Old 04-14-2021, 10:00 AM   #1
2016 19ft flying cloud
Spokane , Washington
Hitch bottoms out when backing in
When backing in our 19 ft flying cloud , due to a slight incline in our driveway the bottom of the hitch sometimes digs into the cement ,,,anyone have an idea how to solve this problem as we will soon be putting in a new driveway , it happens about 6 ft into driveway
We currently have 15 inch wheels and tires on the airstream,,,would upgrading to 16 inch wheels solve this? ($1000),,,airstream wants $1000 to put spacers to raise up trailer ,,,not sure if this will even help since itís the hitch thatís dragging,
Tow vehicle is 2007 Tundra with 18 inch wheels,
Spinonedad is offline   Reply With Quote
Old 04-14-2021, 10:21 AM   #2
2016 16' Sport
Miami , Florida
If your using a hitch with a drop try using just a straight bar or at least less drop. It will make the rear of the trailer sit lower so be careful not to hit that but you might find a balance.
Shiny16 is online now   Reply With Quote
Old 04-14-2021, 10:25 AM   #3
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
You should be able to get the lift done for less than that....
My driveway goes down instead of up, but, I had a lift put on my 20'. The camper is ~3" higher (whereas switching wheels/tires to 16" ones will net you about a half-inch).
Here's the thing: your hitch will need to be adjusted too, for the AS to sit level, also accounting for that 3". Do you use a WD hitch? Without seeing it, I'm not sure if it's the piece that goes into your truck's receiver that is sticking down and 'plowing' into the driveway. If your AS come up 3", would you be able to flip that piece upwards, so it isn't acting like a plow? (Understand what I'm asking?)
-Leslie
LNBright is online now   Reply With Quote
Old 04-14-2021, 10:29 AM   #4
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
Can you post a picture of your hitch? It would be easier to offer a possible solution.
RivetED is offline   Reply With Quote
Old 04-14-2021, 10:30 AM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Two solutions. Can you cut off the excess metal hanging down on the hitch. Raise the rear of the Tundra slightly with air bags. I installed Firestone bags in my 2007 and 2016 Tundra.
Richard
Old 04-14-2021, 10:39 AM   #6
2016 16' Sport
Miami , Florida
Before doing some paving work I had the same issue. Weight distribution hitch off. Ball with no drop on. Problem solved. It’s worth a try without having to reconfigure your WDH or pay to lift the trailer which may necessitate the need for an extra step and so on and so on
Old 04-14-2021, 10:46 AM   #7
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we added the 3" lift kit and went to better quality 16" wheels and tires
no issue in the last few years and no bottom out problems
waninae39 is offline   Reply With Quote
Old 04-14-2021, 11:33 AM   #8
Mollysdad's Avatar
as azflycaster said, what's digging in is most likely the shank which extends below where your hitch attaches.
Mine does too, sometimes with no trailer, I get a 'bang' if I pull out a certain way. The solution is to get rid of that extra metal, either by cutting it off or by buying a shank with less drop. The good news is shanks from all manufacturers are 2" steel, with the 3/4" holes spaced 1.25". So your Equalizer head will fit on a Curt shank, etc.
(BTW, sawing it off may cost more than a new shank if you find a machine shop.)
The thump doesn't bother me because I think of it as early warning. If that isn't there, would the jack foot hit?
Old 04-15-2021, 09:32 AM   #9
1964 30' Sovereign
Ione , CA
Possible fixes in order of simplicity:
1. Replace your tongue jack with one that has lower height. We replaced our original 1964 Airstream tongue jack with a Bulldog one that is easier to use plus is shorter height-wise.
2. Change your slide-in receiver hitch. You can buy a drop hitch, level hitch, or (by flipping the drop hitch over) a raised hitch.
3. Cut an inch (or so) off the current jack shank. Make up for it with a snap-on/off jack foot like https://www.amazon.com/Pro-140070034...73G8Y4TBNRTAFJ
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 04-15-2021, 09:44 AM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
If you only move the trailer occasionally, why not get some appropriately long 2x10 boards to make a lift for the rear wheels of the tow vehicle? You could even use multiple lengths, stack them and nail them together if the dip is too deep to fix with just 2” of lift. Back the trailer in, put down the lifts, back the rear wheels over them, remove them, finish backing. The hitch will only scrape while the tow vehicle’s rear wheels are in the trough.
Silver Clicheí
Follow us at...
silvercliche.blogspot.com
GammaDog is offline   Reply With Quote
Old 04-15-2021, 09:47 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The only thing that hasn't been covered so far: Is the hitch adjusted correctly for normal operation? If the trailer normally is a bit "front low" ( as many are ....), I'd take care of that first.
Old 04-15-2021, 09:55 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Hi
X2
The AS needs to be as level as possible after all 'adjustments' are made.
Best dead level.
High=lower TW
Low= higher TW
Obrigado, ť hora de descansar.
