Old 09-14-2020, 03:56 PM   #1
Brawny's Avatar
2004 30' Classic
London , Ontario
F150 'Pro Trailer Backup Assist' with Hensley Hitch
We recently purchased a new TV - 2020 F150 with Ford's max tow package, which includes 'Pro Trailer Backup Assist'. I've read through the instructions, and watched the how to video on YouTube a few times here.
The procedure seems fairly straightforward, except that they refer to taking measurements relative to the hitch ball. Given that we have a Hensley, I wasn't sure if that's still valid or not.
Does anyone else out there have this backup assist configured with a Hensley, and if so, did you need to change any of the measurements for setup?
For bonus points - how does it work? Worth the effort? I'm fine backing the trailer up myself without the assist. I'm curious if it makes backing up any easier?
Thanks in advance for your advice and opinions!
Brawny
2004 30' Classic
2020 F150 XLT 4x4
WBCCI #1783, Region 2, Ontario Canada Unit
Brawny is offline   Reply With Quote
Old 09-14-2020, 05:02 PM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Many will scoff but I love the backup assist on my F150. There are threads on Airforums concerning it. I mounted my sticker on a 2x1 bar attached to the bottom of the propane tank.
I doubt it will work with a Hensley, though, because the pivot isn't what it expects.
daleyocum is offline   Reply With Quote
Old 09-14-2020, 06:28 PM   #3
2017 28' International
Baileys Harbor , Wisconsin
It works really well with my cargo trailer; and small trailers are the hardest to back up. It is very easy to set up. Ford has some videos on-line on how to do it. This is my second F150 with it. I have set it up on my Propride (similar to Hensley) and it doesn’t work very well. I made the pivot point where the stinger goes into the receiver. It does work when you want to back up straight and make small turns. I just used it backing up into my pole barn after I have straightened out. But you can’t make large turns; at least I can’t. It loses the sticker too easily. Some say they put the sticker on the LP tank cover. I may try that. But if I can use it just to back up straight that’s fine with me. I really don’t have a hard time backing up the Airstream. But I thought I would give it a try since it works so well with my cargo trailer.
Again if anyone has a better solution I’m all “ears.”
Daquenzer is offline   Reply With Quote
Old 09-15-2020, 09:24 AM   #4
Brawny's Avatar
2004 30' Classic
London , Ontario
Thanks for sharing your experience. I'll set up my utility trailer for sure - it has a tendency to jack knife, so the Pro Assist will be useful.
Curious if you think the issue with the AS is the placement of the sticker, or the position of the "ball" for measurements. I wondered about measuring to where the Hensley covers the ball, or possibly midway between the cams on the Hensley, as this is where the pivot point seems to be...
I am too. :-) We're heading out on a 2 1/2 week vacation on Friday, stopping at 6 or 7 different provincial parks here in Ontario. This would be a good opportunity to test out the pro assist!
2004 30' Classic
2020 F150 XLT 4x4
Old 09-16-2020, 09:57 AM   #5
2019 25' Flying Cloud
North-Central FL , Florida
Ditto what daquenzer said above. Has worked fairly well w/
my 25’FC w/ ProPride and both previous F-150 & current F250. Most helpful for longer straighter backups. Doesn’t replace need for operator to be reasonably proficient at standard backing.
djbar is offline   Reply With Quote
Old 09-16-2020, 11:45 AM   #6
2020 25' Globetrotter
Philadelphia , Pennsylvania
My dealer installed mine on my new 2020 Globetrotter with Equalizer hitch for F250 - but warned me that the system does not “like” the reflection from the propane cover, which turned out to be accurate - he said some people cover it with something non reflective - I opted to just learn to reliably back up old school style.
Also (unrelated) I spent a lot of money on Ford’s integrated customer installed rear camera and TPMS - only to find out that because both are wired (vs wireless) it is a huge job to install including drilling holes all over the AS body - nope.
Czarina is offline   Reply With Quote
Old 09-16-2020, 01:41 PM   #7
2018 25' International
Slidell , Louisiana
As you surmised the back up assists assume the articulation point is stationary but with the Hensley type hitches the effective ball point varies with articulation angle. As the angle increases it fails to track the strip location or better the strip is not where the trigonometry in the program expects it and it provides poor guidance or just stops functioning. I can't think of a good way to compensate.
Brian
BayouBiker is online now   Reply With Quote
Old 09-17-2020, 07:53 AM   #8
Brawny's Avatar
2004 30' Classic
London , Ontario
I figured this was the case, but wondered if there was some sort of workaround. I'll probably set up the measurements as Daquenzer has and use it only for long, straight backups. Anything else, I'll do without the system. At least it will work on my utility trailer.
2004 30' Classic
2020 F150 XLT 4x4
Old 09-17-2020, 03:03 PM   #9
Slidell , Louisiana
I'm still thinking about this. I think I'll get my pencil and slide rule out and maybe I can give you some advice. Off the top of my head it will have to be that you do something slightly different from what the computer tells you to do.
Brian
Will Ford's "Trailer Backup Assist" work with a Hensley Hitch wilsodf Hitches, Couplers & Balls 3 02-23-2020 08:52 AM
Trouble with Ford's Pro Trailer Backup Assist setup with a ProPride hitch DaytonaDan Hitches, Couplers & Balls 30 05-29-2018 06:09 AM
Using Ford's Pro Trailer Backup Assist with a ProPride Hitch DaytonaDan Hitches, Couplers & Balls 1 04-11-2018 11:23 PM
Opinions on F150/Pro Backup Assist/25'+ clamb Tow Vehicles 39 09-29-2017 11:56 AM
Ford's Pro Trailer Backup Assist BW1 Tow Vehicles 10 09-17-2017 06:43 AM
