Old 03-29-2020, 09:17 AM   #1
Woodside , California
Tongue weight 25' FC FBQ
I just tried to calculate my FC's tongue weight using the bathroom scale method- one end of board 1 ft. from the hitch post, the scale located 4' from same point, lower trailer until full weight on board, read scale and multiply by 5. In my case, the scale read 240# meaning my tongue weight is 1200# which seems excessive. What I carry in front storage is hitch assembly, weight distribution bars, hoses, and plastic blocks, then under the bed I have a few items such as camp chairs, small grill, etc. I tow with a Ford F150 crew cab, short bed, maximum tow capacity of 11,000# and in my travels to date I have never experienced any towing issues.
So, it my estimate technique correct and reasonably accurate? If so, is this tongue weight in a normal or expected range for this trailer? Maybe I'd be better off not knowing, but in these times of social isolation I have too much time on my hands.
Hope everyone is healthy and practicing good social isolation.
Gary
ghanesdvm is offline   Reply With Quote
Old 03-29-2020, 09:40 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My 25' trailer is a much older RB narrow body. My tongue weight is about 900 lbs. I did that with the bathroom scale years ago. The trailer adds 800 lbs to the truck when hitched and about 100 lbs is transferred back to the trailer axles. I would think your measurement is close. Static tongue weight does depend upon the trailer being level or at the same angle as when hitched. I am one that thinks tongue weight is pretty much a plus for towing stability. In your case a hitched weight on the front and rear TV axles and a unhitched weight on those axles would be instructive. Just one pass through with the trailer hitched would be very instructive. If you can do that now? Even if the TW is 1250 I do not think I would try to change it.
Old 03-29-2020, 09:46 AM   #3
2014 25' FB Flying Cloud
Kingwood , Texas
Probably a pretty close weight. Our 2014 FC 25 FBT, with a ProPride hitch has a tongue weight of 1,200 pounds. I weighed it using one of the trailer specific scales. The 25 footers seem to have more tongue weight compared to bigger Airstreams.
DoubleR is online now   Reply With Quote
Old 03-29-2020, 09:50 AM   #4
2015 25' FB Flying Cloud
Eugene , Oregon
Our 2015 FC 25FBQ tongue weight averaged 1150 lbs.
Meeks is offline   Reply With Quote
Old 03-29-2020, 09:51 AM   #5
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The last one I weighed was 990#, with full LP and water, and no hitch parts installed.
Old 03-29-2020, 11:06 AM   #6
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
1200 lbs tongue weight is too much for a 6000 lb trailer. That's 20%. The normal recommendation is that the tongue weight should be between 10% and 15%. If the tongue weight is too high the rig will be more prone to jackknife in a hard emergency turn. If it is too low the trailer will be more susceptible to sway. I would look to redistributing the trailer contents, putting heavy items more to the center of the trailer.
out of sight is offline   Reply With Quote
Old 03-29-2020, 11:26 AM   #7
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Is your scale actually under the hitch, or are you using the jack? Weights will be different ...
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 03-29-2020, 11:52 AM   #8
Micanopy , Florida
2014 25 ft front twins. When new, not loaded, no hitch ,one bottle propane with whatever the dealer put in, weighed in about1040. Since then have installed, pro pride hitch , filled both bottles with propane, ( many times) enlarged battery box to accommodate bigger batteries (2) , filled both front side (2)and front compartments with all of neat stuff one needs, bedroom cabinets have clothes, necessary sheets and whatnot , and I consistently weigh in give or take...1175 to 1225. From what I have read that seems to be pretty average. Oh yes ,done with a shurline scale. I keep that under kitchen seat . ( in the back).
Done all 49 states ,( no Hawaii) all the provinces except Labrador and PEI. Never had a problem. Enjoy it!
Offack is offline   Reply With Quote
Old 03-29-2020, 12:35 PM   #9
Kingwood , Texas
Under the hitch and level trailer, to get the proper tongue weight.
