   #89
2021 30' Globetrotter
Oviedo , Florida
Lol. If you do that then people will be telling you your bigass truck it beating up your little 25í camper and expect popping rivets
jondrew55 is offline   Reply With Quote
Old 08-09-2021, 06:28 PM   #90
Durango , Colorado
Originally Posted by Vitaver View Post
Confirmed with the dealer, the truck has only one 30 AMP receptacle, it canít be combined and provide the amperage needed to run 2 ACs, even with Easy Start (which I got anyway)
I think your dealer is wrong. That one 30 amp receptacle is two independent 30amp 120V circuits. With a cable like this one.
https://www.amazon.com/gp/product/B0...ref_=pd_gw_unk
You should be able to deliver 6000 watts of power. Two A/Cs should not overload 6000 watts. I realize this will not be the 12,000 watts that are typically available for 50 amp service but it should be enough to power 2 A/Cs especially with soft start. I think your dealer is saying that there is only one 30 amp circuit but that is wrong. There is a full 7.2 Kw or two independent 30 Amp circuits.
RVDreamer is offline   Reply With Quote
Old 08-14-2021, 12:01 PM   #91
2021 27' Globetrotter
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
Deciding factor
[QUOTE=RVDreamer;2524817]I think your dealer is wrong. That one 30 amp receptacle is two independent 30amp 120V circuits. With a cable like this one. ď
You are very likely correct but the critical issue for me is the payload, that even without the generator is exceeded. The comments above from another owner that had such a bad experience towing with the exact same truck I had on order finally convinced me to go to the F250 and no need to worry about it. On that one I will need to carry, and will, my Honda 7000
GT 27 2021, F250 2022 Platinum- 2022 Tesla X - 2021 Ford Mustang Mach E - 2022 Tesla 3 - 2023 Tesla S Plaid. PP3 hitch
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
Vitaver is online now   Reply With Quote
Old 08-14-2021, 12:03 PM   #92
Dully. KCurtis, the issue with the dully may be ‘not enough’ payload to keep traction in such a large rubber to pavement ratio. For traction you need, besides good tires, weight on them and if you are not loaded heavy enough, I suspect you are at risk of hydroplaning or just skidding over snow/some ice/wet road/mud, etc.
Old 05-24-2023, 09:56 AM   #93
3rd RV, First Airstream
ETroup's Avatar
Orlando , Florida
Send a message via Skype™ to ETroup
To reduce tongue weight, adjust your load plan - just like we did when loading military cargo planes.
Avoid putting heavy items up front. Example store light extra paper towels under bed and put heavier tools, liquids, canned goods towards the back. Avoid very heavy mattresses. Use light weight linens and blankets - they are easiers to wash and dry anyway.
Anytime you can move something from front to back you get double the benefit. For instance, you could install a TyRAK from Airkraft and move the spare tire and its metal rack to behind the axles. That 100 lbs off the front and moves it to the rear.
These measures together can reduce excess tonque weight by 200 lbs or more.
ETroup is offline   Reply With Quote
Old 05-24-2023, 02:52 PM   #94
"Cloudsplitter"
OP...was the TW gotten by the dealer a loaded for camping number?
IMHO...if 'payload' is such an issue something was wrongfully planed.
It's been my experience that you need a proper TW and loading 'to the rear' is not the correct solution for a lack payload capacity.
Point of interest what exactly is 'excessive TW'...isn't it just more weight than your setup can handle? Planning
Brochure TW was 820.
Old 05-24-2023, 06:25 PM   #95
ETroup's Avatar
Orlando , Florida
The published tongue weights seem to be derived from the published GVWR (i.e., the loaded weight) of the trailers.
For my 2021 International 27, Airstream lists the loaded weight as 7,600lbs and the tongue weight as 791 lbs (10.4%).
I am defining anything over 800 lbs as "excessive tongue weight" especially when the CAT scales say the whole trailer only weighs 7,000 lbs total actual.
Loading more to rear of the axles to get closer to manufacturer specified 800lbs seems perfectly reasonable (and safe) to me.
Old 05-24-2023, 11:37 PM   #96
2018 28' International
Fayetteville , Georgia
My 2018 International Serenity 28/50amp has to tongue weight of almost 1100 lbs. A wee bit more than factory specs.
brick
Cute wife...
brick1 is offline   Reply With Quote
Old 05-25-2023, 06:09 AM   #97
"Cloudsplitter"
Published weights have no home here, they present to be a dart board number.
Oh boy am I in trouble with a 1200lb TW
BTW...we measure TW un-hitched, with a fully loaded AS.
When hitched with WD set it becomes a receiver weight of 860lb YMMV
2018 GT27 Twin VIN Question Dirtbeard 2018 - Current Globetrotter 7 03-23-2020 07:54 AM
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
