11-03-2003, 05:04 PM
Newbie Towing AS Needs Assistance
I'm new to owning an AS and new to towing anything this big. I've read most of the posts and even more confused than I was before.
BASICS: 2002 F150 5.4 V8, Limited Slip (8600# tow cap)
2003 International CCD
Based on my truck specs I know I can tow my AS. What confuses me is all these types of hitches, connectors, anti-sway things and the like.
What do I really need to get started?
Any help is appreciated.
Jeff
11-03-2003, 05:22 PM
2005 28' International CCD
Pagosa Springs
hitches
You can do a search on the topic and pull up alot. I'd also hit the websites for the Reese Hitch products and Hensley Arrow. They both have generic background info as well as details on their product. Basically you need the right hitch and ball assembly to move anything and weight of trailer/tow vehicle influence that decision. Next decision is if you want/need weight distribution bars to help take some of the weight off of the hitch/ball itself. Next decision to make is if you want/need an anti sway "accessory" to go with the setup to help prevent the trailer from fishtailing around in certain situations. I have the Reese hitch with equalizer bars and the dual cam anti sway bars. There are less expensive and more expensive setups. I'm happy with this one. Good luck.
11-03-2003, 05:33 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Jeff,
You will defintely need a WDH and a brake controller. I am using the Equalizer brand WDH, Reese Straight Line is a good hitch too. The Hensley's are great hitches I would have one if I had a brand new AS and was full timing. But they cost more the my AS did I use the Prodigy brake controler. It is a big improvement over the cheaper units. A lot of the guys swear by the Jordan. Never used one so I don't know. I do know that the Prodigy is a great unit for the money. I use it on 3 different trucks with 5 different trailers. And the Prodgiy is plug-n-play on the Fords. As far as sway control... that is a personal choice, I use it on my AS and popup, but not on my cargo or equipment trailers. At the moment (NO FLAMES PLEASE ) I am towing my 31' with a F-150 4.6 with factory tow package. It can handle it, but...I could and will be doing an upgrade soon.
Aaron
11-04-2003, 07:51 AM
wahoonc
What type of grease do you use with your hitch? I was thinking of using stp oil additive or is that to slippery?
11-04-2003, 10:54 AM
Not a lubrication engineer but think the stp would not be up to the task. I use extreme pressure machine lubricant , wifes employer moved to Miss. several years ago and was not shipping the grease , open tubes subject to different shipping? little goes along way. When that runs out going to use synthetic amsoil.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch.
Pulled by a 2019 F350 Superduty Limited.
11-04-2003, 11:29 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Originally posted by Gene Wissink
wahoonc
Gene,
I just use good old axle grease what ever comes to hand down on the farm . With my smaller trailers I used to just use a piece of wax paper doubled over a couple of times, alot cleaner than the grease. A little grease will go a long way. Also as part of my yearly maintenance I will completely clean out the hitch on the trailer and the ball and start over, helps get the road grit out of it.
Aaron
11-28-2003, 10:13 AM
1954 22' Safari
Deerfield
Brand new at this, really confused, and looking for answers...
I'll be picking up my '63 Globe Trotter in a couple weeks. Not sure of my tow vehicle, but it'll be either a late model Tahoe or Blazer.
I'm towing from Washington state to Illinois, and want to make it as cheap and quick as possible. We're getting new tires and greasing the axle, but my question is:
Do I HAVE to have a hitch equalizer, sway bars, hitch height accumulator, grease tube applicator, drag coefficient calculator... and all that other fancy stuff?
Or can I survive for now with just the stock GMC hitch receivers that came on the Chevys and a 2" ball from the local NAPA? I don't want to die in a fiery wreck just getting it home, but it's going to be a good 2 years until this aluminum heap is restored enough to use!
Any help is appreciated!
11-28-2003, 01:16 PM
Tonka Bay
Big Difference Between Tahoe and Blazer
Brad,
I've towed an Airstream a grand total of 6 miles so am not an authority. However, I do know the difference between Blazers and Tahoes. Go with the Tahoe. The newer Chevy Trailblazers top out at 6300 lbs if you have the best setup. The older Blazers tow probably 5000 lbs at best. Tahoes in any configuration should top these numbers. In theory I can tow my 4300 lbs dry weight Airstream with my Trailblazer (6200 lbs) but 6 miles never over 50 mph convinced me otherwise and I had all those bells and whistles hooked up except the electric brakes.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
11-28-2003, 01:57 PM
1978 25' Tradewind
Metro Phoenix
Brad, I tow my 78 Tradewind with a Tahoe, and it seems to be fine. Of course, I always want more power, whatever I drive (More power! Uhh! Uhh!!), but in terms of stability and sway, it rides like a dream, even with abrupt-to-the-point-of-being-stupid lane changes.
