Old 01-29-2021, 12:26 PM   #1
2021 25' Flying Cloud
berlin , Maryland
f 250 and 25FC
I bought a 250 with the 6.7L diesel as my tow vehicle for a 25 FC RBT with a tongue weight around 835lbs. I am thinking about towing it home before I get a WDH as I don't know which one I want yet. Both truck and trailer are new and will be empty on the trip. I have read many pages here about towing and hitches and don't think I would have any problems. I welcome your thoughts and advise.
Capt who is offline   Reply With Quote
Old 01-29-2021, 02:07 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
No problem at at. I towed my 30’ Globetrotter home 500 miles on the ball.
That’s how it was delivered to the dealer from the factory.
Just watch your speed and don’t do anything stupid and you will be just fine.
Old 01-29-2021, 03:17 PM   #3
2018 30' Flying Cloud
Springfield , Ohio
I tow my FC 30RB without weight distribution or sway control with a 2020 Silverado 2500HD. It tows as good as anything I've ever towed using WD and swaycontrol. The tongue weight on my trailer is ±1200 lbs. Life is much simpler when you can drop the ball on the hitch and drive away. I'd test your combination before buying items you may not need.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 01-29-2021, 03:30 PM   #4
2016 23' International
Long Beach , California
You won’t really notice much of a difference with that truck.
I don’t bother with a weight distribution hitch if just going to our local beach, and we tow our 23’ with a mini truck.
Seanlb is offline   Reply With Quote
Old 01-29-2021, 04:19 PM   #5
Rancho Cucamonga , California
I think you will find you made a good choice and doubt you will need any bandaids to tow safely - you have more truck than you need. Good luck
syclone93 is offline   Reply With Quote
Old 01-29-2021, 04:28 PM   #6
berlin , Maryland
Thanks for the assurance. I appreciate the response.
Old 01-29-2021, 04:56 PM   #7
2020 23' Flying Cloud
Sebastian , Florida
The other consideration for choosing a hitch is sway control. Late model Fords have it built in, and most responsible drivers don’t encounter heart stopping sway, but see how you like the “feel” when a semi passes you.
As others have said, your TV and trailer are a good match, and you may decide you don’t need much more. Just give it some thought as you are driving.
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 01-30-2021, 09:30 AM   #8
palm beach gardens , Florida
You should be fine towing the trailer home, but I recommend you research a good WD hitch with sway control when you get there and use it every time except for short trips.
You will always have a better towing experience with it than without it.
m rafferty is offline   Reply With Quote
Old 01-30-2021, 10:24 AM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
We like our Reese duel cam hitch...
Old 01-30-2021, 12:04 PM   #10
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
Lady Lake , Florida
it’s OK
We moved our 25 ft down to the dealer for a new hitch setup no weight bars Never knew it was back there at 65 max speed.
Life is a Highway is offline   Reply With Quote
Old 01-30-2021, 03:13 PM   #11
Lumberton , Mississippi
f250 and 25fc
30 ft classic towed on the ball with chevy 2500 duramax any speed anywhere no problems
Plug is offline   Reply With Quote
Old 01-30-2021, 05:28 PM   #12
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
You won't need it until you do! I wonder how close to departure a towing accident has occurred due to lack of sway prevention?
guskmg
Old 01-30-2021, 05:46 PM   #13
2018 25' International
Gig Harbor , Washington
I have the same set up, F250 diesel 25 ft serenity with the blue ox hitch system.., I have zero issues, tons of power, I have to remind myself I am towing!! Enjoy!! Deb
dmegig is offline   Reply With Quote
Old 01-30-2021, 09:04 PM   #14
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
I have a 25' FC RB and tow with a 2018 F-250 gas engine. For short trips I have gone without my weight distribution hitch without issues. Do your research and make sure that you have the proper drop on your hitch bar. Even the F-250 will drop a little once you put 900 lbs on the ball.
