Shank size,?New Taller truck
Previously I had an 18 y/o Dodge 2500 4X4 short bed pickup pulling an 85 dual axle 25' Airstream dry weight of 6800lbs and the top of the ball on the Equalizer hitch was 18" to have the trailer pull at level with the shank horizontal length is 12" and the drop(?) verticle length is 8 3/4~9" and the head is mounted in the last bottom two holes.
My new RAM 2500 4X4 short bed sits quite as bit higher:
the Coupler height is 24 3/4"( from the pavement to the inside top of the 2.5" receiver) the ball height still needs to be 18" with a Receiver height of 19" for the Airstream to pull level.
What 2" shank-have the receiver adapter- (or a 2.5" would fit as long as the vertical part does not exceed 2" in order to re-mount the head) should I purchase?
thank you,
Lee Johnson
Corriente de Aire
85 Soverign
