RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-13-2021, 08:34 PM   #1
2020 23' Globetrotter
San Francisco , California
Equalizer hitch -- Is this normal?
We've been full-timing since September and have been using our hitch as the airstream dealer originally told us to. However, it's gotten quite rusty/rickety (see video below). Is this normal/safe? Any guidance would be much appreciated!
Video link: https://i.imgur.com/VgKuKjn.mp4
Dave
dave_stream is offline   Reply With Quote
Old 01-13-2021, 08:39 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Normal. That is why I like the Reese duel cam
Old 01-13-2021, 08:42 PM   #3
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
Load up on this. It works!!
https://www.equalizerhitch.com/store...ance-lubricant
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Old 01-13-2021, 09:08 PM   #4
Gary W's Avatar
2019 27' Globetrotter
Lacey , Washington
Hitch Wobble
The pin that holds the slug into the hitch receiver, is it a straight pin or one with a bend on the end opposite the keeper clip? If its a bent pin, check the receiver holes and see if the have become egg shaped from the pin bent end wearing on the receiver hole.
I had this happen on my previous brand X box trailer where the egg shaped pin hole was worn to the point you could feel the clunk when stopping or pulling away and the hitch was sloppy in the receiver as your video indicated. I had a welder add 1/4 steel plates on both sides of the receiver, switched to a straight pin, and added an anti-rattle bracket. Do a google search or go to a trailer hitch shop and ask but due get a heavy duty model.
I was told by my welder that the receiver metal is ok but softer thus subject to wear from the bend on the end of the pin wearing the metal. I also suspect US v/s metric sizing contributing to sloppy hitch/receiver match up.
A good welding shop can fix your issue and the cost is reasonable.
Gary W.
Olympia, WA
Gary W is offline   Reply With Quote
Old 01-13-2021, 10:31 PM   #5
1988 32' Excella
Robbinsville , New Jersey
No, that's not it.
The problem is the people that use to leave a hitch in the receiver until it rusted solid cried to the hitch manufacturers and the receiver manufacturers so they both added slop to loosen the fit.
Old 01-13-2021, 11:30 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, while you are at it , look to see if your receiver is a Round Tube type that GM used for many years. If it is, they are junk and will break.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-14-2021, 09:10 AM   #7
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
You might want to rub the grease off your dog’s nose��
Actually that much slop looks excessive to me. Try to shim it out.
KK4YZ is online now   Reply With Quote
Old 01-14-2021, 09:33 AM   #8
paiceman's Avatar
Upper St Clair , Pennsylvania
If your truck is a super duty, 3/4 or 1 ton you are probably using an adapter which I have used and did not like as it wobbled. So I purchased from Equalizer a shank that fit my super duty.
Also, I take my equalizer apart every winter as I did with my reese prior, sand it, repaint and grease.
Enjoy
Bud
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
USAF Master Training Instructor (TI) - 68-72
Old 01-14-2021, 09:59 AM   #9
Silvr_Bullet's Avatar
42 2' 27" N / 74 7' 6" W , US
Dave
It looks like a little surface rust, steel will rust. Steel wool and some black gloss spray or paint on will fix it. ....rickety, needs a little more explanation see manual
https://www.equalizerhitch.com/owner...fore-each-trip
Silvr_Bullet is offline   Reply With Quote
Old 01-14-2021, 12:28 PM   #10
amxpress's Avatar
2021 22' Bambi
Clayton , North Carolina
https://www.etrailer.com/Hitch-Anti-...ophy/RSCP.html
amxpress is offline   Reply With Quote
Old 01-14-2021, 01:55 PM   #11
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
I've posted this picture in a previous post. I prefer avoiding any movement of the hitch mechanism (I have an Equalizer and I am very satisfied with it).
The goal is to eliminate most if not all friction with the shank, the receiver and the pin.
For the past 30 years, my hitches have had a "jam bolt". I didn't invent this, it was an experienced owner of a hitch shop who recommended it to me back then. For example, on my current 3/4 ton TV I had a jam bolt hole drilled and a nut welded on top of the receiver (click photo to zoom in). I have also had jam bolt holes drilled and a nut welded under the receiver. Both work.
