RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-17-2020, 01:31 PM   #1
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
f-150 23FB Hensley Cub.
Got the trailer level but truck not so much. Maybe it’s caused by a 5% slope on garage ramp. Should I start shopping for a 350 diesel or will a gas engine work in my case. The trailer is about 30% below the trucks tow rating but this is cutting it pretty close don’t you think? I am thinking about 2021 Lariat 350 SRW with the 7.3L V-8. Opinions. My wife’s Ridgeline it does pretty good towing up to just under 85 MPH. So I don’t think I need a 550
FE
Sorry I am feeling froggy fall is in the air and sure enough I fell this morning.
Fair_Enough is offline   Reply With Quote
Old 10-17-2020, 03:33 PM   #2
Silvr_Bullet's Avatar
42į 2' 27" N / 74į 7' 6" W , US
Yes I would reposition your trailer and truck on level ground first. Do you have any pressure on the lift? Also I canít see what drop you have on your Hensley, you may want to give them a call. If you just want a new truck thatís another matter. I hope your not doing 85 MPH, thatís dangerous.
Silvr_Bullet is offline   Reply With Quote
Old 10-17-2020, 03:35 PM   #3
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
F150 more than enough to pull that rig
drairstream is offline   Reply With Quote
Old 10-17-2020, 04:35 PM   #4
2018 25' International
Slidell , Louisiana
I'd sleep it, then find a truly level spot and reevaluate. I'm thinking maybe that truck might sorta do the job.
Brian
Old 10-18-2020, 02:21 PM   #5
1988 32' Excella
Robbinsville , New Jersey
There is more fender gap on the back of the truck so that looks fine. In the picture the front of the truck looks low, the opposite of the problem you are asking about fixing. Desperately need to park on level surface to have any idea how it really looks.
Old 10-18-2020, 02:24 PM   #6
hissilver's Avatar
Van Wert , Ohio
Right.
hissilver is offline   Reply With Quote
Hensley Cub? AWCHIEF Hitches, Couplers & Balls 9 09-18-2012 10:28 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 08:31 PM
The Hensley Cub bredlo Hitches, Couplers & Balls 23 10-22-2008 11:56 AM
