Old 05-22-2021, 10:37 AM   #1
1976 Argosy 20
2019 25' Flying Cloud
Escondido , CA
Tahoe lift gate hits trailer jack
Hello,
Has anyone else had this problem... 2019 25FC FB - My tow rig is a 2020 Tahoe and the lift gate hits the trailer jack - I almost always un-hitch when we are out but sometime we stay hitched and it's a real PIA to get gear out of the back of the Tahoe. Any suggestion would be most welcome.
Workbench is offline   Reply With Quote
Old 05-22-2021, 10:57 AM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
The issue has affected many. For most, the solution is to rotate the jack head.
https://www.airforums.com/forums/f44...ml#post2121725
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 05-22-2021, 12:14 PM   #3
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
I'm not sure how the Tahoe tail gate works, but on my trucks in the past, the tailgate was easily removed by opening slightly and lifting up and out. Obviously the "ease" will depend on the weight of the gate, but removing the gate for access once you reach your destination may be an option while towing.
kidjedi is offline   Reply With Quote
Old 05-22-2021, 12:24 PM   #4
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Are you using a weight distribution hitch? A Hensley Arrow or Pro Pride will give you 18” additional clearance. It’s also well worth the investment coming from someone who previously used a blue Ox & Equalizer. If your going to be doing a lot of trailering. Get one of those hitches. No more hatch issues, you will never feel your trailer sway ever again.
- Stewart
s1000pre is offline   Reply With Quote
Old 05-22-2021, 12:34 PM   #5
kidjedi's Avatar
1972 25' Tradewind
1975 24' Argosy 24
Denver , Colorado
Truth. When I was using a Hensley Hitch (it was overkill for my situation, but they are fantastic for sway!), I could practically lay down between the trailer and vehicle. Without it, I have to remove the spare tire from the gate to even hitch up.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
Old 05-23-2021, 10:39 AM   #6
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
Originally Posted by Workbench View Post
Hello,
I've got a Yukon that does the same. I found that if I extend the tongue jack to the extent it lifts the hitch a few inches, the tailgate will clear the jack. Just remember the jack is down in the morning, if you don't retract it once you are done. Sometimes, I just open the window instead of the whole hatch . . .
Mike G is offline   Reply With Quote
Old 05-23-2021, 10:44 AM   #7
Ray Eklund's Avatar
2019 27' International
2014 25' International
Oregon Buttes , Wyoming
This worked for a 2006 Tundra lift gate and a 2006, 23 foot Safari.
IF it is the control mechanism that is in the way. Loosen the hex screw and rotate. If that does not fix the issue... longer shank.
A bigger issue is if you make a sharp turn, your tail light may make contact with the Rock Guard, denting it and pushing it into the aluminum panel of the Airstream.
Once you get it worked out, let everyone know. I use Equalizer Hitches with the bars and have lots of distance and can be 90 degrees and have clearance between the tail light and trailer.
One year of Tundra's had bulging tail lights (maybe the 2008) and these tail lights were not on the later models. (For those with Tundras... of course.)
Human Bean
Ray Eklund is offline   Reply With Quote
Old 05-23-2021, 10:51 AM   #8
Tom T
Tom_T's Avatar
Orange , California
Another one for the Hensley Cub WD/AS hitch for hatch/tailgate clearance, as well as to eliminate sway for comfortable driving, ease of using crank jacks for the torsion bars adjustments, no need to take off the hitch head & bars when parked, tighter turning radii, & other advantages.
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 05-23-2021, 12:40 PM   #9
2019 30' Flying Cloud
Grass Lake , Michigan
Had the same problem on my RAM truck. Bought an 8” hitch extender from etrailer that is rated for 10k pounds. Works great and didn’t cost much. Not sure if there’s one for a 2” receiver with enough weight rating for your 25’ trailer but may be worth a look.
oldenavy is offline   Reply With Quote
Old 05-25-2021, 07:47 AM   #10
2019 19' Flying Cloud
Denver , Colorado
I have a toyota sequoia (love it) but gate will sometimes hit depending on the pitch of the ground I am parked on. I use the jack to slightly raise the trailer while hitched and that will help it clear. I also pack where I can roll down the back window to get at stuff.
KeithMehrens is offline   Reply With Quote
Old 05-25-2021, 08:32 AM   #11
Mollysdad's Avatar
Tahoe 'lift' gate, I'll assume is a SUV with a rear door that goes up.
If you choose to turn the jack head here's how I did mine.
https://www.airforums.com/forums/f45...ys-196460.html
Tailgate hits tongue jack. Turtle Hitches, Couplers & Balls 53 02-26-2022 09:49 AM
Big DEE hits 1000!!! Buttercup Our Community 6 05-10-2007 06:40 AM
Our new (not so) baby hits the road. Pecos Pete Our Community 10 02-08-2007 05:48 PM
NEW 1948 Suburban hits the market! 85MH325 Off Topic Forum 21 09-10-2005 07:03 AM