Once the jam bolt is torqued tightly (similar to a wheel lug) the shank won't move even when the trailer is hitched. In addition you won't get ovalized pin holes because you don't have any movement against the pin. And if anybody wants to pull out your hitch, they will need to have the right size wrench! (in addition to removing your locked pin, if that is what you have).
If you have an adapter sleeve, I recommended that you weld it in place. The receiver plus the welded adapter double the steel thickness of your pin holes, making doubly sure they will not elongate or become oval with time.
With these two simple and inexpensive "upgrades" you shouldn't have any problems and years of maintenance free use.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 01-14-2021, 02:04 PM   #12
Mollysdad's Avatar
I also have an Equalizer hitch and although mine may not have quite that much play, it has some.
Once the bars are tensioned on the "L" pads, that will go away.
I wouldn't worry about it.
BTW, the play is between the shank and your receiver, neither of which is an uniquely Equalizer part.
If it bothers you buy a new shank and see if it's better.
Old 01-14-2021, 02:36 PM   #13
2018 27' Globetrotter
Mooresville , North Carolina
I may be missing something but it looks to me like it is installed upside down. I thought the angled part of the hitch that is facing up in the picture should be below the shank, not sticking up from it. This would also mean they have the hitch ball mounted incorrectly.
GOUSC is offline   Reply With Quote
Old 01-14-2021, 04:04 PM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by Wazbro View Post
No, that's not it.
BINGO
I welded three wide beads on the top & sides of the stinger & ground down to fit snuggly.
The welded reducer increases the wall thickness of the pin hole.👍
ID:	386931   Click image for larger version
"I prefer someone who burns the flag and then wraps themselves up in the Constitution over someone who burns the Constitution and then wraps themselves up in the flag.
― Molly Ivins
Tahawus
Old 01-14-2021, 06:43 PM   #15
mwodzinski's Avatar
2017 23' International
Winter Park , Florida
It looks like too much play at the receiver. You might want to try a hitch “rattle reducer”.
I would also recommend you contact Equal-i-zer (https://www.equalizerhitch.com) customer support. Also, don’t be afraid to lubricate the hitch and use rust inhibitor on the wearing parts
Here are some links:
LPS Rust Inhibitor: https://www.amazon.com/Premier-Rust-...s%2C191&sr=8-3
Curt hitch anti-rattle: https://www.amazon.com/Curt-Manufact...0671260&sr=8-1
I hope this helps. Happy camping!
mwodzinski is offline   Reply With Quote
Old 01-15-2021, 03:24 PM   #16
1988 32' Excella
No, it can be installed as a drop (going down) or a rise (going up), whichever way is needed to get the trailer level. Just most trucks are so high anymore the drop is usually needed.
Old 01-15-2021, 08:53 PM   #17
Thanks for letting me know as Id only seen it as a drop. I was out of town when I viewed this thread and could only view it with my phone. The video would not work so this was the only thing that looked odd to me. Once I got home I could view on my computer and see all the slop in the the receiver. This is not normal or safe IMO. I agree a hitch clamp or shims would help this.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
Old 01-16-2021, 06:34 AM   #18
2018 25' International
Slidell , Louisiana
From a hitch performance perspective, it is important to eliminate all the sources of play. While tensioned up the play is preloaded out of the system, but on the road the variable and dynamic forces act to allow all the play to degrade system stability. The play will conspire against you in situation where you most need the hitch to perform its purposes.
Brian
BayouBiker is online now   Reply With Quote
Old 01-16-2021, 10:02 AM   #19
Mollysdad's Avatar
No, the shank can be used either way depending on how much drop or lift is needed.
Equalizer hitch adjustments Raptorrider2001 Hitches, Couplers & Balls 4 09-22-2017 11:45 AM
Is this Normal for a Reese Hitch? malinois38 Towing, Tow Vehicles & Hitches 21 08-03-2016 08:55 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 08:31 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 12:48 PM
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 12:00 PM
