Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-15-2017, 08:13 PM   #41
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
2016 Chevy High Country 2500 Duramax pulling a 2016 FC front bedroom, equal-I-zer hitch. Can open the tailgate even with the truck turned a bit.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel
WBCCI #9026 Delmarva Unit
jamieb1086 is offline   Reply With Quote
Old 07-15-2017, 10:51 PM   #42
Wconley's Avatar
2018 28' International
Renton , Washington
We have a 2013 F150 and 2013 23D. We couldn't until I loosened the three set screws on the jack head and rotate it 90degrees. Took me 5 minutes and now we can open our tailgate fully.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 07-16-2017, 05:37 AM   #43
2015 27' FB International
Wheatley , Ontario
Originally Posted by Mikenbern View Post
in a word.... NO
maybe with a propride or other longer shank hitch -- you may be able to have clearance....
i use an equalizer-- and I can not open the tailgate
x2...
lovetokite is offline   Reply With Quote
Old 07-16-2017, 05:51 AM   #44
2000 30' Excella
2014 30' Classic
Princeton , Iowa
One More
I have had 2 Pickups and 3 trailers and was unable to open end gate with any combination, but I can open the end gate fare enough to get to the stuff at the back of the bed. I put a rage between the end gate and the hitch. Works good.
larryglarson is offline   Reply With Quote
Old 07-16-2017, 06:35 AM   #45
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Many good solutions or observations offered here, the problem is many are specific to a particular situation, Rotating the motor on a jack can sometimes solve the problem but I couldn't do it with the Atwood jack on my trailer. I agree you want to keep the ball as close to the truck as possible to minimize leverage on the truck but some times extending the hitch slightly is an easy and acceptable solution. My equalizer hitch came with a 12 inch shank and as someone pointed out the next step up with equalizer was 18 inches and I didn't want to extend my hitch that far. I found a Reese shank on Amazon that was 14" and worked and only minimally extended my hitch.--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 07-16-2017, 06:48 AM   #46
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Ford F-150, Ezy-lift: Nope!
Heavy stuff I remove before hooking up.
Lighter stuff, out the open upper window.
MelGoddard is offline   Reply With Quote
Old 07-16-2017, 07:05 AM   #47
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The hitch experts at Can-Am Rv tell us even a very short extension of the hitch stinger results in an increased sway input to the vehicle's steering axle in actual handling tests. It is standard practice for them to drill a new hitch pin hole so the ball can be placed as close to the rear bumper as possible.
Doug and Cheryl
Old 07-16-2017, 08:00 AM   #48
Mollysdad's Avatar
Originally Posted by SeaLevel View Post
Yes, there are 3 holes in the frame where it gets mounted, but on my jack at least, there are extra holes provided so that you can turn it 90 degrees sideways. It's designed that way so that you can turn it if required to clear the tailgate.
Ahhh, I see. Thanks.
Are they talking about buying another shank that's longer or using an extension to the existing receiver? I don't see how drilling another hole is any different than buying a longer shank.
I looked at the standard Equal-i-zer shank and the hole is only about four inches from the front. I can't see drilling another hole even closer to the front. I think a slightly longer shank is the answer, like 14".
Not scientific, but it seems most folks who's tailgates opened had 250's or 350's, while those of us with half ton's had more problems. Maybe the tailgates are shorter on larger trucks? Or the bumpers/receivers on larger trucks are farther back.
Old 07-16-2017, 08:18 AM   #49
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
I never noticed that. I'm gonna take a look. Thank you.
TravlinMan is offline   Reply With Quote
Old 07-16-2017, 08:21 AM   #50
2017 30' International
Lincolnwood , Illinois
Equalizer setup and so long as my tt tv are straight just clears. so yes I can
Milo1952 is offline   Reply With Quote
Old 07-16-2017, 08:24 AM   #51
dkottum's Avatar
Sorry I was not clear. They drill the existing stinger to move the ball as close to the bumper as possible for best possible handling and sway control. Has nothing to do with trying to fix the tail gate problem.
Doug and Cheryl
Old 07-16-2017, 09:38 AM   #52
Pat Cassity's Avatar
Montgomery , Texas
No problem at all opening the tailgate on my 2015 GMC Sierra. Using a Blue Ox hitch.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 07-16-2017, 10:32 AM   #53
2005 31' Classic
Gretna , Nebraska
Blue Ox works fine on GMC 2500HD and 31' Classic.
16595 is offline   Reply With Quote
Old 07-16-2017, 10:35 AM   #54
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The heart of the hitch / sway debate is the distance from the ball to the rear axle. Pushing that out by something like 4" is not a good idea for sway. That's about 10% of the typical ball to axle distance. Getting 4" back by drilling another hole sounds like a pretty cute idea. Sure would not help the tailgate issue any though.
In my case, I'd guess that another 2" would (barely) let the tailgate clear the power jack motor housing.
Old 07-16-2017, 10:41 AM   #55
Traveler
TravlinMan's Avatar
Staunton , Virginia
For me, it's a matter of a couple centimeters. Rotating the jack would certainly do it.
Old 07-16-2017, 11:13 AM   #56
'Andy' drilled a closer hole for me, (ball closer to bumper.)
I noticed the difference for sure.
Old 07-16-2017, 03:14 PM   #57
2015 30' Classic
Saint Augustine , Florida
Ford 2015, F 250, Propride, 2015 classic 30
No problem opening and......yes bruised shins from the stinger !
accordionman is offline   Reply With Quote
Old 07-16-2017, 03:15 PM   #58
Me? I would 'leave it lay where Jesus flang it'
Old 07-16-2017, 03:26 PM   #59
JimGolden's Avatar
1977 31' Excella 500
Yes. Ram 2500 with Equal-I-Zer 15,000/1500 hitch and Avion 34X. No problems....
- Jim
JimGolden is offline   Reply With Quote
Old 07-16-2017, 08:09 PM   #60
2014 19' International
Port Townsend , Washington
No...with a 2015 F-150 Blue Ox and a 19' Bambi??? But now I need to check out how much space I need and see about incorporating one of the sides, like rotating the jack. It is a pain to get stiff out of the rear of the bed when the trailer is hooked up.
LBelle is offline   Reply With Quote
Ford F-1/F-100 Vintage Pickups for Towing a 1952 Flying Cloud chopperusa Tow Vehicles 6 02-17-2014 05:26 PM
LNG/Gas Pickups Denis4x4 Tow Vehicles 12 05-08-2012 05:35 PM
Chrysler recalls 242,000 Ram pickups from 2008-2011 JFScheck Tow Vehicles 0 07-13-2011 01:35 PM
Four big pickups get low marks in crash tests Airslide Tow Vehicles 54 02-19-2009 11:49 AM
GM recalling 155k Vans, Pickups and SUVs Silvertwinkie Off Topic Forum 0 02-10-2005 11:43 AM
