Old 05-08-2020, 08:28 AM   #1
2019 33' Classic
townsend , Tennessee
Rock Tamers for GM Duramaz
Looking for rock taming solutions on GM's Duramax trucks. Everything that I've seen so far has the exhaust blowing right onto the rubber.
I did see one photo of an application that had a cut-out for the exhaust, but given the distance from the exhaust to the rubber, I'm not sure it helped that much.
My guess is that the normal exhaust isn't as much an issue as is the regen exhaust.
2020 GMC Denali 2500 HD
Appreciate any suggestions or phots.
BryonJ is offline   Reply With Quote
Old 05-08-2020, 08:41 AM   #2
dznf0g's Avatar
Oswego , Illinois
https://www.etrailer.com/Accessories...rs/ERT230.html
They make a heat shield for this. I fabricated my own years before this was available.
-Rich-
Old 10-15-2020, 07:59 PM   #3
K4TCJ
2009 27' FB Flying Cloud
2006 22' Parkway
Chiefland , Florida
I installed the round exhaust outlets sold by Rocktamer. They are cut in the flap AFTER all adjustments are final. Have been on my Ram 1500 for 6 months with no issues.
Also installed the “Airstream” name plates instead of the Rocktamer ones.
K4TCJ is offline   Reply With Quote
Old 10-15-2020, 08:23 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I’ve got them on my GMC Duramax. Heat shield is the way to go. No problems at all with mine.
Rock Tamers - not a cure for stupid Tin Diesel Rock Guards, Segment & Window Protectors 16 08-13-2017 10:30 PM
Rock Tamers from Cabela's markdoane Hitches, Couplers & Balls 33 05-13-2013 08:50 PM
Hensley and Enkay Rock Tamers Roadtoaster Hitches, Couplers & Balls 5 03-06-2007 09:07 PM
Enkay Rock Tamers: Trim Length Tin Diesel Rock Guards, Segment & Window Protectors 6 05-20-2006 03:45 PM
Rock Tamers vs Protect-A-Tow vs Towtector ITowSilver Rock Guards, Segment & Window Protectors 17 03-29-2006 04:46 AM
