Old 04-26-2020, 05:19 PM   #1
2019 30' International
Kanata , Ontario
Need help for mounting hitch
I use an Eaz-Lift hitch with 1000 pound bars. Hitch head very heavy and I am just recovering from operation so have restrictions on what I can lift. Problem is mounting the head to the car requires one to bend at waist to insert stem. I recall seeing a couple of items that may be helpful. One was a 'handle' type affair that allows you to transport and insert head while standing straight. The other was some kind of cart to transport the head. Didn't need it at the time but now I do!! Any suggestions that would reduce the amount of weight I need to lift welcome so that once these restrictions are over we can get back on the road.
Scotsman1963 is offline   Reply With Quote
Old 04-26-2020, 05:39 PM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I use the hitch grip.
https://www.google.ca/search?q=hitch...Ny463JaA3V8GM:
I also had a short piece of receiver welded to the trailer a-frame where I store the hitch.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-26-2020, 07:00 PM   #3
2018 25' International
Slidell , Louisiana
I use the Hitch Grip also. I like it a lot, makes it much easier to handle the heavy hitch.
Brian
BayouBiker is online now   Reply With Quote
Need help/solution for stripped cabinet mounting screw..pls 05ModPod Cabinets, Counter Tops & Furnishings 10 07-10-2019 01:00 PM
Need help with toilet mounting modarch Sinks, Showers & Toilets 5 07-15-2011 08:14 PM
Need mounting info for Onan 6.5 in a 310 bkahler Mechanics Corner - Engines, Transmission & More... 7 10-28-2010 10:08 AM
"Have dish, will travel"? Need your input on a simple mounting for satellite antenna Aage Audio, Video & TV 13 10-30-2009 08:34 PM
Need help mounting my new ALUMINUM LP tanks sequoiacoast LP Gas, Piping, Tanks & Regulators 44 03-21-2007 09:28 PM
