Old 04-13-2021, 05:24 PM   #1
ShawnSk's Avatar
2021 20' Bambi
FREDERICKSBURG , VA
My truck and trailer tow weights
I see alot of people towing with mid-size trucks, crossovers, etc lately with bigger and bigger rigs. I have a 5.3L silverado 1500 with a 20ft Bambi which I don't think is a large trailer and I am only a couple hundred pounds under my payload, the numbers are attached below. I think everyone should do the calculations just to see where they sit. It may feel fine when you tow but in case of an accident I don't want some forensic accident investigator to ask why I was towing over my limits.
ShawnSk is offline   Reply With Quote
Old 04-13-2021, 06:30 PM   #2
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I like using a calculator also. I made my own based on my individual trailer, cargo, and equipment. It’s Microsoft Excel based and I can customize it for each load and/or trip. It’s important to know your weights and your limits.
FYI - I pull a 23 FB with a GMC Sierra 1500. It’s very doable, but I have to be careful with what and how I pack.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 04-13-2021, 08:59 PM   #3
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
I’ve got a similar setup to yours: my 20’ is a little older than yours, is a Flying Cloud, but my 5.3 Sierra is rated to 9800lbs... on our very first trip ever, our first stop was at the nearest CAT scale, verified that all was well. I know there are folks out there towing these with Highlanders and 4Runners, but I’ll admit as much as I liked my 4Runner, I had to trade it for the Sierra, just couldn’t trust it w/o having enough factor-of-safety capacity over the bare minimum.
-Leslie
LNBright is offline   Reply With Quote
Old 04-13-2021, 09:56 PM   #4
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
If you are using a weight distribution hitch you will find that your truck payload capacity will increase depending on the trailer GVWR and the Truck GVWR and GCWR. In any event your axle F/R GAWR will be your limiting factor.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 04-14-2021, 05:20 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Are the numbers on your chart real scale or from the book figures?
I would...go to the CAT with a loaded for camping rig, you'll know the real weights and be able to set the weight distribution properly.👍
Sweet Streams
ID:	393179   Click image for larger version
ID:	393181   Click image for larger version
Obrigado, hora de descansar.
Tahawus
Old 04-14-2021, 07:47 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
One pass through the CAT scales tells you a whole lot. Takes just seconds and costs about $12 Best bargain around for real knowledge of your weights. Personally I think most people have done that. Knowing that I am well covered in all weight areas is a good feeling.
Old 04-14-2021, 09:49 AM   #7
1964 30' Sovereign
Ione , CA
You're fine. Good truck for that trailer...especially with a weight distributing hitch.
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 04-14-2021, 10:24 AM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The biggest issue for safety is stability. Unfortunately, that has zip to do with the numbers on this or that sticker. Equally unfortunate is the fact that it can be quite difficult to spot a marginal stability situation. There's a lot of "that's just how it is" handwaving that goes on.
Wind blows the wrong way on a downhill curve at this or that speed and marginal turns into major. Net result is a lot of damage and possibly worse than that.
Focusing to much on the numbers, can easily distract from the bigger picture. In order to change the stability, you may well need to adjust the loading ( and / or ) WD. If everything is right at max when you start, you have no way to adjust anything. You are stuck in a dangerous situation.
Best to target limits around 80% of max. Then you have room to adjust things ....
Old 04-15-2021, 05:41 AM   #9
Good...is only good if hitched, loaded and driven safely within it's margins.
Tahawus
Share Your Real World Tongue Weights & Trailer Weights BoldAdventure Towing, Tow Vehicles & Hitches 184 07-28-2020 03:15 PM
Tow Vehicle Weights calculations spreadsheet mixedpuppy Towing, Tow Vehicles & Hitches 0 06-07-2016 10:56 PM
Newer Sport Bambi Real Tow Weights ? jcole 2005 and newer - Bambi all models 7 04-17-2016 06:40 PM
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Trailer weights davidz71 Our Community 6 05-28-2002 10:55 AM
