Old 09-29-2020, 05:08 PM   #1
2013 23' FB Flying Cloud
Burien , Washington
Recommendations to replace stolen hitch
We've had a EAZLift 600 lb hitch for our 23 FB and Touareg TDI for a couple of years and it worked fine. It was stolen and now we need to replace it. The 600 lb EAZLift kits are back-ordered for at least a month. My other options are a 1000 lb EAZLift or a 600 lb Equalizer for more than double the cost of the EAZLift.
Would appreciate input from folks here on best option for our RV & TV setup. Any concerns about using the stiffer 1000 lb EAZlift? Thanks!
SeaJim is offline   Reply With Quote
Old 09-29-2020, 06:15 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I would not want the stiffer bars. Are you planning a trip in the next month?
Old 09-29-2020, 06:19 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
The bars need have a capacity above what is need ,but not too much.
Ie 450lb tongue weight with 600 lb bars ok. 1000lb bars NO!
50% MORE THAN NEEDED MAX. Double is too stiff
Too little, you are looking for trouble.
As others have stated, too stiff is bad and may cause damage
waninae39 is offline   Reply With Quote
Old 09-29-2020, 08:34 PM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
How much is your loaded tongue weight+cargo weight in the back of the vehicle? I'll bet you will find that 650 is low and that 1000 lb bars may not be so far away from your actual load.
good luck!
Old 09-29-2020, 10:16 PM   #5
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Ez lift not nearly as effective as equalizer . Blue ox is second best to equalizer. Of course if you want true sway control, PRO PRIDE!
sheriff1 is offline   Reply With Quote
Old 09-29-2020, 10:34 PM   #6
Newport Beach , California
Call etrailer and the dealers and see what they recommend. And buy hitch and coupler locks.
reginac is offline   Reply With Quote
Old 09-30-2020, 10:26 AM   #7
2018 27' Globetrotter
Colts Neck , New Jersey
Replacement hitch
My suggestion is to call Andy at CamAm to both get a recommendation and buy it from them. They keep a lot on hand and are very fair.
megster is offline   Reply With Quote
Old 09-30-2020, 10:46 AM   #8
2013 27' FB International
mamaroneck , New York
Husky centerline
Pulled a 27 fb cross country three times with a husky centerline and our Touareg No issues - piston controlled anti sway. Great hitch.
jackanddiane is offline   Reply With Quote
Old 09-30-2020, 11:18 AM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
First, before you buy, determine your tongue weight. Published data is usually off by enough to make this worth while. Make sure you have water and propane full. maybe add a few crates of stuff in the front, like you would when you travel. My experience tells me that you will have a tongue weight approaching 600 to 700lbs. If this was my sole decision, then I would opt for a 1000lb equalizer system. In my experience it has the best balance of friction sway control and weight distribution. After initial setup, which is crucial, it will perform flawlessly. An if not, the company stands behind their product 100%. I own 2 of their hitches, and so far have been super happy with them. But again, key is determine your actual tongue weight. Don'
t go with published data. Then add the weight of your brackets and bars as well. Touaregs are super cool, but have short wheelbase and limited tongue weight allowance. Make sure you stay within the law.
Uwe
www.area63productions.com
Old 09-30-2020, 09:00 PM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Following
TouringDan is online now   Reply With Quote
Old 10-02-2020, 07:42 AM   #11
2019 25' International
Washington , Washington, D.C.
The problem with trying to use Andy at CanAm is that the U.S/Canadian border remains closed.
PatLee is offline   Reply With Quote
Old 10-02-2020, 08:05 AM   #12
2018 25' International
Slidell , Louisiana
For the Touareg and the 23' setup your Eaz Lift Elite was a very good choice. I would look harder for someone with the same setup in stock. Don't switch to an Equalizer as, though they work very well, they are too stiff for the trailer and too aggressive for the vehicle and will contribute to oversteer tendancy with the Touareg. If you can't find an Eaz lift get a Curt or Reese or other with similar design. Don't get the Eaz Lift Recurve, it is not a good match for a few reasons.
I have the Blue Ox, and it is not a good fit for you either. The Andersen would be good but it is incompatible with the Atwood 88xxx series coupler all Airstreams prior to 2019 have. It can be tweaked, I just did it and put the Andersen on to replace my Blue Ox so I can directly compare it, but most won't want to mess with the tweaks.
