Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 06-22-2015, 04:58 PM   #41
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I have a 2012 5.0 4wd with 3.55 gears and see just slightly lower mileage figures if I am running conservative speeds. Probably due to the 4wd. It's a really nice engine as well.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 06-23-2015, 10:38 PM   #42
cramar
1992 25' Excella
Leamington , Ontario
Originally Posted by slowmover View Post
Were the highway miles, solo & towing, covered at the same travel speed (on cruise control)?
I assume that this is addressed to me. When towing, it was 60 mph or under. When solo it was 70mph on highway. A better comparison would be solo at 60mph. I suspect the 22mpg would bump up a bit. But I did notice that instead of running in 5th while towing, if I let it run in 6th, I get a slight 3% improvement in mileage. But I would rather run with slightly more revs in 5th than in OD, which is used of course during non-towing.
Never used cruise control (CC) with either run. Unless on absolutely dead level ground, I can do better than any cruise control at reducing fuel consumption. That is because CC uses constant speed, which demands noticeably more fuel up a slight grade and reduces fuel going down. I tend to drive with constant throttle (i.e. constant fuel), which means I slow down slightly going up a grade and speed up going down, which gives me added momentum for going up the next hill. Also I can anticipate slowing down and try to coast as much as possible, which uses next to nothing in fuel.
Boomerstream One - Live Riveted!
Leamington, ON
Canada
cramar is offline   Reply With Quote
Old 06-24-2015, 08:24 AM   #43
Vintage Kin
Fort Worth , Texas
I realize folks "believe" they can beat CC, but at the end of a day, they don't. Among professional drivers it is contraindicated in large studies. Men motivated by significant bonuses. The CC is constant, drivers aren't.
I was beating CC more than forty years ago, and I know how much harder it is today with far more sophisticated drivetrains. But I'll contend the attention we pay to a dead-on speed is offset the wrong way towards our overall best practice.
The exception may be in rolling terrain under light load. And how aggressively CC software is done. And for a limited length of time.
But for both, the longer the drive, or with only slightly reduced attention, the machine will win.
"Repeatable results" is a better way of looking at an overall annual towing average (versus CC or not CC). And engine time versus trip length.
The worthwhile experiment about CC is to set the speed for CC use about 2-mph below the manual input speed for rolling terrain. The engine time will be close to the same for the trip. And the bonus is a more rested driver with more alertness to mirrors and potential problems at a distance. Try it.
Ok, so 35% fuel penalty change is beset by variables. If it turns out you're willing to make the A-B comparison of a similar truck load at same speed and use of CC, this would make for replicable results by other owners of the same truck once exact truck spec, climate and terrain are factored. If the drivers manual says to tow in a particular gear setting, then that applies as well.
RV forums are beset by threads of others wanting to know about a particular trucks fuel cost. But we have "answers" in posts that may as well be random numbers. Speed, load, etc, that are far different, truck spec, climate and terrain that are far different, right down to seemingly minor differences like the use of CC. A range that really isn't realistic for what a truck can do.
Among professional drivers, doing the exact same work in the exact same truck, the gap is just over 30%.
As I'll guess most will report economy over a small range of trips, and from 60-65/mph, the FE may not be so great a discrepancy as 30% between owners of similar rigs.
However, the real numbers are over the largest average number of miles. And over vehicle life. RVers seem to trade vehicles -- trailers or tow vehicles -- pretty rapidly (about six years on each), so results are also skewed towards "new". A higher cost per mile overall no matter the trip fuel economy.
An EB Ford, taking into account the above (lack of reporting protocol) can be made to look better than it is, or so could the EcD Dodge. Or worse.
As the drivers dashboard readout of fuel economy seems fairly accurate today, part of a solo highway trip on CC yet at towing speed (say 75-miles or so) could be offered to "see" what the towing penalty amounts to in an unbiased manner. Truck load is the variable.
Old 06-25-2015, 03:16 PM   #44
cramar
1992 25' Excella
But for both, the longer the drive, or with only slightly reduced attention, the machine will win."
"An EB Ford, taking into account the above (lack of reporting protocol) can be made to look better than it is, or so could the EcD Dodge. Or worse."
Actually since this is an EB Ford vs. ED Ram thread, I would strongly recommend a boost gauge for any turbo engine (assuming the above do not have them). If you drive by the boost gauge that is how you can find out you can do better than CC. I installed one on my chipped TDi. I noted that on level ground under CC, the engine was generating X amount of minimal boost. As soon as a slight grade was encountered, the gauge would rise as more fuel was demanded to hold the speed. The final boost reached of course depended on how long and how steep the grade. Sometimes it was dramatic. So turning off CC, I learned to try to keep a constant boost pressure by regulating the throttle. It generally worked real good and far superior to CC. By slightly accelerating when approaching a hill would minimally increase boost, and backing off throttle to keep it low when actually on the hill was real effective. You must learn to drive with a very sensitive foot.
But you are right, on level ground it is much less stressful to just flip on the CC and enjoy the ride. Which is why I generally use CC on any vehicle far more than the average person.
In non-turbo engines with instantaneous fuel readouts, this will do the same thing as the boost guage. But I find the F150's readout terrible compared to a true instantaneous reading on my wife's Honda or my former 14-year old Corvette.
Leamington, ON
Canada
Ford F150 3.5L Eco Boost Streamer1492 Tow Vehicles 601 05-19-2014 08:05 PM
2015 Ford Expedition with Eco-Boost Roadtech Tow Vehicles 16 02-24-2014 04:43 PM
Interesting read on the Eco-boost Denis4x4 Tow Vehicles 4 08-21-2011 11:58 AM
