07-01-2019, 08:52 PM
Wasilla
, Alaska
To weld or not to weld
The receiver on my tv is larger than the hitch so I was given a sleeve to make up the size difference. Now trying to line up the hole in the sleeve to the hole in the receiver to get the pin in is such a pain in the arse. I've been thinking about welding the sleeve to the hitch but not sure that's a good idea. Can someone please advise?
Man plans ... The Gods laugh
07-01-2019, 09:43 PM
1995 25' Excella
xxxxx
, xxxxxx
I can't see anything wrong with welding the reducer to the shank.
2017 30' International
Broomfield
It’s a pain but you get used to it. Helps to use a pin that has a beveled end. I would not weld.
07-01-2019, 11:17 PM
Wasilla
, Alaska
My concern is weakening the shank when it's heated during welding. Are you an experienced welder?
07-01-2019, 11:22 PM
Wasilla
, Alaska
The pin I'm using is beveled it's just that the sleeve slides in when I put hitch in. Can you explain why you think it's a bad idea to weld. I'm just trying to weight the pros and cons and so far there is only 1 pro and 1 con.
07-01-2019, 11:51 PM
1995 25' Excella
xxxxx
, xxxxxx
Yes, I can weld. No, I am not a certified welder....lol.
My shank is solid steel. I can't see welding on it causing it to weaken...I suppose to keep from worrying, one could only weld forward of the pin hole.
I contemplated welding my reducer to the shank. I decided against it because I wouldn't be able to use it in a 2" truck if something happened to my truck while I was traveling.
07-02-2019, 01:59 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Why not spot weld two nipples on the reducer which would stop its movement right at the perfect depth?
07-02-2019, 04:21 AM
1995 25' Excella
xxxxx
, xxxxxx
Good idea, except wouldn't you weld the two nipples on the shank? With my aftermarket reducer you would. It slides inside the receiver about an inch. Of course, if you did that the 2" shank wouldn't fit a 2" receiver any longer.
The factory Ford reducer is flared on the end. It stops at the perfect depth.
I really wasn't considering welding the reducer on the shank due to having trouble putting the pin in, though. I was considering welding to take the extra play out of the hitch shank.
07-02-2019, 04:48 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes, weld...done by Reese when I bought the receiver.👍
One nice benefit...it doubles the thickness, less chance of an egg shaped pin hole.🤔 15 Seasons. SFSG
CRH...I had the shank welded. Three thin wide beads, top and both sides ground down to fit snugly.
07-02-2019, 04:58 AM
I would weld the sleeve into the hitch receiver box. This is a common adaptation method, and the metals in question are not exotic.
William C. Swinney
07-02-2019, 05:36 AM
Charlotte
, North Carolina
My snarky comment is why not just buy the correct sized shank?
The weld/don't weld question...I agree with the poster above is you lose your option to remove the reducer in the case of a different size shank.
If you are just aligning the pin hole, spot weld it so it can be easily removed. Or weld a bead to stop it where holes are aligned. Or buy one flanged correctly.
These are mild steel parts and can be welded, but I would not. I am a weldor, not certified.
07-02-2019, 05:48 AM
1995 25' Excella
xxxxx
, xxxxxx
The reason I did not buy the correct sized shank is because I couldn't find a 2.5" that had the length and drop that I wanted that would work with my chosen hitch head.
07-02-2019, 06:04 AM
Virginia Beach
, Virginia
My reason for not getting a 2.5" shank is I am getting old and lifting a 2" is already a strain. Buh!
07-02-2019, 07:37 AM
2019 28' Flying Cloud
2014 22' FB Sport
Davie
, FL
It's low carbon steel. You're not going to weaken it by welding.
07-02-2019, 08:46 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I'd put the reducer into the receiver, insert the pin, and weld along the outside edges that face toward the rear of the TV.
A little bead down each side would probably do the job.
07-02-2019, 09:22 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
You have my permission.
07-02-2019, 09:24 AM
2012 23' FB International
Woodstock
, Ontario
Just tack it in place and then if need be you just grind out the tacks,
JCW
07-02-2019, 09:44 AM
2018 33' Classic
Medway
, Massachusetts
Weld tab
I had the same issues and solved it by welding on a tab only that lined up the sleeve hole with the receiver hole so the only juggling is with the hitch itself. The benefit is this is not ‘permanent’ and retains full flexibility of using the different available sizes.
07-02-2019, 10:10 AM
2013 31' Classic
billings
, Montana
Mine is somewhat loose...you weld the outside...you best weld the inside or the outside will be trying to do all the work...as the inside will be loose...and flopping around...
07-02-2019, 11:50 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Ours' is welded around the front receiver lip and has been "flopping" around,(not), for 15 Seasons.
SFSG.👍
