Old 05-02-2021, 07:21 AM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Possible bumper drag
I’m reading posts where dragging the bumper is discussed. We haven’t had a chance to do any BLM boon docking, though have driven through some uneven Harvest Host fields. I do a pretty good job reading terrain and seeing potential hazards. We visited a campground in Palm Springs which had a drainage area formed into the paved surface which could not be avoided. It ran the entire width of the road with deep grooves on one side. I didn’t have an issue with the 25’ though it was really close. We recently traded our 25’ for a 30’. As far as I can tell, it looks like all 5 feet were added behind the wheels. I can guarantee I would have scraped the bumper with the 30 Bunk.
How common is this?
It the only solution adding a lift? If so, does it effect the ride?
Should I even be concerned about this?
Have you scraped your bumper and not had any damage?
s1000pre is offline   Reply With Quote
Old 05-02-2021, 07:34 AM   #2
2018 30' International
Southern Pines , North Carolina
I have a 2018 30’... Off road the bumper isn’t the only worry — it is the sheet metal enclosure for the tanks just above and behind behind the axles. That can be the low point in the right dip. Haven’t done it yet but a lift kit is in my future...
Disconnect your weight transfer hitch (if possible) prior to entering the campground. On most rigs this will drop the hitch an inch or more and that gains you an inch or two clearance in the back of the trailer.
I have air bags on my truck and between deflating the bags and removing the weight bars it helps with clearance. Some folks will even set up the hitch to have a 30’ trailer be slightly nose low to add rear ground clearance. But that is another can of worms.
NC-Serenity is offline   Reply With Quote
Old 05-02-2021, 09:01 AM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
I believe the consensus is that the lift kit has been a blessing. Have not heard any regrets. After bending one of the skid plates on the back of my trailer coming out of a busy parking lot, I decided to add the lifts. They have helped when on dirt back roads and when parking on a slope...no more digging a hole to lower the pro-pride hitch far enough to level the trailer!
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 05-02-2021, 09:26 AM   #4
s1000pre's Avatar
Which lift kit did you go with?
Old 05-02-2021, 01:14 PM   #5
Lost in America
mojo's Avatar
You have to determine which Dexter axles you have and then order the proper lift kit. Got mine from etrailer.com
2017
Old 05-02-2021, 01:24 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Dexter Lift Kit.
There is only one kit that fits your 30' trailer - dexter 2 7/8" kit #K71-724-02 for #11 axles.
There are no downsides. Tows the same. More clearance. Frankly, 30' trailers should come standard from the factory with these axles blocks installed. Many of us have them installed. Cost for installation with parts runs between ~$850 and ~$1500 depending on who does it for you.
Some people tackle this themselves. On the 30' getting at the bolts in behind water tanks requires welding tabs to the bolts as it's very difficult tog get a wrench back in there. GMFL on the forum sells the modified bolts for DIYers.
I still cringe on those parking lot dips. Difference now with a lift is that I still come close but don't drag
wulfraat is online now   Reply With Quote
Old 05-02-2021, 01:41 PM   #7
jaybauman's Avatar
2021 33FB Classic
2019 30' Flying Cloud
Katy , Texas
Previously with my 30Bunk, and now with my Classic 33, a lift kit should be considered a necessity. On any trip gas stations, grocery stores, and Starbucks are required stops and maps never show how much incline you may have to negotiate.
Problem solved when I installed a lift on the bunkhouse. I'm taking the Classic in on the 15th to have it lifted before summer travels begin.
Do it and don't look back.
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
jaybauman is offline   Reply With Quote
Old 05-02-2021, 02:18 PM   #8
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
I agree with the above posts. I called Dexter with my axle serial #s to confirm the #11s. I had my lift done yesterday by @GMFL Went easy & no issues. As long as the 30 & especially the 33ís are, I think this is a necessity; regardless if youíre boondocking or not. Well worth the money when considering risk vs reward.
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Drag wheels instead of steel drag bars under bumper? Ron cencal Bumpers & Bumper Storage 17 09-19-2020 07:32 AM
Bumper Drag is a drag LilPeanut Repairing/Replacing Floor &/or Frame 21 08-24-2020 10:04 AM
Bumper DRAG and BEND: OTJ Repair Ray Eklund Bumpers & Bumper Storage 27 06-08-2020 06:51 PM
Dexter Lift Kit... Eliminates Rear Bumper Drag, too? Ray Eklund Boondocking 24 10-03-2018 09:31 AM
Can you guess which rally had Airstream "drag racing?" yukionna WBCCI Rallies & Events 9 08-27-2003 07:42 PM
