Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 05-20-2013, 06:51 PM   #1
1969 27' Overlander
St. Louis , Missouri
Pro series hitch?
Towing a 1969 27' Overlander with f250 power stroke. I have original reese trunnion bars but no hitch. by the time I buy what I need I'm spending some decent coin on an old system I'm unsure of. Thinking about purchasing this setup, looking for thoughts, comment, concerns!
Pro Series Weight Distribution System w/ Friction Sway Control - Round - 10,000 lbs GTW, 750 lbs TW Pro Series Weight Distribution PS49902
Noco is offline   Reply With Quote
Old 05-20-2013, 06:58 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Take a look at this before you do.
http://www.airforums.com/forums/f464...ead-92131.html
2004 Excursion 4x4
Old 05-20-2013, 07:21 PM   #3
1969 27' Overlander
Good video, is it that effective and worth the dough?
Old 05-20-2013, 07:37 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
No. I used it 4,000 miles and removed it because of several safety concerns that became apparent. Read on.
doug k
Old 05-20-2013, 08:27 PM   #5
HowieE's Avatar
Images: 12
As you read on keep a count of those that are using this hitch and those that have some other agenda.
For your set up you will be hard pressed to equal the performance.
2004 Excursion 4x4
