07-24-2010, 09:10 PM
#21
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Originally Posted by elzavb
Hi All,
I am new to the trailer pulling of an Airstream. I have just bought a 1989, 32 ft, Excella and am pulling it with a 02, Chevy,1500 HD with an 6 liter gas engine. I knotice at speeds of about 65 mph the trailer rearend would fishtail and I would have to put on the breaks to stop it. I have an equilizer hitch and was told to was set up right. I went to the locial RV store and they told me to add stableizers bars to both sides of the receiver. Will this hepl? The trailer was not over loaded and most of the weight was in front of the axels. I was also told that a bad wheel bairning could be the problem. Can someone give me some advice on stableizers bars. and what might be my problem?
Visit Out of Doors Mart - one of the better Airstream dealers - and located in North Carolina. They will help you diagnose the problems which can be numerous.
Paula
07-24-2010, 10:53 PM
#22
1999 28' Excella
Frederick
, Maryland
Hepjon, good point, I didn't notice that he had the HD version of the 2500. PMclemore, the reason us fools purchased the 2500, is for the beefier engines like the Dmax and the Allison transmission. The OPs truck should be able to handle the weight. Hopefully they will get squared away. Would be nice if they would follow up with more info based on our questions.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
07-25-2010, 12:08 PM
#23
Tom, the Uber Disney Fan
2006 30' Safari
Orlando
My understanding, not that I have ever got a good explanation, is that the 1500 HD is the "best of both worlds" scenario in that you get the suspension and brakes of the 3/4 ton, but you get the economy of the 1/2 ton engine, transmission, and rear end. There is a 2500 & 2500 HD and a 3500 & 3500 HD available, IIRC. But, like I said I have never received a good explanation. Also, I think the 2500 is more of a "work horse" and the 1500 HD is more of a daily driver and is lighter in duty.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
10-14-2010, 10:34 AM
#24
2008 30' Classic S/O
Dearborn
, Michigan
Whether it’s a ‘half’ or ‘three-quarter-ton’ isn’t the real issue.
You should not be using a ‘friction sway-bar’ with a 30’ trailer.
You need a ‘dual-cam’, at the very least. Preferably, a 3P or Hensley.
10-14-2010, 12:08 PM
#25
Mantua
, Ohio
Yes you need stabilizer bars if you mean antisway bars. zz
10-15-2010, 07:00 AM
#26
Dearborn
, Michigan
I mean, using a "friction anti-sway" bar to tow a 30' trailer is like taunting an alligator.
Just like towing around town, you can poke that alligator with a stick- thinking you’re pretty clever cause nothings ever happened, and he’s not going to make much of a move to get you, cause you’re out of reach, with your long branch… but at some point, you’re gonna get lazy, or cocky, and step in just a wee-bit too close, and before you know it, that ‘gator is gonna leap and catch your fleshy calf between his razor sharp teeth, and he’ s not going to let go. He’ll slowly drag you down into his swamp, with you thrashing about, all the while inching your nostrils closer to the surface of the water; whilst you scream and claw at the slippery, muddy goo at the waters edge. Until, exhausted from your futile efforts to free your leg, and weary from blood loss, he’ll pull you beneath the water, and wedge you under his favorite tenderizing rock- where you’ll stay while he, at his leisure, feasts on your bloated corpse…
And THAT, my friend, is why you DON’T USE a friction anti-sway bar.
10-15-2010, 08:22 AM
#27
Ottawa
, ON
Yikes!
Ewwwww...! I'm getting rid of my "friction anti-sway" bars right away!
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
10-15-2010, 08:31 AM
#28
Corona
Torsion type sway control, has a brain.
Friction type sway controls, are brainless.
10-15-2010, 09:48 AM
#29
Trabuco Canyon
If it were mine, the first thing I'd do is weigh the trailer and tongue of the trailer. To me if its fishtailing unprovoked at 65 MPH, there is something very fundamentally wrong here.
