Old 06-28-2020, 01:08 PM   #1
2019 27' Flying Cloud
Arlington , Washington
How does my tow rig set up look folks?
I have a 2020 Chev Silverado LT 2500HD towing a 27' FB AS
was wondering how my hitch height and coupler look,,,? (Blue OX hitch)
my truck sits high so I had to bring the ball down 1 hole from the previous owners set up (he had a Toyota tundra)
whats your opinions based on this photo?
Niblet is offline   Reply With Quote
Old 06-28-2020, 01:16 PM   #2
2015 25' Flying Cloud
Tucson , Arizona
It appears level to me but I'm far from a professional. Have you measured from the ground to the base of the trailer at the front and rear, then compared those measurements? That's going to be much more accurate than an eyeball check. Also, welcome to the Forum!
McStreamy_ is offline   Reply With Quote
Old 06-28-2020, 01:17 PM   #3
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Looks good. Trailer looks nice and level as does your truck. It also looks like you have the right ball angle as your WD bars are in the right spot. If you are parked on level ground, get a carpenters level on the floor in the middle of the trailer. What does that tell you?
When you set up you WD did you do any measurements to see how much weight you are moving to the front axles when hooked up? With your truck you want to get about 50% of the weight the trailer took off your front wheels moved back to the front by way of your WD bars.
thewarden is offline   Reply With Quote
Old 06-28-2020, 01:21 PM   #4
No I didnt do any measuring, quite frankly I just watched the blue ox set up video and just kind of winged it,,,because I was purchasing the AS and just wanted to get it hooked up and get home. Do you know a resource where
I can go to figure out these measurements?
Thanks..I'm a rookie
Old 06-28-2020, 01:27 PM   #5
Tucson , Arizona
I have reached out to BlueOx customer service a few times and have found them to be both helpful and knowledgeable. You can email them at info@blueox.com or by phone at 800-228-9289. The owners manual might be of help also https://www.blueox.com/wp-content/up...5002000-11.pdf
Old 06-28-2020, 01:36 PM   #6
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
There is a video on the Equalizer website that shows what to measure and explains how a WDH works to move loads around. You can also go to CanAmRV's website and they have. a bunch of downloads on all sorts of things to look at.
Youtube is helpful as well. You might need to rig up a means of measuring the tongue weight of your trailer using a bathroom scale and some lengths of lumber. There are some tongue scales that can be purchased to make that easier. Sherline is one and I think that can be bought off the etrailer website for example.
Maybe we will see you around the area when the borders open up. We like to spend time at the Fort Casey campground and over in Coupeville!
PB_NB is offline   Reply With Quote
Old 06-28-2020, 03:54 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The camera lens could be contributing...but the rear of the TV looks high and the rear of the AS low.
Make sure the pavement is flat the entire length of the rig and measure.
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 06-28-2020, 04:44 PM   #8
2013 30' Flying Cloud
Kingwood , Texas
On a level spot you should compare the measurement from the ground to a spot on the truck about the middle of the front tire without the trailer hooked up and thetrsiler hooked up with WD fully setup. The measurements should not change much. But taking it to a CAT scale would be the best comparing weights of the steer and drive axles with and without the trailer hooked up. Visuals are great, but the numbers never lie.
DoubleR is offline   Reply With Quote
Old 06-28-2020, 06:19 PM   #9
how do I do the CAT scale thing,,I never have before and there is one just down the road from me,,is their a detailed guide? do I weight the TV without the AS first?
Old 06-28-2020, 06:20 PM   #10
Its not the camera,,you are correct,,,maybe I need to come down another hole on the hitch
Old 06-28-2020, 06:46 PM   #11
Kingwood , Texas
Basically I do the CAT scale weighing on the way to take a trip. Load the truck like normal for a trip and a full tank of gas. Drive the truck only to the CAT scale and stop on the scales with your steer tires On scale #1 and your drive axles on scale #2. Go hookup the trailer with WD setup as normal and reweigh with the steer wheels on scale #1, drive wheels on scale #2, and trailer on scale #3. You can weigh the truck & trailer again with WD not enguaged. You can then determine several things about your truck and trailer. YouTube also has several examples and better detailed descriptions.
Old 06-28-2020, 06:53 PM   #12
2017 28' International
Jim Falls , Wisconsin
I used a level on the inside when parked on a flat place. I also measured. Once you get it set up right then it’s just a matter of doing the same thing every time. If you are going to error you want the front a bit lower to prevent sway. Definitely not the reverse.
Daquenzer is offline   Reply With Quote
Old 06-29-2020, 08:13 AM   #13
Tucson , Arizona
There is a CAT Scales app that makes the process much quicker. Download the app, enter your info, drive on the scale, press the weigh now button in the app and you get your weight ticket emailed to you. Saves you having to park and go inside.
Old 06-29-2020, 08:17 AM   #14
thewarden's Avatar
The other thing to remember is that you are towing with a 3/4 ton so, theoretically, you could tow without WD. I would not recommend that but it means that the amount of weight being distributed by your bars is not critical. You just have to make sure that it is not too much.
