Does anyone know how many inches high the A frame part by the LP tanks is on the new Globetrotters? I’m guessing 6 or 8 but I can’t order a weight dist hitch until I know exactly what it is.
Depends on size: the chassis height can vary depending on the length of the AS, some are not as tall as others... (AFAIK, it's more length-dependent than model dependent, that an International and a GT should be the same, if the same length).
Thanks my GT will be 23 foot so the 4,5,6 inch option is probably the hitch I need I don’t suppose they go bigger than 6 inches on frames in the 23 footers?
I can't guarantee/quote the 23' frame height off the top of my head, but I 'think' that 4" is correct. I would expect that if you called the dealer from whom you're buying, they could confirm that. But yes, that's the ballpark range.