The hitch should received proper attention too, and good suggestions here.
10-15-2010, 10:43 AM
#30
Master of Universe
2008 25' Safari FB SE
Grand Junction
For alligator defense I always carry an alligator clip.
Gene
10-15-2010, 02:03 PM
#31
Ottawa
, ON
10-15-2010, 03:02 PM
#32
Maniacal Engineer
Lopez Island
Indeed. Spontaneous fishtailing at 65 mph means something is badly wrong, and using a sway control hitch to reduce it is just a bandaid.
Properly hitched w/o sway control devices engaged, no trailer should display any steady state oscillations. They may sway back and forth a bit in response to transient inputs (gusts of wind, sudden steering inputs, etc), but those oscillations should always damp out if the driver does not react to them. One common cause of trailer sway is driver-induced oscillation, where the driver reacts to trailer behavior in such a way as to exacerbate the sway rather than reduce it.
- Bart
10-15-2010, 06:17 PM
#33
Vintage Kin
Fort Worth
- Bart
Never seen one that didn't "oscillate", following from the rear. Never. It's always there. Move from one side of the lane to the other, change lanes, catch a wind gust . . it's always observable.
"Should always damp out" is relying on luck. The trailer load may change; a slow tire leak may be present, or, worst of all (and I doubt we've discussed it around here) is a tripping hazard where the TV and/or TT get airborne on one side or, God forbid, both.
When the trailer comes back down all sorts of havoc can play: blown tires, broken suspension, serious hitch damage, and so forth. She may get airborne a second time as well if suspension bottoms badly.
A sway- eliminating hitch is worth every penny at that point. As are attending to all other hitch rigging details.
10-15-2010, 11:12 PM
#34
Maniacal Engineer
Lopez Island
I may not have been clear: if you have a trailer that sways back and forth noticeably (from the tow vehicle, not the trailer's rear bumper) under normal towing conditions w/o a sway reducing hitch - something is wrong, and you should address the cause of the problem rather than slapping damping (friction) on it and hoping it goes away under all conditions.
-= Bart
10-16-2010, 03:51 AM
#35
Any trailer that has a "sway" under normal conditions is a sick puppy. It needs fixing before any superhitch is employed.
After all, aren't these the best towing trailers on the planet?
Incidently, I've been using the classic brainless friction anti-sway bars for decades from coast-to-coast with no sway problems whatsoever. This includes using them not only on the best towing trailer on the planet, but on the underlings as well.
10-16-2010, 06:00 AM
#36
Dearborn
, Michigan
10-16-2010, 06:30 AM
#37
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
I'll second Paula's suggestion.....take a trip over to see the good folks at
Out Of Doors Mart especially if you can't fix it with suggestions from the good folks on our Forum here.
In dog years, I'm dead!
10-16-2010, 09:06 PM
#38
Salem
, Oregon
Hi, Joe. I personally think this is a pretty harsh analogy coming from someone who can't stop their own trailer from swaying even with the $3,000.00 magic hitch. Many people, like me, use what you call a friction type hitch and are very happy with it's performance. And for the other guy, torsion means a twisting type spring and Reese Dual Cam springs bend just like all of the others, not twist like car trunk springs or torsion bar springs used on several cars for front suspensions. I use an Equal-i-zer brand hitch and in over six years, and many thousands of miles, my trailer only swayed once; It was sitting in my driveway swaying during a 5.0 earthquake.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
10-16-2010, 09:13 PM
#39
Salem
, Oregon
Having a memory doesn't require a brain.
Hi, springs and many other materials [plastics and metals] have a memory, meaning that they can be bent and will return to there original shape, but that dosen't mean they have a brain. So as far as I'm concerned, all hitches are brainless.
10-16-2010, 09:29 PM
#40
Oswego
Hear, Hear!!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Trailer Sway or Fishtailing
68 Overlander |
Hitches, Couplers & Balls |
9 |
12-13-2007 06:43 PM |