Tahawus
Old 04-15-2021, 11:10 AM   #13
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
When I had my 19', I had to create a ramp (twice) for my driveway. The first time was with just two layers of 3/4" plywood, that did not last. The second, I created two 2x8 with 3/4 plywood on top for a smooth surface. To this day, it is still structurally sound. I don't need it anymore because I upgraded to a 25, and the dual wheels help to clear the angle. I did make markers on the concrete to help position it whenever I needed it. I also added wheels on the side to help move it to position because that thing is heavy.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 04-15-2021, 11:30 AM   #14
PKI
PKI's Avatar
Walnut Creek , California
Options
The 16 inch wheels and tires give you the option to run a higher load capacity tire and there are more types available in the 16 inch size. The bigger diameter will raise the trailer slightly and that allows a higher lift setting on the tow vehicle receiver hitch shank.
As suggested in prior posts, optimize the hitch shank clearance by removing any extra length length or drop. If you do not have the skills and tools to modify the shank, it may be easier and less expensive to replace the shank with one that is closer to the configuration that you need for your application.
But, but, but .... the fastest solution is as suggested above - bridge the dip with inexpensive wooden planks to raise the tow vehicle as it transits the driveway approach.
Good luck with your new coach. Pat
Old 04-15-2021, 01:30 PM   #15
Jim J
Jim J's Avatar
2014 30' Flying Cloud
"X" hits the driveway
Solve for "X"
Increase the clearance between "X" and the driveway.
The right solution depends on what X is and whether your drive slopes up or down from the street.
If X is the shank, Can it be reversed? Can it be cut off?
If X is the tongue jack, can it be raised?
If X is some other part of the trailer, A trailer lift kit or larger tires or boards on the pavement may work.
If X is part of the truck, something to lift the truck frame higher may work.
Jim J is offline   Reply With Quote
Old 04-15-2021, 01:56 PM   #16
2017 25' International
West Lake Hills , Texas
Angle it in
My hitch never scraped. My problem was the tail and the spare tire. My experience might differ from yours.
I needed 2-bys stack two deep at the deepest point and WD bars removed for the first time I backed in. I marked the driveway afterward as mentioned. No lift kit.
After that first time, I hit it at an angle and had plenty of clearance. No gap filler. I was a little more confident with accurately placing the trailer where I wanted it. No lift kit.
Leaving the bars on will raise the hitch three or four inches.
Lift is installed now so no worries...until I install the ProPride hitch. Iím a little concerned about that.
Fungus is offline   Reply With Quote
Old 04-15-2021, 07:08 PM   #17
Does the approach angle make a difference ?
Should I be backing straight in, I’m having a new driveway installed this summer,,,wondering if one side was at a gentle slope would give me more clearance,
It’s the bottom of the shank that is hitting and it only hangs down about 1 inch,
Suppose I could grind 1/2 inch off , it’s solid
Old 04-15-2021, 07:38 PM   #18
Approach angle can make a big difference dependent on the situation.
Iím backing into the driveway which is on the passenger side at a ninety degree angle to the street. The right side trailer wheels cross the dip while the left side is still on the street. So the wheels sort of straddle the dip. As the left trailer wheels reach the dip the right trailer wheels lift the trailer enough for the tail to clear. Truck follows trailer a little more then cut the tow vehicle so the trailer tail swings right just a little because you want the tow vehicle to hit the dip at a slight angle too.
You might find it easier to learn the maneuver by getting the trailer into the driveway with 2-by boards. Then drive out at an angle. Note how you did it. Then back in on the same track.
Old 04-15-2021, 11:37 PM   #19
2007 27' International CCD FB
San Diego , California
3" trailer lift also lifts the hitch and WD components accordingly. Never had to worry about clearance again.
pteck is offline   Reply With Quote
Old 04-16-2021, 04:15 AM   #20
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Big Difference
Should I be backing straight in, Iím having a new driveway installed this summer,,,wondering if one side was at a gentle slope would give me more clearance,
Itís the bottom of the shank that is hitting and it only hangs down about 1 inch,
Suppose I could grind 1/2 inch off , itís solid
I always take an angle approach when entering or leaving say a gas station with a slope. It gives you a few extra feet to make the transition.
Also as others have said, remove your weight distribution and maybe even change to a straight shank hitch just for parking purposes. Sounds like a huge PIA (and it is) but this has worked for me instead of dragging my hitch or back of the trailer.
Mikebrady62 is online now   Reply With Quote
Hitch Ball Retaining Nut Backing off During Trip csondt Towing, Tow Vehicles & Hitches 37 10-19-2017 08:10 AM
Backing with weight distribution hitch streaminwild Towing, Tow Vehicles & Hitches 29 08-14-2014 09:31 AM
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
Bottoms up! CanoeStream Belly Pans & Banana Wraps 8 09-02-2010 07:38 AM
front end bottoms out!!? Curtis-79MH Airstream Motorhome Forums 18 09-15-2003 10:13 PM