I've got the Prodigy brake controller, which seems to be fine, although I've never used anything else, so how would I know? If you get the controller from www.rjays.com, not only are they cheap but they have plug and play cables to hook them into your Chevy (assuming that it has the factory tow package).
I have a Reese dual cam hitch, which I recommend.
Remember, whatever you have now for a hitch will be glad to wait two years in the basement while you get the trailer fixed. If you cheap out now on the hitch, not only will you be biting your fingernails all the way home, but you'll have to buy another decent one two years from now.
-Don
11-28-2003, 03:22 PM
Newbie towing
Congratulations on what sounds like a wonderful purchase.
According to the 1963 literature, a 19' Globetrotter (2770#) could be towed by the "larger compact cars".
Now the larger compact cars circa 1963 were a lot larger than todays compact cars, especially if you get one from Hurtz or Ayviz, but I think you would do just fine with any full frame vehicle.
Be sure you get the brakes hooked up and working, but I think the weight distributing hitch, airspeed indicators, inclinometers and remote tire inflation monitors are too much at this point.
What if you decide in two years you need to upgrade, and all the hitch equipment you buy now is too small?
11-28-2003, 03:41 PM
1954 22' Safari
Deerfield
Three different but all valuable opinions!
I'm leaning towards the Tahoe (though mom leased it and the prospect of adding 4000 miles to the odo isn't pleasant) based on what you said about weight, Davydd, but don't you think I'm safe with either since the '64 literature says mine weighs 2700 lbs?
Drboyd, I like your idea of getting a brake controller and stuff now rather than put it off... I'll mull that over. It's true, I don't want to be so nervous the whole way home that it's not any fun.
I guess in the end if what you say is also true, Markdoane, I may give my wallet a break and see how she behaves with nothing but what Jackson Center gave her to begin with. I will ask that the brakes are double-checked before I arrive, and I've already bought some temporary brake lights to get it home.
I appreciate these responses, you guys. What a phenomenal resource you all are!
11-28-2003, 04:00 PM
St. Cloud
Don "drboyd" could edit this but let me get it up right away. There's an extra comma in that link. It should be www.rjays.com . I've seen RJays recommended before, so good call Don.
11-28-2003, 06:35 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Brad!
Welcome to the Forums and the world of Vintage Airstream ownership!
You are embarking on a rather long expedition at a time of the year when the weather can be uncertain at best. You will not regret having a properly adjusted weight distributing hitch even with a Globetrotter (you will want to avoid potential rear end damage that might result from towing with a "nose high" hitch that increases the likelihood of dragging the rear of the trailer on driveway dips and possibly even when crossing railroad tracks), and functioning brakes will be equally necessary.
My '78 Minuet 6.0 Metre is approximately the same size and weight as your Globetrotter (20' and 3,100 pounds fully loaded for vacation), and I wouldn't think of towing it the distance you are facing without my Reese Straight Line hitch that includes the Dual Cam Sway Control (for me this is true whether my tow vehicle is the '75 Cadillac or the '99 K2500 Suburban) - - it is the 500 pound version and it works very well with my Minuet. I only towed my Minuet once with just a weight carrying hitch behind the Suburban - - I knew it was there as there was a shimmy constantly evident as the weight carrying hitch was too high making for unstable towing (I was very glad to get it home on its first voyage of 200 miles and it didn't move until I had a proper deep drop draw bar and Reese Dual Cams). You will likely find that you will need a deep drop ball mount just to get the trailer level for towing (this has been true for both my K1500 Chevrolet club cab pickup as well as my K2500 Suburban so it will also likely be true for your Tahoe) - - so the additional cost for a proper weight distributing hitch shouldn't be extremely great
The only part of the hitch that wouldn't be the same for your Globetrotter as for a larger Airstream (under 31') would be the weight distributing bars and possibly the hitch ball - - the balance of the components are for all intents and purposes identical. The one thing to keep in mind when purchasing the hitch ball is that all 2" hitch balls are not equally rated. It can be somewhat difficult to find a 2" hitch ball with the 6,000 pound rating - - it isn't something that usually can be found at the discount retailers - - I usually purchase mine at either the Airstream dealership or from a shop that specializes in trailer repairs.
Good luck with your Globetrotter!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
11-28-2003, 06:36 PM
Retired.
, At Large
Re: Newbie Towing AS Needs Assistance
Jeff
Jeff, it kind of looks like the thread took off and left you...
Anyway, you HAVE to have a class IV or V hitch setup, a head for that setup with what should be a 2 5/16" ball, electrical plug compatible with the trailer, and a quality brake controller.