Just make sure that the trailer is level front to back and if you can not get it exact, a little lower on the front is better than a little lower on the rear. Again, I park on a level surface and use a level inside the trailer for this. There are other ways that work as well including measuring the front and rear of the trailer to the ground. Do what works best for you.
Go to the CAT scales and weigh the truck's front axle and then the rear. Then hook up the trailer without your WD bars and weigh front and rear again. Take note of how much lighter the front axle is and what the difference is between what the front axle was without the trailer and what it is with the trailer and no bars. Now, you want to tension your bars until you return about 50% of that weight back to the front. This will be a bit of trial and error until you get the right tension.
The goal is to make sure you have a level trailer and that when you use the WD you are putting back about 50% of the weight the trailer takes off the front when the weight of the trailer tongue is on the hitch ball without WD bars.
Old 06-29-2020, 10:42 AM   #15
Napa , California
That is what we tow with and just about what we tow...we have a 27' GT and our tow is a 2019 Chevy Silverado 2500 HD diesel, with the Blue Ox as well. Looks great and you will have no issues with power.
The suggestion to measure front and back of the trailer is spot on. Ours was set up by a dealer and they took it on a test run just to be sure before we took possession. That's how they tested it. An old trucker showed us how to load the trailer and truck for the best towing results and we've never had any feeling of instability at all.
The other thing that amazes us is the mileage, on a 6,000 mile trip with hills, valleys, and traffic we averaged about 15 mpg! That's better than when we were towing a tent trailer with a full sized gas van.
Atwebs is offline   Reply With Quote
Old 06-29-2020, 11:29 AM   #16
Mollysdad's Avatar
It looks really, really close.
Maybe the rear of the truck and the front of the trailer are a touch high, so maybe add one link to the chains? Take a little WD out? That's a quick test without disassembling anything.
Drive to a Cat scale and get it weighed.
Old 06-29-2020, 11:38 AM   #17
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Measure the front of frame..and rear...not on a parking lot they are unlevel....use a shop floor or the concrete at a scale house....good show..
Old 06-29-2020, 03:25 PM   #18
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Niblet, congratulations on the new Airstream!
I agree with the other posterís suggestions. Your 2500 will need less weight transfer than a 1500 due to the stronger rear suspension (will drop less).
We have a similar setup - RAM 2500 with a 27í Globetrotter and Blue Ox. I have two sets of bars, 1000# and 1500#. Our tongue weight is around 1100 lbs.
After experimenting, the 1000 lbs. bars did just fine on a 2200 mile trip to Colorado last week. Iíve got them set with 3 1/2 links showing at the latch. Iím guessing that should be fine for an initial setup. You can fine-tune as necessary. You want the bars to flex which transfers less stress to the trailer.
A couple of tips about the Blue Ox: Never disconnect unless the truck and trailer are straight. Any turning will tension one bar more than the other; thatís how the anti-sway works. Also, lock the hitch on the ball then raise the tongue jack to make it easier to tension / remove the bars.
Happy camping!
Jeff
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 06-30-2020, 06:54 AM   #19
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
Is your rig ready for camping? Is it full of clothes, food, propane, dishes, water? Is your truck full of traveling stuff, chairs, grill, fishing stuff, Maps, tools (it's an Airstream so you will need lots of tools)? If it is then the ball is 1" to high from my calibrated eye. If it isn't ready for travel, you are very good. Make sure you look at the door sticker for you maximum gross combined towing capacity and your maximum payload. When I am ready to go with my Ford F250 my payload is way short. So much for thous that said a 250 is overkill. You've got a great rig enjoy and be safe. With you 100K investment I would certainly recommend a PPP Hitch. You will immediately feel the difference. If you are a novice trailer puller the extra insurance has saved me a couple of times. Very cheap extra insurance for such an expensive rig. Happy Streaming
gr.austin is offline   Reply With Quote
Old 06-30-2020, 07:35 AM   #20
2014 25' Flying Cloud
Temple , Texas
When I moved up from a 1/2 ton to a 3/4 ton truck I needed a longer shank to get my rig level, I think you should do the same as it appears that you are a tad high in front and you want to reduce the risk of dragging the rear of your AS, I also agree that 3 1/2 links showing and 1000# bars are right on for your BluOx. You have a beautiful set up, enjoy.
I purchased a Blu Ox shank, but Curt also makes one that will work, I talked an e-trailer rep before ordering and they told me right that a longer shank is needed for 3/4 ton truck
2014 Flying Cloud 25FB
2018 Ram 2500; Diesel
Blue Ox WDH
RamRider is offline   Reply With Quote
How much does your renovation rig weigh? junebug76 General Repair Forum 8 08-30-2017 06:08 PM
HELP, please! Did this CAT Scale make my rig look fat? Hareynolds Tow Vehicles 27 06-28-2017 09:57 PM
Hitch Question for Folks Who Tow a 19' Airstream Beetle Towing, Tow Vehicles & Hitches 48 02-21-2017 03:21 PM
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