Old 03-29-2020, 09:48 PM   #10
Loaded trailer weight is 7300#
Old 03-30-2020, 06:20 AM   #11
2010 25' FB Flying Cloud
Davenport , Iowa
last year at a rally, we had a meeting of the minds where we measured several trailers for tongue weight. Four members brought their Sureline scales, so we tried each scale on different trailers.
My 2010, 25 fb converted Q to twin weighed from 950 to 1100 pounds. That was the low and high weights.
Which scale do I believe, 4 scales, 4 different weights?
Airtandem is online now   Reply With Quote
Old 03-30-2020, 06:29 AM   #12
Davenport , Iowa
we leveled the trailer each time.
we averaged the weights and mine was 1025#
we used same procedure on different size trailers from 19 to 34 ft with about same results. ALL above what AS lists for tongue weight.
None were compared to Truck scales.
Old 03-30-2020, 06:34 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
They are not certified scales...the dial on our 2000 is in 50lb increments.
The positive side you have a lot more info than most.👍
POI..you get the most accurate from directly under the ball.
CAT figured TW is actually not tongue wt, the weight is taken at the TV rear axle.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire"
Amanamus
Tahawus....🌥
Old 03-30-2020, 06:37 AM   #14
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Here is a link to my FC25FBQ scale tickets with a Propride hitch. Tongue weight 980#. https://www.airforums.com/forums/f42...ml#post2202254
2018 GT27Q, 45 nights 9,860 miles, 600W Solar - Produced 75kWh, PD4655L, 6V Batteries, Champion DualFuel, ProPride&BOSP, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, 400W Solar - Produced 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(To RF)
AirMiles is offline   Reply With Quote
Old 03-30-2020, 07:18 AM   #15
2014 22' FB Sport
Davie , FL
The Sherline scale gives erratic readings if there is an air bubble in the oil.
Old 03-30-2020, 07:41 AM   #16
Davenport , Iowa
This was al done as part of our Tech Talk" at one of our rallys.
There was alot of room for error, but was interesting in seeing the different weights measured.
There was room for error in how the 2x12 used as a base for the scale sank in the ground, what if the measurements were done on a more solid surface.
We realized these measurements would not be correct, but it was a start.
Old 03-30-2020, 11:44 AM   #17
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
Airstream Weights
The attached link has a lot of the parameters for Airstreams:
http://airstreamguy.com/lengthswidthsweights_vin_range
WindyJim is offline   Reply With Quote
Old 03-30-2020, 12:55 PM   #18
Huntley , Illinois
We had a 2015 FC FB 25. We had it weighed at the scales and hit 1300 lbs. we weighed several times and called colonial. Not surprising to them. With tanks full, water and wheel base this is a true weight. There is an extensive thread on this topic if you research it in the forum web site. You can only get the weight down if you do not use the external lockers. Do not go by the brochure!
cegardner is offline   Reply With Quote
Old 03-30-2020, 03:43 PM   #19
Baltimore , Maryland
There will be variations in TW due to hysteresis (look it up) on dual axle trailers due to how the tongue was raised and/or lowered prior to measuring. Don’t sweat it.
Profxd is offline   Reply With Quote
Old 03-30-2020, 04:03 PM   #20
2018 25' Flying Cloud
Morton , Illinois
Gary
Our 2018 25ft FCFB torque weight is 1125lbs. Odd a CAT scale.
mckenej is offline   Reply With Quote
FC27 FBQ wiring chase routing DC AC cptdzl Electrical - Systems, Generators, Batteries & Solar 7 11-21-2019 07:12 PM
New 27 FBQ Question AgBullet 2016 - Current Flying Cloud 2 02-19-2019 07:20 PM
New 2019 Globetrotter 27 FBQ (!) Hareynolds 2018 - Current Globetrotter 26 09-17-2018 09:13 PM
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
