Old 10-17-2021, 02:08 PM   #1
gsj
2018 23' Flying Cloud
Parkit360 Won’t Move over Grass
We have a Flying Cloud 23 and we purchased the Parkit360 10K to move it across from our grassy front yard to the backyard (which is gravel).
We need it to move backwards through the side of the house and the Parkit360 won’t simply do it. When we try to back it up the tires rotate in place and start digging a hole on our grass/ lawn.
We tried using wood planks and concrete pavers to create some traction, but nothing worked. It just moved a few inches and stopped.
Battery was fully charged.
Any idea what we could be doing wrong?
gsj is offline   Reply With Quote
Old 10-17-2021, 02:12 PM   #2
dznf0g's Avatar
Oswego , Illinois
There were a couple of different tire tread patterns available when my brother in law bought his. He got the aggressive farm tractor tread and has no problems. They also had a "turf tire", which is pretty smooth.
-Rich-
Old 10-17-2021, 08:56 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I’d try laying down some plywood for the park it wheels to roll on perhaps. I’d also remove the batteries and propane tanks to lighten the load on the park it.
wulfraat is offline   Reply With Quote
Old 10-19-2021, 06:08 AM   #4
gsj
We got it!
We got it! We managed to move it!!! 💃🏼Putting more weight on the tongue and maneuvering to get out of the hole we were in did the trick. We then got stuck at another hole and used a plank to move out of it. Once we got to our gravel path everything went very smoothly.
Parkit360 recommended changing to 6.5” tires and in the meantime deflating them a bit. It seemed to work.
Thanks for all your suggestions!!!
Old 10-19-2021, 06:33 AM   #5
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
Good to hear.
Learning and enjoying as we go !
Saluda372 is offline   Reply With Quote
Old 10-19-2021, 06:48 AM   #6
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
If possible, dump water, empty holding tank(s). If you pull the propane and batts, you will reduce your hitch weight which may or may not be helpful.
Unrelated, I had a high capacity P360XL and it literally tore itself apart. I overbought the capacity at the time thinking I would upgrade. I think it had a rating of around 12k. I didn't even withstand 7500lbs before the hitch ball mounting point totally ripped apart from the frame of the power dolly.
I bit the bullet and bought a 15k Airtug and it pulls the trailer like it's barely even there. Great traction and FAR less wrestling with movement. When your parkit eventually fails, seriously consider the Airtug....far, far, far fewer problems...but it's not inexpensive, esp if you already flipped for the Parkit first.
panamerican is offline   Reply With Quote
Parkit360 / Electric dolly for tight spaces? Jimbob24 Hitches, Couplers & Balls 45 08-31-2020 08:24 AM
Parkit360 Trailer Dollies dhroberts Towing, Tow Vehicles & Hitches 12 08-28-2018 08:04 AM
Parkit360 dolly with ProPride 3P hitch dhroberts Hitches, Couplers & Balls 3 05-09-2018 09:22 AM
Parkit360 10,000 lbs electric trailer dolly for sale Gamehawkers Airstream Classifieds 0 03-15-2018 09:05 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
