Old 06-14-2021, 09:57 AM   #1
Norwalk , Connecticut
Question Ford Trailer Backup Assist
Dear Members,
I have a new 25' International coming in August, and was curious to hear from anyone if they've used the trailer backup assist feature on the F150's with their Airstream. And what they think of it.
Thanks for your thoughts.
Silverminer
25' International FBQ
TV 3.5L V6 Ecoboost with Max Tow Package
Silverminer is offline   Reply With Quote
Old 06-14-2021, 10:10 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Which F150 do you have?
Why ask?
The "old ones" came with a sticker that goes on the trailer. You mess around with a bunch of measurements and calibration stuff. Finding a location for that sticker that works well was a challenge for most folks ( = we didn't bother with it ).
The "new ones" come with a yaw sensor. You mount a box on the trailer and it plugs into the truck. No stickers, no crazy measurements. It looks (other than the added cable) like an easier setup to get working.
Either way / either one, they both seem to work. The big issue any time you are backing is to be aware of the stuff around you. Neither one helps you spot that post on the blind side of the trailer .....
Old 06-14-2021, 11:12 PM   #3
I have a 2017. So it comes with the stickers. Thanks for the reply.
Old 06-15-2021, 01:28 AM   #4
Sag Harbor , New York
Welcome to the forum. Lots of good discussions all over the place on this system:
https://www.google.com/search?q=Ford...=airforums.com
Happy trails,
Peter
FYI
FWIW
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 06-15-2021, 05:03 AM   #5
wilsodf's Avatar
2014 27' Flying Cloud
Paramus , New Jersey
I thought the yaw sensor was only for 5th wheels. We have a 2020 F350 and it comes with the trailer back up assist , we had it on a 2018 expedition we used before our F350. We used the sticker with an equalizer hitch and it worked well. When we upgraded to the Ford F-350, we also got a ProPride 3P hitch. It doesn’t work with a 3P hitch because of the pivot points on the hitch throw it off when you try to turn.
For now back to plain old “back up” the way it has been done for years.
I’ll look up about the yaw sensor since our truck has that. I’ll report back what I find out.
wilsodf is offline   Reply With Quote
Old 06-15-2021, 05:45 AM   #6
wilsodf's Avatar
Looks like the 2021 Ford F-150 with the 12” screen and Sync 4 now uses the Yaw sensor for travel trailers . Looks pretty cool. I believe our 2020 Ford Super Duty only uses the YAW sensor for 5th wheel or gooseneck. I will call Ford and ask them if our YAW sensor would work on a travel trailer and report back.
Old 06-15-2021, 07:51 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I've been backing up all sorts go boat, horse, utility and camping trailer;ers for 40 years or so. I finally thought I'd try the backup assist on my very squirrelly kayak trailer. It works great!
However I think it would be a challenge to find proper sticker placement on an Airstream.
2019 Ford Expedition Platinum
Old 06-15-2021, 08:31 AM   #8
2021 28' Flying Cloud
Chester County , Pennsylvania
I have a 2020 F150 (with stickers) and can tell you due to the location of the propane tank cover you are not able to place the sticker in the location it needs to be placed.
Sidwar is offline   Reply With Quote
Old 06-15-2021, 09:26 AM   #9
2018 26' Flying Cloud
Oriental , North Carolina
My problem with the sticker location is that the truck cannot see it 100% of the time. The electric jack gets between the truck and the sticker at certain angles and the truck loses its visual contact with the sticker. This usually happens when you absolutely don't want it to.
Captn.Ken is offline   Reply With Quote
Old 06-15-2021, 09:29 AM   #10
2017 27' International
Antes Fort , Pennsylvania
I love mine. The sticker needs to be a part way under the propane tank cover but that does not interfere with the assist. I just zig-zag easily into my spot!
alphamale49 is offline   Reply With Quote
Old 06-15-2021, 11:44 AM   #11
Marietta , Georgia
F250 with backup assist
I have a 2020 F250 with pro trailer backup assist. I was able to get the sticker on the A-frame off my 2021 Classic 30. The sticker needs to be between 7” and 22” from the center of the ball. It just squeaks into the minimum distance. Once the 4 distances are entered into the trailer setup, it works like magic!
pwakeling is offline   Reply With Quote
Old 06-15-2021, 12:11 PM   #12
wilsodf's Avatar
Sticker Definitely won't work with 3P hitch - ProPride or Hensley Arrow
When I had my expedition, the sticker system worked well, unless you took a tight turn and the camera would lose the sticker. The Pro-pride hitch will not work with my 2020 Ford F350. It will work backing up in a straight line, but the minute you try and turn and the 3P hitch pivots, it loses the sticker.