Most important is to have the trailer as level as possible after you hitch up. Sorry, but my hitch bar that I use is with my trailer in storage so I don't have it to measure. But to give you an idea, I measured from the top of my weight distribution ball and it is about 1" above the top of the inside of my hitch receiver on my truck.
Also be aware that the safety chain clips are difficult to clip onto the weird openings on the F-250 tow bar. I bought some links to make hookup safe and quick. Here is a video that shows what the problem is (I went with a different set of clips).
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 02-03-2021, 10:45 AM   #15
Coolio's Avatar
2019 25' International
Evergreen , Colorado
I have 2019 25FB and tow with a 2019 F250 diesel crewcab. We've towed over 10,000 miles without a WDH. 98% of the time it works great! The only time I felt like I needed it was traveling I-80 through Wyoming with 50mph crosswinds.
Don't feel like you need to rush on the decision. The truck is very stout and can easily handle a trailer your size.
Coolio is offline   Reply With Quote
Old 02-04-2021, 04:06 AM   #16
CruiserGa
Bmccorm's Avatar
2004 25' Safari
Gainesville , Georgia
You should be fine. Here is the direction for my 2019 F250...
Bmccorm is offline   Reply With Quote
Old 02-04-2021, 06:13 AM   #17
berlin , Maryland
Well, I should be ok. This is my first exp with a heavy duty type of tow vehicle. Only have a couple hundred miles on it so far but am very happy. Thanks again.
Old 02-04-2021, 06:39 AM   #18
B. Cole's Avatar
1977 31' Sovereign
Rochester , WASHINGTON
guskmg
A WDH is needed when the tow vehicle isn't big enough for the trailer.
Glad to help...
B. Cole is offline   Reply With Quote
Old 02-04-2021, 06:43 AM   #19
B. Cole's Avatar
1977 31' Sovereign
You have a real tow vehicle, for that trailer.
WDH is for tow vehicles that are too small for the trailer.It is what it is.
Comments above , giving examples using real tow vehicles,not being driven by trailer,( like a overmatched small tow vehicle) point that out..
Old 02-04-2021, 09:50 AM   #20
Lewisville , Texas
Same setup. 2018 25FC and 2019 F250 6.7 4x4.
I use the blue ox wdh but only because I used to tow with an F150 and it NEEDED sway control.
I would LOVE to throw the WDH into the trash because it adds time effort and expense to the process. Think about it, I am wearing out my tongue jack every time I put it on or take it off because I have to substantially lift the back of my heavy truck to relieve the pressure on the bars.
That’s got to add a fair amount of wear and tear.
Also, when you get to your site, if you don’t take the massive hitch out of your truck’s receiver you will bang your shins on it at night (and sometimes in the day). When you take it off you get grease on your shorts and maybe shirt. If you put it in the back of your truck it will break other stuff, add weight and take up space. If you throw it under the trailer it will get nasty and rust more rapidly.
If I were in your shoes I’d drive the setup until something scared me. Hopefully nothing will. And if it doesn’t, please PM me and tell me to get rid of mine!
Rant over. And yes I am aware that Hensley and Pro Pride are perfect and I’m an idiot for buying the blue ox.
Matt & Roxanne
2018 FB Twin INTL Serenity (The Flying Squirrel)
2019 F250 DIESEL (Ferdinand)
@tflyingsquirrel
mattRox is offline   Reply With Quote
250 meets 250 meets 250... "made for Germany" in Germany split window Classic Motorhomes 31 03-16-2020 05:25 AM
2017 25FC FB water pump circuit The Colonel Water Heaters, Filters & Pumps 11 02-24-2017 07:47 AM
Husky Brute fit for 2017 25FC FB The Colonel Jacks, Stabilizers, Lifting and Leveling 1 09-04-2016 02:17 PM
Started Day w/ 25FC, ended with 27EB jayseejay Eddie Bauer - All Models 19 05-26-2015 11:46 AM
Additions to new 25FC NWGreyhound Stoves, Ovens & Microwaves 4 06-07-2010 05:36 PM