You SHOULD HAVE also a weight distributing hitch, and a transmission cooler.
It WOULD BE NICE if you had a decent anti-sway device, and towing mirrors, so you can see the guy you just cut off...
As far as what brands, that is a matter of budget and personal preference, although I have learned you usually get what you pay for, and the more expensive something is, tends to be better quality and functions better.
11-28-2003, 07:24 PM
Contributing Member
Austin (Hays County)
Jeff
I just sold my 2003 International AS after towing it roughly 8000 miles with a Silverado 1500. The AS is slightly heavier unloaded than the CCD but with the same configuration and gross weight.
I used a DrawTite hitch with 550# bars and it was about pefect. You don't want 1000# bars, they are too stiff for the tongue weight. 550# bars worked fine, 750# bars would be OK.
I used a Reese friction bar and never needed anything more for sway control. The trailer is inherently well balanced. I towed through a storm with 75 mph gusts and had no problem although construction signs and branches were being blown across the highway. A couple of times, I forgot to put the sway bar on and never noticed the difference. It was more belt and suspenders than required.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
11-29-2003, 08:02 AM
1959 22' Caravanner
Atlanta
, Georgia
Get a hitch and sway control. Single axle trailers are much more prone to sway then tandem axle.
We had to tow our 59 home 30 miles. I will NEVER tow that trailer again without WDH and sway control. It was one of the scariest times I have ever had. It was not safe.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
11-29-2003, 08:49 AM
Brad,
This forum and thread have tons of good advice for you. I too
was new to towing last year. I spent hours searching for info and still felt confused and unsure. The most important thing I did (IMHO) was to buy a Tahoe. I bought it especially for the trailer and of course it was a big investment. I would not want to tow even my '17 ft. Caravel with anything less. Since you have it use it!
I also have a Prodigy brake controller and a Reese friction sway control. This was not very expensive and works beautifully. I took a 3000 mile trip involving mountains-no problem. If you have the Tahoe you probably dont need the equalizing hitch for a Globetrotter especially if money is an object. Sway control is pretty important. If you get to experience sway you wont like it.
I would not tow with anything less than the setup I have but I feel like I dont need anything more.
Good Luck,
Heidi
11-29-2003, 09:27 AM
Tonka Bay
Temporary Tow Vehicle?
Brad,
If you are talking about a one time tow with a Blazer it probably would do the job. If you are talking about a permanent tow vehicle for your vintage Globetrotter then you might want to reconsider. A Blazer is smaller than a Trailblazer and a Trailblazer is smaller than a Tahoe. Trailblazers are somewhat designed to be tow vehicles but I now have my doubts and will probably trade in for an Avalanche next year. I never thought Blazers were designed to tow much more than a small boat despite what weight capacities they claim.
If you are talking about a temporary or borrowed tow vehicle you have an advantage. You will know a lot more about what you will need and want afterwards without regrets. If you are like me and stuck with what you got then you may end up feeling the way I do. I traded in my Silverado pickup two years ago and never anticipated owning an Airstream.
Davydd
12-01-2003, 12:00 PM
1954 22' Safari
Deerfield
Hello again to all-
Spent several hours in the last few days looking into this some more. I'm finally beginning to get clear on it (well, clearer, anyhow.) I'm going to take mom-in-law's 2004 Tahoe with factory hitch receiver.
So what I'm left to purchase is... everything inbetween.
I've kind of landed on either Reese or Draw-Tite hitches for my setup.
It seems I can't get on the road without spending over $400, but such is life.
Again, this is for a '63 Globetrotter (390 lbs. tongue)
- 750-800 lbs. rated, weight distribution bars - Draw-Tite: $250
- Anti-sway bars - Draw-Tite: $97
- adjustable height shank - Draw-Tite: $95
- and a 2" ball - dunno, 20 bucks or so.
That's $450, and it's about the same for the Reese Strait-Line, which combines the WD and anti-sway in one package.
So, unless someone can give me a safe, less expensive alternative (used?? I'd do it!) this is what I'll be getting in the next day or so.
Thanks all, see you online.
12-01-2003, 12:08 PM
Just a member
1978 28' Argosy 28
Lutz
I got this off www.hitchtrader.com
Used REESE weight distributing package--complete w/head, ball, snap ups, bars, etc. $49! Many other used hitch parts & packages--call for additional information. Moving locations this winter--sale prices on all used hitch equipment! www.acefogdallrv.com
800-747-0747
Many forum members as well as myself have done business with them and cannot praise them high enough. It may be a bit out of your way, but if you tell them what you need I am sure they could ship it to you. If you call tell Christy we all said HI.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
