07-26-2018, 07:19 PM
2016 27' International
2018 30' Flying Cloud
Norman
, Oklahoma
Sport 16 Weight Distribution System needed?
Do I need sway or weight distribution system for a Sport 16?
Its recommended of course. Maybe I need one more because a light wind could blow that trailer down a parking lot. Would appreciate any opinions. Thanks.
07-26-2018, 07:24 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
What will you tow with? That will decide.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
07-26-2018, 07:26 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Whether you need weight distribution, or not, depends on the tow vehicle. If the weight of the trailer on the back reduces the load on the front axle substantially, then you need weight distribution (to return load to the front axle). So, if you are towing with a small vehicle and the hitch is several feet behind the axle, yes. But, if you tow with a 1 ton truck, no.
Sway control, yes you need.
Alan
07-26-2018, 07:32 PM
Norman
, Oklahoma
The trailer will be hauled by two tow vehicles. Ford F250 and 2016 Toyota Land cruiser. Forgot to add that. Thanks for the comments. Already have an E4 equalizer set up for my 30' Flying bunk. I am assuming the weight rating for that(30'bunk) could be too much for the weight rating for the Sport. Can I use the same equalizer E4 set up on the Sport?
07-26-2018, 09:23 PM
1991 25' Excella
Santa Ynez
F250 No to WD.
LC my guess is no also but not familiar with that rig.
I tow our FC19 with a tundra 1/2 ton and no WD but a sway bar.
Drop the trailer on the ball and see what it looks like, if no rise in the front wheels your probably ok.
Others will disagree with my simplicity but you talking 350 lbs? of tongue weight.
Will Rogers
Alan
07-26-2018, 09:37 PM
2017 30' International
Broomfield
Spring arms on your E4 (assuming you have the 1000lb bars like I do for my 30’) are too stiff for the 16’. Don’t do it you’ll rattle the bambi apart (as you know tension on the spring arms / WD needs to be applied with the e4 to activate friction-based sway control)
You need the 400lb or 600lb spring arms on the smaller equalizer unit (if you want to stick with that brand)... I believe the head is smaller for this spring arms = new hitch.
Alternatively per the other poster you might just not worry about WD with such a light tongue weight - and simply apply a single friction-based swat control arm. You do want sway control.......
07-27-2018, 01:37 PM
2017 16' Sport
N/A
, N/A
Equalizer is both a weight distribution and a sway system, after all a 16’ Bambi Sport is still almost 2 tons of trailer.
07-27-2018, 01:42 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Try a Hensley Cub it is down sized for smaller trailers such as yours.
guskmg
07-27-2018, 01:43 PM
2017 16' Sport
N/A
, N/A
I would go with a lighter spring bar as referenced in an earlier Post. Call Equalizer company or an Airstream dealer.
07-27-2018, 03:09 PM
Norman
, Oklahoma
My dealer reccomended Sway Pro by Blue OX. The trailer will be used by my wife more than me probably. He thought it would work better. I am so used to Equalizer.....I feel like sticking with it. Sway Pro looks fine too I guess. Thanks for the responses.
04-28-2020, 04:53 PM
2018 16' Sport
San Antonio
Hi OKstream,
I have a Sport 16 also and wondering about sway control. I'm wondering what you decided and how it's worked out for you.
thanks
