Old 07-07-2020, 08:16 PM   #1
2012 23' International
clovis , California
Scale weight question
I need to get a weight measurement on my pickup truck tow vehicle. When I called a local CAT scale... the guy on the phone acted like I had 3 heads.
Was I just talking to the wrong guy, or do some CAT scales just do big rig
comercial truckers?
jgerardi22 is offline   Reply With Quote
Old 07-07-2020, 08:31 PM   #2
2014 27' Flying Cloud
Paramus , New Jersey
You can weigh your pick up there. If you download the app, you can get weighed right from your truck and never go into the truck stop to pay. I believe the fee is $12, if you go back with your trailer within 24 hours, the re weigh is only $2.50. Also you be asked by the app or the attendent for a trailer number. I just make one up, like 1234.
When you pull on the scale, there is one pad for your front axle, one for your rear and one for your trailer axles.
Good luck Click image for larger version
wilsodf is offline   Reply With Quote
Old 07-07-2020, 08:47 PM   #3
2018 25' International
Slidell , Louisiana
All the CAT scales will weigh anything that rolls up, but they don't get a lot of trailers. the one down the road from where I live gets a lot of military transfers due to the many bases in my area and you have to have a certified weight ticket to enter the base so they see some to the point that each time I pulled in, they asked if I was in the Military.
Anyway since they don't see a lot of travel trailers, it would help if you get familiar with the procedure. What they generally prefer is this:
1) Pull onto the scale with WD hooked up. Get your front axle on the front scale, your rear on the middle scale and the trailer on the back scale. The yellow paint lines clearly mark them.
2) Use the call button to talk to the operator, provide requested information, tell them this is your first weighing today, and give them a truck number when they ask. Just make one up, like the last four of your social or phone, they need to punch something in.
3) Run into the counter to pay and tell the operator you are going to do two more weighings after the first one. Pay the full amount ($15 or so for all three) They will hand you the first ticket,
4) Go back to the rig drive off, release WD tension and drive back on, ring the operator tell them it is the second weighing and provide the weighing number from the ticket. when finished, drive off.
5) disconnect the trailer in the truck parking area and return to the scale with just the vehicle on the front and middle scale. Ring the operator, repeat and when finished drive off.
6) Collect the two other tickets, re-hitch the trailer, you are good to go.
edit: yeah also what he said ^
Brian
BayouBiker is online now   Reply With Quote
Old 07-07-2020, 09:41 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The first time I used a CAT scale I pulled in right behind a Subaru sedan.
SSquared is offline   Reply With Quote
Old 07-08-2020, 05:20 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
I use a "four" ticket method. I add a full WD run so I know the maximum limit of the WD set-up.
I have my Hensley jacks marked and with a bit of experience one CAT trip per Season is all thats needed.
The more you learn about YOUR rig the easier it gets.👍
ID:	372222   Click image for larger version
ID:	372224   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 07-09-2020, 09:24 AM   #6
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
Denver , Colorado
If you are just wanting to know your vehicle's weight and don't need it "certified," any landscaping place that sells large quantities of gravel, rock, etc. will have a scale. I have found that they'll often weigh your vehicle for no charge.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 07-09-2020, 09:36 AM   #7
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Talking
Good luck Attachment 372193
This is what i did, works good. And you can adjust your chain settings on the WD Hitch and go for a re weight too
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet]
Ultraclassic is offline   Reply With Quote
Old 07-09-2020, 09:56 AM   #8
2000 30' Excella
GTA , Ontario
This is OK for total Rig weight but really is a useless number to use for calculating your weight set up.
With a CAT Scale you get Tow Vehicle Front [Steer] and TV Rear and Trailer Axles, And total Rig
If you take your truck over first all ready to Camp/tow, [No trailer on]
then do a re weight with the trailer ready to camp,
No WD set tight or chained up
Then do a Third re weight with the rig all set with your WD set for towing
Like Bob did he posted pictures
This will give you a lot of info to plug into a spread sheet or use for toilet paper if you run out no but seriously
you will know your actual TV gross - maybe plus your sidekick and dog [add accordingly - proceed with caution]
You will know your actual Trailer Gross [+/- propane/water load]
you will know how much trailer weight is on the TV rear axle and how much front axle lift you get.
You can calculate your trailer tongue weight
Then with your WD set to where you "Think" it should be you can see how much Weight is being transferred from the rear of the tow vehicle to the trailer Axle and The Front Axle.
Cheers Ultra
Old 07-09-2020, 10:00 AM   #9
kidjedi's Avatar
1972 25' Tradewind
Denver , Colorado
Right. But the OP didn't say what he/she needed the info. for, and if they just need to know how much the vehicle weighs, I'm letting them know that there are much easier ways (ha! see what I did there?) than driving all the way to a CAT scale.
BeahmStream.com
Old 07-10-2020, 05:34 AM   #10
2000 30' Excella
GTA , Ontario
Ok I re read the OPs question and you are sort of correct. . He/she asked about a CAT scale and I ran with it LOL, Yes I have got the empty truck weight at a scale at a landfill but like I said it is only "part" of the equation and not helpful in the big picture
Old 07-13-2020, 11:46 AM   #11
clovis , California
Thanks guys... always helpful!
Old 07-13-2020, 12:06 PM   #12
2007 25' Safari
Rogers , AR
Last time I weighed I didn't have a WD hitch.
Weigh #1 I unhooked the trailer and pulled the truck forward on the drive axle scale.
Steer Axle 0lbs
Drive Axle 5240lb (2005 GMC Crew Cab 1500)
Trailer Axle 5080lb (remodeled 2003 Keystone 24FB dry + propane)
Weight #2 I hooked the trailer back up and weighed normally
Steer Axle 2860lb
Trailer Axle 3120lb
Trailer Axle 4520lb
Simple math says that my tongue weight (5080-4520) is 560lb
I just realized that the gross weight differed between readings by 180lbs. Only thing I can think is if I was sitting in the truck on the last weigh?
2007 Airstream 25FB Safari LS - GY Endurance - Prodigy Wireless - Andersen
2005 Chevy Silverado Crew Cab 2500HD Duramax Allison 12000lb tow cap
2008 Porsche Cayenne Turbo 500hp/516lb-ft 7700lb tow cap
2005 GMC Sierra Crew Cab 5.3L 2wd Towing pkg, built trans, 40k Tru-cool 7000lb tow cap
Mr. Merk is offline   Reply With Quote
Hitch weight with a bathroom scale CanoeStream Hitches, Couplers & Balls 36 08-27-2017 12:43 PM
Using a Sherline tongue weight scale ? Storis Towing, Tow Vehicles & Hitches 5 08-04-2015 03:06 PM
Sherline LM 2000 tongue weight scale and ProPride WD Hitch DeltaRon Towing, Tow Vehicles & Hitches 12 07-29-2015 04:39 AM
Tongue weight scale for loan? cwf Towing, Tow Vehicles & Hitches 0 08-03-2013 09:48 PM
