Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 02-04-2006, 10:29 AM   #1
blucloud's Avatar
2007 27' International CCD FB
1987 25' Sovereign
1977 23' Safari
North Olmsted , Ohio
Images: 20
Equal-I-zer v/s Reese dual cam
New trailer, new hitch .....
Our first AS was a 77 Safari, 23 ft., which I towed from Maryland to Ohio using only the Reese WD hitch. After settling in we upgraded to the Dual cam set up that went with the WD hitch. (straight line) My towing impression of this system, Xcellent.
New AS, a 87 Sovereign, 25 ft, which I towed from Florida to Ohio using only the Reese WD hitch. The Sovereign seemed to tow better than the Safari.
NOTE: The 77 and 87 were towed with a borrowed WD hitch. The Reese Straightline setup was sold with the Safari.
Time for a new hitch set up. I've been looking towards the Equal-I-zer because of the ease of hitching up. My wife would like the HA, but out of our price range. Her second choice is the Reese Straightline only because it proved it's reliability with the other AS.
My question, is there much difference between the two hitches re: sway control and durability?
You never know what you can do
until you try to undo what you did.
blucloud is offline   Reply With Quote
Old 02-04-2006, 10:44 AM   #2
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Images: 18
Send a message via AIM to Andrew Selking
I think most people would tell you that both are good hitches. If you do a search on this topic you will find lots of threads on hitches and pros and cons of each. I like the reese because thats what I have but the Equal-I-zer is also a good hitch. Your wife must have expensive tast if she wants a HA or lots of money to throw away.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 02-04-2006, 11:00 AM   #3
Two years ago I sold my 1977 Argosy 22 to a gentleman that towed it with a Toyota Tundra from Metro-Detroit to Salt Lake City.
He brought a brand new Equal-I-Zer hitch with him.
I have towed Airstreams and Argosys since I was 16 and I have always used the standard Reese W/D hitch with an anti-sway bar set-up. Never really had problems but I always towed with a big TV or a small AS or Argosy.
When he got back to Salt Lake City he called me and said the hitch worked awesome. He has now towed it all over the west with the same set-up.
I do not suggest one over the other as long as you use safe towing and hitching practices.
I know of a gentleman that tows a Minuet with nothing more than the ball mount on a 3/4 ton pick-up. He has complained about the fact that he cannot pull the trailer any faster than 55 mph or it sways all over the place. I tell him consantly to let me know when he is pulling and I will stay off the Interstate.
Just wanted to tell you the success story of the Equal-I-Zer.
Anon is offline   Reply With Quote
Old 02-04-2006, 11:33 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Reese Straight vs Equalizer
The simple Reese (without the frictional damper or twin cam) does not have any dampening action except the friction in the ball and trunions. The Equalizer automatically comes with some sway dampening because of the friction where the weight distribution bars rub on the trailer connection points. If you need sway dampening because of relative size difference of trailer to tow vehicle or a shorter wheelbase TV, I would go for the twin cam but the frictional dampener Reese of Equalizer should be equal.
Old 02-04-2006, 01:02 PM   #5
1975 29' Ambassador
Reno , Nevada
Both the DC and the EQ are step up from the friction bar and indications are that they are about equivalent in handling improvement. For a new setup, I think the EQ has the advantage as it is a simpler setup.
What is missing in the equation is the tow vehicle. Sway control devices compensate for tow vehicle and other deficiencies. (best word I can find- not intended to be negative as all rigs have deficiencies). For instance, a long wheelbase half ton or better pickup with short differential to ball distance and a heavy front end doesn't really need either load leveling or sway control. But if you have a vehicle designed for passenger comfort first with a soft suspension and long rear hangover, an HA might be the only way you are going to have comfortable handling.
A longer and heavier trailer will tend to handle better as it takes more to push it around and it has more leverage to control it.
