I tow our 2019 international with a 2017 F-150 Supercrew. My hitch is a Reese dual cam WD/anti-sway system. I have towed about 7500 miles over the past two years with this setup and am generally happy with the performance. I have never had a "back and forth sway" under any conditions. What I do feel when passed by a truck is an abrupt lateral shift followed by the normal "suck and push" as the truck passes. I pay attention and make the normal corrective steering measures.
In trying to find the source of the "abrupt lateral shift", I placed three 0.030" spacers in the trucks receiver to eliminate most of the 0.100" left to right slop between the hitch shank and the receiver opening. This did not eliminate the " abrupt lateral shift" experienced when passed by a truck.
Two other possible causes of the abrupt lateral shiftcome to mind:
1) Is it possible that this type of anti-sway hitch requires a certain amount of motion to react to the side force on the Airstream? In other words this is what you get.
2) Is it possible that the sidewalls of the truck tires (from Ford) have low enough stiffness to Produce the "abrupt lateral shift" that I feel?
Will a ProPride hitch elinimate the "abrupt lateral shift"?
I have read everyone's opinion on this topic. They are varied and insightful. I wish there was a standardized test that could applied to objectively rate each hitches reaction to the "disturbances" seen while towing.
On a side note: We taking delivery of a 2022 F-250 SuperCab with 8 foot box next week! Got tired of running into the cargo limits with our current F-150. I plan on seeing how my existing SOB hitch handles with the new truck. To get rid of the abrupt lateral shift I would consider a new hitch.
First post! - let's see how this works.
