Old 04-06-2021, 03:14 PM   #1
2020 23' Globetrotter
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
ProPride hitch and Fordís Backup Assist
I finally got it dialed in, and it works. The basics are in the below, but not quite.
https://app.hubspot.com/documents/22...ccessId=c2c22d
It makes a vague reference to all other measurements have to consider the trick on modifying the actual distance from license plate to Ďhitch ballí (which you donít have as a pivot point on a PP3). Wish it was more clear. I went on on measuring and adjusting the actual readings on the measuring tape with plus and minus the difference between the actual distance as measured against the 16 inches the author indicates should work. Wrote down, tried, crossed out, wrote down again, repeat, till it works, but I donít know what are the final numbers I actually inputted into Backup Assist, no idea how to recover them from the carís screen either, so sorry canít be of much help, but I made it work, it can be done and is great.
Anyone with a better explanation of the process, please provide it. It is a great tool.
GT 23 2021, F150 Platinum 2020 (2021 on order)- 2017 Audi A7S - 2020 LR Defender 110 HSE
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO. GT 27 2021 on order
ďShips are safe at harbor, but they are made to cross oceansĒ
Vitaver is offline   Reply With Quote
Will Ford's "Trailer Backup Assist" work with a Hensley Hitch wilsodf Hitches, Couplers & Balls 3 02-23-2020 08:52 AM
Trouble with Ford's Pro Trailer Backup Assist setup with a ProPride hitch DaytonaDan Hitches, Couplers & Balls 30 05-29-2018 06:09 AM
Using Ford's Pro Trailer Backup Assist with a ProPride Hitch DaytonaDan Hitches, Couplers & Balls 1 04-11-2018 11:23 PM
Ford's Pro Trailer Backup Assist BW1 Tow Vehicles 10 09-17-2017 06:43 AM
