Old 02-11-2018, 10:07 AM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Fords Death Wobble. Watch while you can
This is what one Dealer told a customer.
There are other videos on this.
2004 Excursion 4x4
Old 02-11-2018, 11:18 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Wow I would love to know the dealers name. Stay away
Old 02-11-2018, 01:56 PM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I wonder what Ford's response would be to this video?
Old 02-11-2018, 02:17 PM   #4
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
That has more to do with the incompetence of the dealer employees than the manufacturer!
It is disgusting treatment of a customer in any case.
Bruce
Loving our 2021 Globetrotter 25 shopping for the next tow vehicle and 2020 GMC 2500 Sierra Denali Duramax.
Bruce B is offline   Reply With Quote
Old 02-11-2018, 04:02 PM   #5
2012 19' International
Southeastern MI , Michigan
Wheel out of balance, and loose suspension parts. Seen it many times on everything from Model Ts to Jeeps.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
Countryboy59 is offline   Reply With Quote
Old 02-11-2018, 04:58 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Could be just bad front tires.
The dealer is not one I would trust.
How many miles on the truck?
Old 02-11-2018, 05:20 PM   #7
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
"They all do that" said my Ford dealer upon hearing the resonance in my brand new Ranger at 100- 110 km/h. It was loud and uncomfortable to listen to for any great length of time; either had to do 110+ or less than 100 kph. They didn't have a clue what caused it; thusly were not prepared to throw parts at it to fix it.
Haven't bought a Ford since.....or ever will.
Good luck to the gentleman whose truck is in the video.
Cheers
Sidekick Tony
Old 02-11-2018, 05:25 PM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I took my F-150 in 3 times for front end alignment right after purchase. Vibrations like crazy over 50 MPH. Turns out one of the lower arms was bent prior to or during assembly.
MICHAEL
Old 02-11-2018, 05:47 PM   #9
Cheers
Sidekick Tony
There’s nothing wrong with the Ranger. Your dealer was incompetent.
Old 02-11-2018, 05:52 PM   #10
Boxite's Avatar
2008 22' Sport
An incorrectly pre-loaded recirculating-ball steering gear will do this. I witnessed it several times when I worked as a new car dealer-tech. The fix was to replace the steering-gearbox under warranty and "red-tag" the defective box so it would be examined and permanently condemned rather than rebuilt. (At least that's how Toyota handled it.)
Loose/defective rod-ends will also behave that way. (I have no experience with newer electric-steering and no knowlege as to how it might, or even if it can, behave in this manner.)
The voice in the video (presumed to be a "Ford Dealer" but not supported by evidence) might simply be a local yay-hoo who's out of his depth, but his comments betray his complete and irresponsible ignorance.
Old 02-11-2018, 07:37 PM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I used to run fords,many of them..
Old 02-11-2018, 08:33 PM   #12
1988 29' Excella
2008 25' Safari SS SE
Did more noodling on Youtube. Owner is Brandon in Colorado. Truck had bad ball joint, Ford finally fixed truck.
Did not learn dealership, very scary that a dealer like that exists!
I like shiny objects.
mbutterfield is offline   Reply With Quote
Old 02-11-2018, 10:04 PM   #13
VernDiesel's Avatar
Dayton , OH, 2017 33' Classic 8,561 dry
Point taken.
Transportr AS & TT Mfg 2 dealr RAM ED factory brake controller tow mirror hitch camera & receiver 1,290/12k, No sway WDH, Adj. hitch, axle 2 frame air bags, tune w turbo brake, SLT Grill, 31.9" load tires, Max ED tow 9,200, GCAR 7,800, Max Ram 1500 GCVW 15,950, truck hitches steer 3,240 drive 2,560
VernDiesel is offline   Reply With Quote
Old 02-11-2018, 10:06 PM   #14
VernDiesel's Avatar
Good thing it’s still a free country.
But I really enjoy the sense of humor & more in your signature.
Old 02-12-2018, 04:23 PM   #15
HowieE's Avatar
Images: 12
Not sure if you have ever worked on a front end but I assure you a failed or undertightened ball joint would not cause this issue.
The common contributes to Wobble in older trucks have long been understood. Generally it is a combination of several things. This was a new truck and the problem had to go beyond worn parts.
Since I have a Ford 250 chassis under my Excursion I looked a little further and found this explanation. Luckily Ford did not install a Wobble Pron front end on my truck.
Not that I will need this kit but having used several BD modifications on my trucks I would surly consider it if I had the problem.
2004 Excursion 4x4
Old 02-12-2018, 05:03 PM   #16
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
Ok here is ground truth. I have a 2005 F250 full size 4x4. I am the original owner. The truck has 54K on it. I have just started towing a 2017 28’ Serenity. A few years ago before I bought the trailer I was traveling down I-264 in VA when I hit a series of rough bumps. I was going 65mph. I almost lost control from the resulting violent shaking and out of control shimmying of my front end. I took it to the Ford dealer and they basically found nothing wrong. After a ton of research, all I could find was this front end is sensitive to tire pressure. So I ensured that my tire pressure was at the recommended pressure and I have not experienced the phenomenon again. I didn’t believe it, but three days ago I got a Ford bulletin in the mail discussing this same issue. It said the exact same thing - tire pressure was the answer. Hard to believe but maybe they are right.
VaTravelers is offline   Reply With Quote
Old 02-12-2018, 05:41 PM   #17
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Just got a letter today from Ford on my 2005 F250 Super Duty 4 X 4 about the shimmy problem. Ford and NHTSA have been reviewing this issue, Ford said mods to suspension, not maintaining proper air pressure and proper tire replacement are some of the causes of the shimmy issue. If you still have issues contact Ford Customer Relations. Thought I would share this with all.
cole3444 is offline   Reply With Quote
Old 02-12-2018, 07:39 PM   #18
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I used to buy Fords.owned 16 to be exact.....
Old 02-13-2018, 02:48 AM   #19
If this happens you have a loose suspension component somewhere, and bad shocks. If you have 60,000 miles you have one or the other. And they need to be aligned correctly, not just “within limits” but dead on.
I’m real finicky on alignment, have had several used vehicles with this issue and I always was able to fix it permanently wh the 3 things above. Even on the Jeeps the dealer says tire pressure and balance, blah blah blah. Tighten the suspension and replace shocks first.
Michelin 16” tires
Hensley Arrow hitch
Fords EcoBoost Towing Capacity davcarv Tow Vehicles 53 04-15-2014 12:06 PM
Airstreams Boxers Fords & the Rocky Mountains... THEPILL On The Road... 2 04-16-2011 08:21 PM
New Fords-sway control built in? hhendrix Tow Vehicles 36 04-06-2010 12:57 AM
toilet wobble Frank's Trailer Works Sinks, Showers & Toilets 17 09-07-2007 06:07 PM
