Originally Posted by ROBERT CROSS
"THEY SAID"...did you eye-ball & confirm?
Did they drop the oil pan...call you in to the shop and point out the.."metal was all through out the engine".
I would first confirm the diagnosis. Low OP does not always equal metal particles. No pressure on a running engine could very well be a faulty pressure sender.
Having some experience in GM service, that R&R 'repair' will be much more expensive at a dealer.
What he said.
Also, I just replaced my Ford 6.8 V-10 with a Ford Reman. and had it installed by a local Christian Brothers Automotive. It was about 25% lower in total cost than your quote.
I would consider a different vehicle, but you should get very familiar with the pros and cons of each vehicle. For instance in my “Ford Excursion World” the king of engines was the 7.3 Diesel from 2000 through 2003. In 2004 the 6.0 Diesel was introduced and was plagued with problems.
Good luck in your research and decision.