Brian
BayouBiker is online now   Reply With Quote
Old 10-03-2020, 01:20 PM   #13
Burien , Washington
Thanks to all for your information and suggestions! Following up on my original post. As it turns out, only the ball mount and the sway control bar were stolen - they were in a storage shed, not mounted on the TV. We got the 600 lb EAZlift setup originally based on conversations with CanAm, among others, and it worked well for us for 2 years.
Here's where we ended up. Since we still have the 600 lb bars, I got a 1000 lb kit and using the ball mount and sway control bar from it. We contacted several local dealers, CanAm and Dometic directly. Here's what we learned.
- Dealers generally only stock the EAZlift Elite kits, not individual parts. They were not sure whether the ball mount components were the same for the 600 lb and 1000 lb kits. We were finally able to confirm from Dometic and CanAm that both kits have the same ball mount components.
- The EAZlift 600 lb kits are back ordered at Dometic as they have had a huge increase in business this summer due to the surge in RV business from due to Covid
- Apparently there is also an increase in thefts of hitches and other RV gear
- CanAm does have a few 600 lb kits, but freight to Seattle is over $US200.
- Dometic customer support was very helpful, as was CanAm and High Sky RV Parts in Washington.
So we got a 1000 lb Elite kit locally, we're installing it with our 600 lb bars and we're rolling again. Thanks again to folks for taking time to respond. Anyone need a set of 1,000 lb bars ?
Old 10-04-2020, 10:50 AM   #14
1996 25' Excella
Tillsonburg , Ontario
The suggestion was for advice.... no border issues there and Andy would be pleased to discuss Iím sure
CanAm were selling Easylift when I replaced the ancient Hensley two years ago
JCW
JCWDCW is offline   Reply With Quote
Old 10-04-2020, 12:36 PM   #15
Burien , Washington
JCW
Absolutely! As I mentioned, CanAm has been a reliable source of information for us. They do carry and recommend EAZlift Elite for the RV/TV combination we have. They are the only place we could find the 600 lb kit in stock and they can readily ship to the US. The only rub is the $200 it would cost to ship to Seattle, but if we didn't have the 600 lb bars, I would have ordered the kit from them in a heartbeat. Highly recommend CanAm for their expertise and customer service.
Old 10-04-2020, 02:25 PM   #16
2010 19' Victorinox
Asheville , North Carolina
I am using the EazeLift 1000 for my Touareg TDI and 19ft bambi. So far I have really like it. Easy to install and not too stiff.
mbsprouse is offline   Reply With Quote
Old 10-04-2020, 05:46 PM   #17
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
I have 800 lb bars on my 20’. And CanAm set it up.
Native143 is offline   Reply With Quote
Old 10-04-2020, 06:57 PM   #18
Longwood , Florida
My 2014 Flying Cloud 20FB came with an Equalizer. Andy at CanAm suggested replacing it with the 800lb EAZ Lift Elite... said the Equalizer bars were very stiff and put were hard on the hitch and the A frame of the trailer... especially when on uneven pavement.
I called everywhere looking for the EAZ Lift Elite, because as mentioned above, they are on back order. Then a few popped up on Amazon for $290... it is being delivered tomorrow.
Good luck and safe towing!
RogerBart is offline   Reply With Quote
Old 10-04-2020, 09:27 PM   #19
2019 22' Sport
High River , Alberta
I acquired an Eazlift hitch with 1000 lb bars from CanAm when we had the old Overlander. Iím using the same equipment with the 22FB.
The 1000 lb bars work perfectly. They are tapered, so they donít achieve full tension right away. I have two links hanging.
Yes, higher rated bars will put more stress on the trailer, but probably not nearly as much as towing with a three quarter ton pickup.
AlbertF is offline   Reply With Quote
Old 10-04-2020, 09:36 PM   #20
Calgary , Alberta
What coupler do 2019's and later have? It's compatible with the Andersen WDH's?
qwertyd10n is offline   Reply With Quote
Generator stolen - what to replace with? Dan S Generators & Solar Power 14 10-03-2011 08:15 AM
Stolen Hitch Silver Threads Hitches, Couplers & Balls 51 07-29-2011 10:32 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
Hitch Stolen. . . GRRRRR The Flintstones Hitches, Couplers & Balls 65 09-07-2007 02:22 PM
Stolen Hitch - Replacement Suggestions? fastrob Hitches, Couplers & Balls 11 08-07-2006 11:40 PM
