RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-19-2020, 02:30 PM   #61
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by switz View Post
Cummins speciality is straight six cylinder diesels.... not much luck with small v8 diesels.
..never seen a V8 cummins in the trucks 555..265...903... didnt do much
Old 11-20-2020, 06:39 AM   #62
2008 19' Safari SE
Cary , North Carolina
Nissan XD has (had) a Cummins V-8.
2008AS is offline   Reply With Quote
Old 11-20-2020, 03:25 PM   #63
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Originally Posted by jaybauman View Post
While this was quite true in the past, it's no longer valid for every make.
With the 2020 redesign, GM specifies a higher GVWR for Duramax versions to compensate for the larger mass of that engine, which negates the payload penalty for choosing the oil burner.
Thanks. Thatís good to know and makes sense. I wonder if the increase in GVWR makes it essentially a 1 ton truck😀
KK4YZ is offline   Reply With Quote
Old 11-20-2020, 03:30 PM   #64
KK4YZ's Avatar
Hiawassee , Georgia
Originally Posted by JTChapmon View Post
We did a lot of research on the AS we want to buy and then started looking for the truck. Based on pay loads and tow weight, none of the new ASs really require the benefits of a diesel drive train. Especially when you calculate the cost of diesel and additional maintenance and then DEF. Further calculate the cost of fuel vs the fuel savings of diesel, it could take six decades to pay back the diesel. Some will say resale is a big advantage of diesel but I really don't care what my kids get for my truck when I am done with it one way or the other.
With all that, we went gas, 2500 Dodge Ram Longhorn with a 4:10 differential.
I am knowledgeable on the benefits as I manage the maintenance of a military ship with seven diesel engines...but then I preferred steam propulsion from my Navy days.
You are correct in that a diesel isnít required for an AS; nor can one cost justify it. However, itís is nice to have when pulling a load in the mountains or accelerating up an uphill entrance ramp with a 28í trailer in tow😀. It just a matter of preference. Just like an International over a Flying Cloud.
Old 11-20-2020, 04:20 PM   #65
Is it January yet?
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
Even more so.
A fully-loaded GMC Sierra 2500HD Denali Duramax has a payload rating of more than 3000 lbs. My 3500HD AT4 payload rating is 3839lbs, and I have every option except gooseneck prep.
Had I paid attention to payload ratings, I would have ordered a 2500HD instead.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 11-21-2020, 11:04 AM   #66
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Notice that Nissan stopped building their pickup trucks with the Cummins V8 as there were too many issues. They planed to call it a heavy half ton but the actual numbers were even less than some other brands Ĺ ton units.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 11-21-2020, 03:56 PM   #67
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
It's not just the hauling...
You are right if payload and hauling is what is of interest to you. Wally Byam promoted the Airstream on the basis that it could be pulled by a car, or even a bike! (see promotional photo). And as long as you stay on level roads, pretty well anything can tow an Airstream.
But in real life you may end up with grades like the ones shown below, which is from a road in the beautiful Charlevoix region of Quebec (recognized as a UNESCO biosphere reserve where the Laurentian mountains meet the St-Lawrence River).
The inherent engine braking nature of the diesel engines that one finds in 3/4 ton trucks make driving in these conditions a lot more pleasant and safe -- they are an antidote to white knuckle driving.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 11-22-2020, 11:12 AM   #68
switz's Avatar
2014 31' Classic
Images: 8
Going up the road captioned above would be easier with a turbo charged diesel as no engine power is decreased with elevation increases.
Old 11-22-2020, 11:25 AM   #69
2007 34' Classic S/O
Hillsboro , Texas
Older tow vehicles
While it is accurate that Wally Byam was an advocate for using a passenger car as a tow vehicle, remember that the passenger cars in the 50's & 60's were of body on frame construction, just like today's trucks. Unit body or unibody vehicles today are vastly different from the old cars. You will also see many photos of Wally's caravans showing International Travelall trucks, the forerunner of Suburbans and SUV's. My first tow vehicle was a 1993 Travelall with an AMC 390 cu. in V-8, a Chrysler Torqueflyte transmission, and a mixture of other parts from different sources. Finding correct replacement parts was always a challenge. My Travelall was a better TV for my 23 ft. Prowler than a '88 Chevy Suburban with the 350 GM V-8 I had later.
John Green, Hillsboro, TX
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 & ARC member W9CJX
jwgreen is offline   Reply With Quote
Old 11-22-2020, 12:32 PM   #70
Hermes's Avatar
Memories... my dad worked for International and our family "car" was a Travelall, way more practical than the station wagons of the day! (but we didn't have the Airstream). Lee Iaccoca didn't need to look too far for inspiration for the family van.
Old 11-22-2020, 08:32 PM   #71
1989 29' Excella
Olympia , Washington
I have a 2018 Dodge Ram 3500 with a high-output engine diesel with the ASN transmission and I've heard a lot of reports about problems with them shifts hard from 1st to 2nd especially when pulling the dealer doesn't seem to know what to do with it or how to fix it but otherwise I love the truck I wouldn't by any other truck
Larry koeser is offline   Reply With Quote
Old 11-23-2020, 08:12 AM   #72
2014 27' Flying Cloud
Wenatchee , Washington
^^^ Too much truck for mere mortals, thatís the real problem.
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 11-25-2020, 09:42 PM   #73
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg & Cambridge , Mississippi / New York
Love my 2015 Ram 3500 with Cummins and 6 speed manual transmission.
BUT...
It *did* leave me on the side of I-81 for several days while towing last Spring when the DEF pump failed. It was still covered under warranty, but I couldn't get any dealer in the Harrisburg, PA area to service the truck within a two week period. Ended up towing it on a friend's flatbed 300 miles home to get it fixed. The whole DEF system is a huge Achilles Heel for *all* diesels today. My 2015 does not run as well as my 2001 Dodge/Cummins did, IMHO; and the arbitrary 150 mile disablement built into the software is criminally negligent - and guaranteed to leave you stranded in Timbuktu.
Not much I can legally do to fix this issue; but if I were to go out and buy a new Ram tomorrow, sadly, I would go with the Hemi gasser... :-(
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 11-26-2020, 09:14 AM   #74
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Spell check..I meant the Cummins V8 engines..in the trucks...didnít do much
Old 11-26-2020, 09:26 AM   #75
2020 25' Flying Cloud
Knoxville , Tennessee
This is the salient point to this debate and very well stated.
After making the move up from a 1/2 ton to 3/4 ton RAM turbo-Diesel, I assure you in the context raised by HermŤs, the confidence instilled by having your trailer hitched to the more stable platform far surpasses the few extra MPG you may gain with a smaller TV.
Gibson3798 is offline   Reply With Quote
Ford Powerstroke VS Duramax and Cummings franklyfrank Tow Vehicles 158 12-15-2016 12:26 PM
Duramax or Cummings Diesel? RivaHaven Towing, Tow Vehicles & Hitches 130 11-28-2015 07:24 AM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 06-29-2010 11:20 PM
Isuzu diesel & transmissions tigerpaw Mechanics Corner - Engines, Transmission & More... 0 04-30-2007 12:11 PM