We have the 5th wheel package and the YAW sensor, but I am assuming that the YAW sensor only works with 5th Wheel or gooseneck and it says to use the sticker for Travel Trailers.
The 2021 Ford F150 with Sync 4 now uses the YAW sensor and no sticker.
I will call Ford later today and ask them about the YAW with the 2020 Super Duty. But my guess is that won't work for Travel Trailers until they go to the new Sync 4.
I will post what I find
Old 06-15-2021, 12:12 PM   #13
wilsodf's Avatar
Meant to clarify when I had my Expedition, I was using an Equalizer hitch, not a 3P hitch.
Old 06-15-2021, 01:18 PM   #14
Cedar Hill , Texas
Silverminer, I have the same F150 as you. I did all the measurements than checked them and I love my backup assist. I joke that I am a over 60 (way over) year old Texan and have never backed up a trailer. AND I'm dyslexic. I would never be able to back my rv without my F150. (Sometimes, when no one is around, I practice. Thank God no one is around - hahahahhahaa)
fthopkins is offline   Reply With Quote
Old 06-15-2021, 02:39 PM   #15
2017 25' International
West Lake Hills , Texas
Same here.
Backup assist does not work at all with the ProPride hitched to a 2020 F-150.
It did work with an Equalizer hitched to a 2020 F-150. The back edge of the sticker was hidden under the propane tank cover.
I didn't use it much. It would lose sight of the sticker when backing into my driveway due to an uneven surface across multiple humps. Big trailering mirrors work as well for backing straight. The only time it came in handy was when I backed up a few hundred feet one day.
Fungus is offline   Reply With Quote
Old 06-15-2021, 03:59 PM   #16
2017 28' International
Jim Falls , Wisconsin
When I had the Blue Ox I tried it and the sticker would get lost on tight turns. I just gave up using it. Also if you back up at night forget it. The sticker really gets lost then. I have the Propride now and don't use it except for backing up straight. I will be interested to see if the 2021 set up works better, AND if it will work with the Propride. I would think it should.
Does work great for the cargo trailer though.
Daquenzer is online now   Reply With Quote
Old 06-15-2021, 04:02 PM   #17
Denver , Colorado
I have a 2021 F150 PowerBoost with the Max Trailer Tow Package, which includes the back-up assistance. Since taking delivery of our 2021 27' FC mid-March, we have enjoyed 38 nights at 15 different campsites in Colorado, Utah, California and Oregon. I am new to pulling and parking a trailer, and have been very pleased with the features of the F150 - both as a very comfortable and powerful towing vehicle and with backing into various campsites. Aside: I have the Equal-i-zer Sway Control hitch; which I have also been very happy with.
RoadCyclists is offline   Reply With Quote
Old 06-15-2021, 04:04 PM   #18
So how does the back up assist work? I assume it works fine from your statement.
Old 06-15-2021, 06:35 PM   #19
Anna Maria , Florida
I do it the old fashion way and smoothly glide back into my space using my mirrors.
They have never failed me since I learned how to use them 52 yeras ago.
franklyfrank is offline   Reply With Quote
Old 06-16-2021, 08:54 AM   #20
Half a Rivet Short
Hi
I'll bet they work even when the front of the trailer is covered in mud ...
There are a lot of things that can put the backup assist stuff out of action. Learning how to manage without it is a good idea. Practice is very much part of that learning process ....
Ford's Pro Trailer Backup Assist moosetags Tow Vehicles 37 04-02-2021 06:28 PM
Using Ford's Pro Trailer Backup Assist with a ProPride Hitch DaytonaDan Hitches, Couplers & Balls 1 04-11-2018 11:23 PM
Anybody have experience with Ford's New "Pro Trailer Backup Assist"? DaytonaDan Towing, Tow Vehicles & Hitches 35 10-07-2017 05:03 PM
Ford's Pro Trailer Backup Assist BW1 Tow Vehicles 10 09-17-2017 06:43 AM
