01-12-2016, 09:50 AM
2014 23' International
Hurst
First Airstream and I don't want a truck (!)
Linda and I are so excited that we will be picking up our new-to-us 2014 23D International Serenity later this week. We are 99.99% sure that our trusty '96 Land Cruiser won't be satisfactory for the weight... sometimes it seemed to struggle a bit when pulling our Casita (~ 3,100 pounds on the road). The truth is that we don't want a truck, preferring a SUV. Right now, I'm thinking 2008~2012 Toyota Sequoia with the 5-point-something V8, six speed transmission and all the towing stuff. I've read a number of threads about this vehicle and all seemed pretty positive, but all I found were 'kinda old."
So, I thought that I'd post this question as to the suitability of the Sequoia with the 23D for current thought. We do like to travel frequently to the Rockies, if that matters, and it probably does.
Thanks so much,
Rob
01-12-2016, 10:08 AM
2016 25' Flying Cloud
Holly Springs
, Mississippi
I'd for sure call Andy T. at CanAm and discuss your circumstance with him. He can give you some really good guidance as to what TV can be made to work quite well.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
01-12-2016, 10:42 AM
1972 25' Tradewind
North Vancouver
, British Columbia
Yes, give Andy a call. He can speak to your specific vehicle choice as well as recommend other options that would work for your trailer.
North Vancouver, BC
01-12-2016, 10:49 AM
Alamo Heights
Top here on AIRForums uses a Sequoia as one of the tow vehicles. It's not a fuel-economy champ but for a 23' trailer should do fine if properly equipped and set up. If memory serves he's had minor annoyances with the brakes, starting before he ever towed with it. Big heavy SUV that likes to warp the stock rotors, I think.
— David
01-12-2016, 10:51 AM
2012 25' Flying Cloud
Battle Lake
Sequoia is pretty close to Tundra in size, shorter wheelbase and independent suspension which are very good for getting around and stability.
A little smaller SUV with a 5.7 engine (plenty) and 8-speed transmission that is less expensive and not as thirsty on fuel is a late model Dodge Durango, also independent suspension and rated to tow any mid-size Airstream.
There are three equally important elements in a great towing combination. Tow vehicle, trailer, and hitch, if any one is poor, the combination will be poor. Spend at least as much time researching the hitches as you do the other two elements, and get it set up by someone who knows what they are doing. Many dealers and customers treat the hitch as an afterthought, a make-do item.
Doug and Cheryl
01-12-2016, 10:57 AM
1974 Argosy 20
Kooskia
, Idaho
Also consider a Jeep Grand Cherokee, with the V8 or diesel.
01-12-2016, 11:23 AM
2004 25' Classic
Prescott
Another choice: Nissan Armada or Infiniti QX56
Julia & Bob
W/ Deedee & Boo
AIR #30685
01-12-2016, 11:34 AM
N/A
, N/A
Why not another Land Cruiser? It will last you another 20-25 years.
01-12-2016, 12:07 PM
Walnut Creek
Believe there is another thread with a similar question. The Toyota reliability reputation drives loyalty. However, there is a lot going for new, in place of older used. Travel breakdowns are a real distraction at a time that you need/want to enjoy the experience.
Towing is a unique type of driving. A tow vehicle performs better and is safer if it has a low center of gravity, long wheel base, short rear overhang, wide track, large tire contact patch, big disk brakes, similar mass to the trailer, reasonable torque, stiff chassis, and a payload that matches load and tongue weight conditions. The reduced oxygen at higher elevation gives an advantage to boosted induction engines.
The 23 matches well with a number of SUVs. However, it also matches up with minivans and cars, which can be less expensive and provide as much and often more economy and utility. They are worth your consideration.
Good Luck, Pat
01-12-2016, 12:59 PM
2013 25' FB International
Liberty Corner
, New Jersey
We ended up with a QX and really like the comfort and power. If you get a 56 make sure it is at least a 2011. Big change for better that year.
01-12-2016, 01:07 PM
2015 28' International
Ofallon
, Missouri
I have a 2013 Armada 4WD with tow package, which has a tow rating of 9,000 lbs. I have towed a 25' and now a 28'. We love it.
01-12-2016, 01:13 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Another vote for a 2011 or later Durango or Cherokee.
2019 Ford Expedition Platinum
01-12-2016, 01:38 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Get a newish Sequoia. You'll be happy. They make great tow vehicles. It would only be better if they offered it with the twin turbo diesel from the Land Cruiser.
Lance
01-12-2016, 03:03 PM
Always learning
1972 29' Ambassador
Central
I guess I should add the twin turbo diesel is from the LC that is available worldwide minus North America.
Lance
01-12-2016, 07:04 PM
I'm In
, Kentucky
Thanks so much,
Rob
We tow ours with a 2004 4Runner. It has a smaller 4.7L V8 but it has a 7,000 lb. towing capacity. The early Sequoias also had the 4.7L. If you can get the 5.7 you can upsize the trailer later on with the bigger engine but the 4.7 does nicely with the 23' size. I think Toyota kept the 4.7L in the 4runners through about 2007 but the '04 models have the larger fuel tank.
Just a thought.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
01-12-2016, 07:50 PM
Biloxi
, Mississippi
I happily tow my 23 with a 2011 Jeep GC Overland Hemi. I had an F-150 and decided it was overkill.
MICHAEL
01-13-2016, 10:22 AM
1955 18' Globetrotter
Carrollton
A friend of mine has a gorgeous Porsche Cayenne SUV that pulls his large boat --- If you want style and can afford one he says it's fantastic.
01-13-2016, 10:29 AM
2005 30' Classic
Box Elder
, SD
We have towed our current A/S with a 2010 Nissan Armada SE over 65,000 miles with NO adverse issues. Since the Armada has a 9,100# tow limit, we carefully keep the A/S to no more than 8,500# and get 10-13 mpg depending on topography as we keep speeds under 65 mph.
The Sequoia is also a very good tow vehicle. Good luck with your A/S and finding the tow vehicle which best suits your needs!!
01-13-2016, 10:40 AM
Taos
, New Mexico
True story - we were visiting an Airstream dealership about a year ago in the southwest. A couple was admiring the Bambi which was on the floor in the Airstream store. They asked a sales person several questions and it seemed to be going along very well at least until they asked if their Subaru could tow the trailer. I loved the response - "sure it will - one time". Subaru products are awesome and I've owned a few myself but this was a honest answer and it was the right answer. I agree with you on the pick up truck part, no desire to drive a truck as a TV and through the year. The input above is all great and, for me, we have had such great luck with Chevrolet. The full frame V8 Tahoe & the Suburban remain the lead choices for me in a quickly narrowing field of options for a sturdy and capable non-pick up tow vehicle.
01-13-2016, 10:41 AM
2004 25' Safari
2013 27' Flying Cloud
El Prado
, New Mexico
Diesel is the answer, no matter what the question about tow vehicles. Among SUVs, try the Mercedes GL (or ML, for a 23') or Jeep Grand Cherokee.
