Old 05-27-2020, 12:00 PM   #1
2008 19' Bambi
Dayton , Ohio
Mercedes ML350 Gas
We would like to buy an AS to Tour the western US and Canada. We will leave from Ohio. We have a ML 350 all wheel drive with a factory hitch and a 7200# trailer rating. My wife an I alone. WHAT IS THE largest AS we should consider? I am concerned about not having enough “margin” for the car & stores. Thanks in advance for the advice.
Yknot is offline   Reply With Quote
Old 05-27-2020, 12:34 PM   #2
2018 25' International
Slidell , Louisiana
The allowable tongue weight varies from year and model. Do you know the max tongue weight or can you describe the year and model more completely? Do you have the factory installed hitch? Depending on the particulars you are looking at somewhere between 23 and 28 as the limit.
Brian
Old 05-27-2020, 12:40 PM   #3
2019 25' Flying Cloud
Houston , Texas
It would be helpful if you posted your payload max. It should be on or near your tire pressure sticker.
DCPAS is offline   Reply With Quote
Old 05-27-2020, 01:31 PM   #4
gator.bigfoot's Avatar
KW , Ontario
Older MLs like mine needed a hitch reinforcement to be used with the weight distribution hitch. You will also need a brake controller. With proper setup you can tow a larger unit. Mine is a 30, but TV is an ML320CDI. But 27' shouldn't be an issue. I highly recommend you see CanAm rv to get it setup right if you're not familiar enough to do it yourself.
gator.bigfoot is offline   Reply With Quote
Mercedes ML350 Bluetec eleighj Tow Vehicles 227 10-16-2015 11:09 PM
Mercedes ML350 fitting Prodigy P2 Break Control. jmpgino Tow Vehicles 13 06-19-2015 06:01 AM
Mercedes ML350 wing mirror extensions. jmpgino Tow Vehicles 5 06-06-2015 12:29 PM
Towing with a Mercedes ML350 Blue Tec BudBeckert Towing, Tow Vehicles & Hitches 4 02-02-2015 09:25 PM
2012 Mercedes ML350 towing math/specs-for 25, 23 AS vonzellen Towing, Tow Vehicles & Hitches 58 05-21-2014 08:55 PM