Old 02-04-2006, 01:28 PM   #6
blucloud's Avatar
1987 25' Sovereign
1977 23' Safari
Images: 20
Ahhh hah.... I did forget to mention that the tow vehicle was the same for both units, 04 Burb, 4W/D, 5.3L w/3:70 gears.
Old 02-04-2006, 01:56 PM   #7
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Dual Cam HIGH PERFORMANCE This patented product is Reese Products main technique for controlling trailer sway. Unlike the friction sway control, this approach works to control sway from the start rather than just resisting sway once it’s begun. And it works only when needed.
The advantage of the dual cam system is its ability to forestall sway in addition to sway resistance. It works to hold down the start of swaying activity while at the same time allowing free and easy vehicle and trailer interaction. Another advantage of the dual cam system is that it’s installed on the trailer and therefore doesn’t require adjustment every time the towing vehicle and trailer are hooked up, unless hitch weight or tow vehicle loading are changed.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 02-10-2006, 07:22 PM   #8
Grand Rapids , Michigan
Excuse me, but I'm a newbie here. I just bought a 19" Bambi in Florida and will be towing back to Michigan with 2002 Yukon Denali. I will need to purchase a weight distubution and sway package. What is HA? What would ya'll recommend for me? Should I buy something here in MI, or from the AS dealer when I pick up the little silver bugger?
Double D is offline   Reply With Quote
Old 02-10-2006, 08:01 PM   #9
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
If you were to buy the Reese Dual Cam you will need to drill holes into your trailer A frame to mount the Duel Cam hanger brackets. The Equal-I- zer you do not need to drill holes to mount, The Hensley is the best on the market but also costs big bucks, here is there link to check them out
Old 02-10-2006, 08:28 PM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Equil-i-zer
Both hitches are quality units. I've had the Equal-i-zer now for 3 years andI love it. No worries on the road.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-11-2006, 12:49 AM   #11
HA = Hensley Arrow, about $3K
goldwing70 is offline   Reply With Quote
Old 02-11-2006, 06:32 AM   #12
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Either the Reese Dual Cam or the Equalizer will do you fine for a Bambi 19' behind a Yukon. The HA is a superb hitch, but won't do any better job controlling a trailer of your size and weight than the other two, and it weighs significantly more.
Sway is caused by inappropriate weight loading, tongue weight that is less than 10-15% of the total load weight, low or unbalanced tire pressures, and either warn suspension parts or good ol' design flaws in the suspension on the tow vehicle. Once you eliminate those as causes of sway, your trailer shouldn't, and your sway control hitch will just be an added measure of safety.
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
Old 02-11-2006, 10:35 AM   #13
1975 29' Ambassador
Reno , Nevada
Ghee Whiz. It is beginning to appear that the Reese DC contingent is catching the Hensley Arrow disease ;-)
When the sales hype gets going, so should the rational buyer!
A Burb has a medium wheelbase and medium to long axle to ball distance. Load leveling is nearly always needed. Handling can often be satisfactory with good tires and the other things Roger metions. Most folks find a friction bar sufficient but a DC or EQ often adds a bit of comfort. IMHO and HA is a bit of overkill for a 'Burb but there are those who find security in a big heavy orange blob between them and their trailer!
IMHO, of course, usual caveats apply. Safe driving starts and ends with the nut behind the wheel.
Old 02-11-2006, 03:21 PM   #14
Thanks for the tips. Sounds like the Equal-i-zer is the way to go...
Old 02-11-2006, 03:22 PM   #15
Wow, a tad pricey for me. Thanks for the heads-up!
Old 02-11-2006, 03:25 PM   #16
Roger
Thanks. I appreciate the positive reinforcement. It boosts my confidence in my TV.
Reese friction to Reese Dual Cam ? Kistler Our Community 7 07-01-2003 07:53 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
Reese dual cam problems Kistler Our Community 29 04-01-2003 07:52 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Reese Twin Cam Setup Road Ruler Hitches, Couplers & Balls 5 09-15-2002 12:23 PM
