Old 11-14-2022, 08:44 PM   #1
Aluminated
1977 31' Sovereign
1987 29' Airstream 290
Norman , Oklahoma
Images: 14
To spend or not to spend and does it make a difference?
I'm in the middle of a renovation on a 1977 31' International Sovereign. I'm towing it with a 2019 Nissan Armada. I'm at about 70% of the vehicles towing capacity. I'd like to know if it's recommended that I install an anti-sway setup and add electric brakes to the rig? I towed the trailer about 100 miles to get it back to my shop and it towed well and it stayed in a nice straight line behind my tow vehicle. There weren't any issues with stopping either. Are these items required anywhere in the states or crossing into Canada and are they worth the investment? Thanks, Eric
ericjan2 is offline   Reply With Quote
Old 11-14-2022, 08:50 PM   #2
dznf0g's Avatar
Oswego , Illinois
Brakes are required. And I'd highly recommend sway control.
-Rich-
Old 11-14-2022, 10:36 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
You definitely need brakes and probably will want sway control.
CRH is offline   Reply With Quote
Old 11-15-2022, 05:18 AM   #4
InvertdEagle's Avatar
2023 33' Classic
Manassas , Virginia
In Virginia, if the trailer weighs more than 3000 lbs, brakes are required by law. Most states have a similar requirement.
InvertdEagle is offline   Reply With Quote
Old 11-15-2022, 06:53 AM   #5
SlowPokePete's Avatar
2020 25' Globetrotter
Hillsdale , New York
Yes on both...always better to play it safe, and follow the law.
SPP
SlowPokePete is offline   Reply With Quote
Old 11-15-2022, 07:03 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
New axles should be part of your restoration and they will come with brakes. The trailer should be wired for them since it came with brakes from the factory. Sway control is optional, but recommended.
Richard
Old 11-15-2022, 07:18 AM   #7
dznf0g's Avatar
Oswego , Illinois
The lowest common denominator I have deduced is 1500 pounds as a states' requirement for trailer brakes.
-Rich-
Old 11-15-2022, 07:39 AM   #8
Aluminated
1977 31' Sovereign
Norman , Oklahoma
Images: 14
Thanks for the input. I actually figured I would need to do the brakes at least, and I've gotten a quote from E-Trailer for the sway control. I'm having the underbelly (frame and holding tanks, axles and associated plumbing and wiring) inspected before it goes back on the road. If the axles and current brakes are in good shape is it still recommended that I replace the axles? I'm trying to adjust to living on a fixed income and nothing is getting cheaper!
Old 11-15-2022, 08:06 AM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
If the axles are original, they need to be replaced. It is all about height and travel. To check travel, the wheel should drop a couple of inches when the trailer is jacked. If it does not, the rubber inside the axel has hardened and will not absorb shock.
Richard
Old 11-15-2022, 09:10 AM   #10
Aluminated
1977 31' Sovereign
Norman , Oklahoma
Images: 14
I just got off the phone with Dexter axles in Chickasaw, Oklahoma, about ten miles from me. They said If I can get a picture of the number stamped on the axle it would help them get the correct axles for me. They said there is also an 'information plate' on the axle and that would also help them identify my axle. Can anyone tell me where to look for this information while I'm under the trailer? Thanks for the assist
Old 11-15-2022, 09:45 AM   #11
2017 25' International
West Lake Hills , Texas
If replacing axles, it be a good time to consider hydraulic brakes.
Fungus is offline   Reply With Quote
Old 11-15-2022, 10:39 AM   #12
1960 26' Overlander
Tipton , Iowa
You have already heard about brakes. Sway control is required by law in the state of Iowa.
Scott S is offline   Reply With Quote
Old 11-15-2022, 10:59 AM   #13
Bouctouche Dunes
1976 Argosy 26
Moncton , New Brunswick
Trailer Brake requirements for Canada
In New Brunswick, Canada, any trailer over 2,000 lbs is required to have independent trailer brakes. In my opinion you did well to tow a 31' travel trailer anywhere without a weight distributing hitch and sway control but I see that the Nissan Armada has some impressive anti sway and load levelling features in it's suspension. You'll have to be the judge of that one. Happy Trailering!
kevinf is offline   Reply With Quote
Old 11-15-2022, 11:35 AM   #14
Little falls , New York
Agreed. Take it from a guy who has had an axle break on a vintage unit. (Just don’t do the lift. They look ridiculous..)
civeng99 is offline   Reply With Quote
Old 11-15-2022, 12:39 PM   #15
I should have said hydraulic disc brakes.
Old 11-15-2022, 01:52 PM   #16
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
And we would recommend if you're going to take it off-road go ahead and do the lift kit it doesn't look that badly and it performs very well. If you're sticking more towards pure authentic restoration by all means leave off the lift.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 11-15-2022, 07:33 PM   #17
2019 25' Flying Cloud
Hendersonville , North Carolina
Originally Posted by civeng99 View Post
Agreed. Take it from a guy who has had an axle break on a vintage unit. (Just donít do the lift. They look ridiculous.)
Don't do the lift? The first time he drags the tail of that 31' long trailer going into a fuel stop or any other place that has dips, uneven curbs, steep driveway approaches etc. he will wish he included the 2 3/4" lift when installing new axles. I have a 2019 FC 25' and would not even attempt to go up my driveway without a lift kit install. Looks Silly? Depends. Dragging the back of the trailer is pretty silly. No effect on handling or towing.
uraljohn is offline   Reply With Quote
Old 11-15-2022, 08:06 PM   #18
I would add axles while your at it...
It's that time again... Have a great Happyhollowgivingthankmas everyone.
Old 11-22-2022, 01:22 PM   #19
1978 25' Tradewind
Houston , Texas
I was in a very similar situation and just got new axles. 5500# axles were only ~$2500 each, and given how important that part is, seemed well worth it. There is also the issue that trailer brakes are a critical part of sway control. A good WDH will have sway control, but that's really more "sway mitigation". If a sway condition arises, the ONLY way to damp it is prompt application of the trailer brakes. So a sway control hitch makes that situation less likely, but working trailer brakes are the only solution once it comes up.
amschind is offline   Reply With Quote
Old 11-22-2022, 07:12 PM   #20
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Sway control is like safety glasses. You don't need them till you wish you had them.
kscherzi is offline   Reply With Quote
Standard 30amp power cord or 90M/90F? Does it make a difference? StreamingB Electrical - Systems, Generators, Batteries & Solar 0 07-04-2018 05:18 PM
What a difference new axles and tires make Hummer Axles 9 04-20-2015 07:17 AM
Can two more inches make a difference? ROBERTSUNRUS Hitches, Couplers & Balls 19 02-02-2011 11:22 AM
Good swaybars make a difference tetstream Tow Vehicles 1 09-01-2007 12:50 PM
The right person does make a difference stinkytwinky Waste Systems, Tanks & Totes 16 09-25-2005 12:53 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
