08-25-2012, 06:17 AM
1966 17' Caravel
Bethel Park near Pittsburgh
, Pennsylvania
Harbor Freight Haul-Master Weight-Distributing Hitch
10,000 Lb. Capacity Weight-Distributing Hitch System
I thinking about buying this to tow my 66 Caravel with my 09 Grand Caravan. Has anyone bought one of these? It is a great deal using a 20% off coupon from there ad. I'm looking for any feedback.
Ace in PA
WBCCI 2169
TAC PA-1
08-25-2012, 06:26 AM
Retired.
, At Large
If you get it, resign yourself to buying another complete setup when something breaks.
08-25-2012, 06:50 AM
1966 17' Caravel
, Pennsylvania
Thanks for your reply Terry
I know some people don't like HF. But I have had very good look with there stuff. They do a very good job when it comes to returns and replacements if needed. I can get this for $152 that in one third of what a Resse will cost me. With your thinking I can buy three of them.
Ace in PA
08-25-2012, 06:58 AM
Retired.
, At Large
Ace in PA
That's what I was thinking. I've had very bad luck with getting parts for their stuff. And yes, retail on a Reese is about $400. Reese is also now made in China.
08-25-2012, 07:12 AM
1971 27' Overlander
Central
, Ohio
Looks like the max. towing capacity for a Grand Caravan is 3,600. So for about the same price you could get your hitch here:
Dodge Grand Caravan Trailer Hitch - 2009 | etrailer.com
Is 'That Italian place" still there - I used to live it Bethel.....
08-25-2012, 07:13 AM
1978 31' Sovereign
Tampa
I also have had good luck with 90% of the things I buy at Harbor Freight. You just have to be wise enough to know what to stay away from.
Having said that, I don't know that I'd buy a WDH from them. While it's several pieces, it's several KEY pieces and it's the only thing that ties your tow vehicle and your trailer together. I'd hate to skimp on something that important.
I have, and like, the HF electric tongue jack, but I'd spend the money on a Reese or equivalent for the WDH. Just my .02, of course.
2000 31' Land Yacht
Central
Read their warranty policy on it, they don't warrant everything they sell the same. Some tools have and not others, and at the mgr's discretion sometimes. Check what happens when you get failure of product, a hand tool might not do too much collateral damage, however I wouldn't want to be the driver of a failed hitch.
08-25-2012, 07:31 AM
2010 25' FB Flying Cloud
Davenport
, Iowa
the hitch is the life-line between the TV and trailer; DON'T BE CHEAP. It's NOT only your life that is in involved, and your insurance might be involved if you have an accident. The "sharks" will be looking.
08-25-2012, 07:47 AM
1974 Argosy 28
Fresno/Clovis
Buy 2, then you have spare parts. Otherwise, if you have probs while traveling, options are few, and prices go up.
Roger
08-25-2012, 07:50 AM
2012 25' Flying Cloud
Battle Lake
It has no built-in sway dampening. That would be an additional expense to add separately.
doug k
08-25-2012, 08:03 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Since you asked. One thing is that if the hitch is good for 10000 lbs and 1000 lbs tounge weight it might be a bit stiff for that car/trailer combination. I like the Reese Straight Line better and you can get it with 600 lb torsion arms. I feel very good about spending the additional $300 for the Reese. I like the anti-sway control built into the Reese.
I do not need 3 hitches for $450; I need one that works well. Click on the Pro-Pride site and look at the Reese that they offer there.
I do not know of anything necessarly wrong with the HF setup. But it is not something that I would want to use. I want a hitch product that I think has gone through some real development and testing and has a record of performance.
08-25-2012, 08:11 AM
Berlin
, Maryland
Ace
I do not know anything about the HF's hitch so do your homework before you purchase. The hitch IMO is more then a lifeline between your TV and the AS. It is a lifeline between you and your passengers.
John
08-25-2012, 08:37 AM
1975 Argosy 26
1963 24' Tradewind
Seattle
Interesting.... I see nothing wrong with it... looks just like my EZ-lift hitch. More than likely, it probably is the same. My only concern is that the bars seem to be rated for 1000 pounds? Might be a bit stiff for your trailer, but with the Grand Caravan's realatively soft suspension, it might work out ok.
Yes, you need sway control too.
Marc
08-25-2012, 08:50 AM
1973 21' Globetrotter
Houston
Make sure you understand how to size your bars. The 1000 lb bars with this set-up are probably too much for your combination of trailer and tow vehicle. The 1000 lb bars would suggest that you have 500 lbs tongue weight and 500 lbs of cargo in the back of your TV. You want your bars to be as close as possible to your actual combination of weights. Over-sizing the bars by several hundred pounds will result in an overly stiff connection, which could result in damage. As far as I know, there are no options for different sized bars on the HF hitch system. If you do decide this hitch is the way to go, you can get the sway dampening device for about $30 at HF as well (bring your coupon too).
To vear off topic, slightly, on the topic of HF, I certainly use my share of 20% off coupons, but I try to buy only "dumb iron" there (nothing with a cutting edge, or a requirement for precision). Funny story, I needed to replace some pieces of steel that are roughly 3" x 1.5" x 0.25" that act as big washers tying the front and back of my trailer C-channels to the frame. A piece of mild steel bar stock would have cost me some $14 at the local hardware store, but I was at HF, and they had their small nail-puller type pry-bars on sale for $1.99. On a whim, I bought a couple of them, as they had the right dimensions for my application. By the time I got home, I was having second thoughts, as I figured I would burn up a band saw blade and a drill bit or two trying to cut what should be spring steel. Well, I went ahead with the project, and these pry bars cut like brass.
08-25-2012, 10:30 AM
Port Orchard
Ace in PA
WBCCI 2169
TAC PA-1
First of all I don't buy cheap tools, so I don't shop at HF. However the purchase you are contemplating can be a life or death matter. I have no idea where this is made, but if it made using the Chinese Q/C techniques, I would be very dubious about it.
Even with your light trailer, a broken WD bar catching on the pavement at highway speed can easily throw the TV and trailer out of control. at 60 mph, it is unlikely you will be able to recover. I highly recommend you go with a well tested hitch system that has a good reputation with users here.
I would sooner tow with a hitch and ball. At least then you know what you are dealing with.
Ken
08-25-2012, 11:55 AM
Baltimore
, Maryland
Come on now Ace, quite pulling people's legs with this joke
08-25-2012, 01:03 PM
1968 28' Ambassador
Cedaredge
Just spend the extra $250 and get an Andersen WD hitch with built in sway control. Easier to hook up and 100 x better. And it's made int the USA.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
08-25-2012, 01:55 PM
K.C.
, Missouri
And if you want a more traditional designed WD hitch, that is also made in the USA ( well made, I should add ) that has built in sway control, consider the Blue Ox.
08-25-2012, 02:37 PM
1966 17' Caravel
, Pennsylvania
I Not Sold Yet
Well Frank I didn't think I was pulling anyone's leg. But guess I was looking a that Chinnesion stuff! Lots of good feedback. Well should I be a test pilot and try it out? I think not.
Thanks All
Ace in PA
