Old 09-20-2021, 08:00 PM   #1
Spaggs's Avatar
GAINESVILLE , GA
Made in USA steel valve stems?
I plan on installing a TST TPMS with the ability to air up without taking off the signal sending cap. I’ve found some German ones, and will buy those at $10 a piece instead of buying anything Chinese, but I would really prefer Made in USA.
Any ideas as to U.S. manufacturer for these?
Thanks.
Spaggs is offline   Reply With Quote
Old 09-20-2021, 08:13 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Have never thought to ask for a specific brand / country of origin of valve stems……
wulfraat is offline   Reply With Quote
Old 09-20-2021, 11:00 PM   #3
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Made in USA
https://www.dillvalves.com/
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 09-21-2021, 07:11 AM   #4
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
I used Dill VS-902-W stems for my TPMS sensors.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 09-21-2021, 07:30 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thanks.
Be advised the flo-thru stem sensors slow down fill time.
The sensors inside the wheel no so much.
I've found it no harder than removing a valve cap when airing up with the added benefit of easy battery replacement. TETO
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 09-21-2021, 08:03 AM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Thanks.
Steel valve stems rust….only use brass…
Old 09-21-2021, 09:08 AM   #7
Mollysdad's Avatar
Dill 902-W made for rims with recessed valve stems.....like ours.
Dill online doesn't seem interested in retail customers, but Discount Tire stocks them.
Old 09-21-2021, 09:16 AM   #8
Dennis C's Avatar
When I swapped my OE valve stems for the Dill stems, there was a visible mark on the wheel where the TPMS sensor had been rubbing on the wheel. I'm happy that I changed them. I picked them up from a local supplier and had them in hand for my appointment with my tire guy.
Name:	TPMS sensor.jpg
Dennis
Old 09-21-2021, 10:28 AM   #9
2021 25' International
Plymouth , Michigan
Just had these Dill valves installed this week in my AS 15" wheels. I went to 3 national tire dealers (Discount Tire was one of them) in the metro Detroit area in search of the Dill stems but all were not familiar with them. I called Dill and they sent me to Mohawk Rubber Sales. Called the company, they had them in stock and got them out to me same day, Like $2.80/ea + 6$ shipping. Very good customer service.
I took them and my wheel assemblies to my local GY tire store and had them install them, $20 for the 4 tires.
I too had the TPMS transmitter contact marks on my rims. Glad I went now with the solid metal Dill valves.
2021 International 25FBQ
2018 F-350 6.7 SRW CC SB
SVTRIDE is offline   Reply With Quote
Old 09-21-2021, 10:29 AM   #10
Spaggs's Avatar
GAINESVILLE , GA
Dill VS-902-W it is.
Thanks for your input guys!
Old 09-21-2021, 12:49 PM   #11
Interesting the OEM Alcoa wheels that came with our AS have steel...stainless.
Brass doesn't corrode?
Snip quote.....
"Generally, brass corrodes when the zinc, copper and tin components of brass alloy are exposed to water. ... Corrosion in brass is easily identifiable by reddish or pink splotches on the surface of the object. In addition to the impact of water, exposure to mercury and ammonia can also cause brass corrosion."
Tahawus
RLC
Old 09-21-2021, 01:15 PM   #12
Mollysdad's Avatar
That's a steal!
I did them myself....because I think I can do better!
I did a post.
https://www.airforums.com/forums/f31...ml#post2539809
Would I do it again? NO! Take the wheels to a tire store.
Actually, it was a learning experience.
Old 09-22-2021, 10:07 AM   #13
Rltports's Avatar
2015 25' Flying Cloud
Bettendorf , Iowa
I’m considering purchasing TPMS. I installed the Dill valve stems last ear. Is it necessary to have the tires balanced with TPMS sensor installed?
Rltports is offline   Reply With Quote
Old 09-22-2021, 11:45 AM   #14
Mollysdad's Avatar
No. The sensors are only an ounce or so.
Let me re-phrase that. I didn't.
Old 10-03-2021, 07:04 PM   #15
Freedom
KCurtis's Avatar
2020 25' Flying Cloud
Dallas , TX
You may want to have each tire balanced after installing your TPMS sensors. I did when I installed mine and each tire required counter weights installed to rebalance the tires. I had them ensure they were balanced before they installed the metal valve stems and the sensors. My trailer was brand new at the time and the tires have worn very evenly.
2020 25RB We named her Freedom
2019 Chevy High Country
WBCCI: 26506
KCurtis is online now   Reply With Quote
Old 10-04-2021, 02:17 AM   #16
2017 25' International
West Lake Hills , Texas
If you have Centramatic wheel balancers, no need to balance.
DT lost two of my sensors, so I did not balance the wheels after installing the sensors. DT made it right though. Paid me cash for two sensors plus comped me a tire.
Fungus is offline   Reply With Quote
Old 10-04-2021, 06:33 AM   #17
No need...??? I don't agree, but regardless.
Mount & balance is usually bundled at most jobbers, why not take advantage of it? Hard to improve on a Road Force balance.
The advantage of the Centramatics is that they balance the entire assembly drum/rotor and the tire and wheel.
Tahawus
RLC
Old 10-04-2021, 08:47 AM   #18
Spaggs's Avatar
GAINESVILLE , GA
Talked to my Discount Tire rep. and he said I needed to balance the tires after the switch to the Dill metal stems because the tires, most likely, will not go back on in the same position as before.
I’m going to take my TST Flow Throughs and mount them at the store after they remount the tires, but before they get balanced.
Thanks again for the help.
FWIW: same Dill stems will work on my Ford Excursion.
Old 10-04-2021, 10:39 AM   #19
Mollysdad's Avatar
I installed the Dill stems myself. So I know the tire did not rotate on the rim. I only broke the bead in the area of the stem, just enough to slice the old rubber one and get my hand in with the new Dill.
BTW, a TST cap sensor weighs 15 grams, about 1/2 oz. The flow through sensor weighs 22 grams.
I can't imagine a tire shop pulling the tire off, but then I'm not there.
Old 10-04-2021, 11:28 AM   #20
Discount Tire lost my first two TPMS sensors. So, no thanks on letting them lose more sensors.
If I do it again I’ll stand at the door of the shop while they install the sensors and balance the wheels, making sure the sensors go on before they balance the wheel. I could have had them balanced with sensors on the second two wheels because I arrived before they opened and stood there watching them do the work. Other advantage to early arrival is that the installers can get busy on your unmounted wheels while they wait for the cars to be moved into the bays. In and out in 20 minutes or less.
I guess the point is to hand them the sensors right before they start the work and keep an eye on them.
I was pleased that they used a torque wrench on the stems.
Tire Balance - Steel Valve Stems Tobbun Sprinter and B-van Forum 23 03-21-2019 08:13 AM
Marathons made in USA romap Tires 35 03-20-2010 07:49 AM
Carlisle -- made in USA?? n2916s Tires 4 10-05-2009 06:18 PM
USA made brake shoes HowieE Brakes & Brake Controllers 11 04-17-2008 03:00 PM
