Emergency Brake Battery Size
We renovated a 74 Argosy trailer. I purchased, new axles, brakes, and a new emergency brake away switch. The switch came with a motorcycle sized battery. Is that ample to pull in my four trailer brakes? How do I test with out having to jack up each wheel, spin the tire, and pull the pin on the brake away switch. And even then there may be enough current to pull in the brakes under a no load situation. What about in the real world stopping of a run away trailer? I have 4 6-volt Lifelines on board. Should I just hook the switch up to those?
