RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-29-2020, 02:11 PM   #1
Aurora
MimiandRandy's Avatar
2019 30' Flying Cloud
Tampa , FL
Drop shank ground clearance—is 6” enough?
We recently replaced our TV with a 2020 F250 TD. We were pulling with an F150 and finally took the plunge. I had to buy an 11” drop shank and adjust it to the second to last hole to level my AS, then had the shop cut off the excess. That still leaves me with just 6” of ground clearance using my Equalizer hitch. I’ve read in other forums that 6” is acceptable, but is the minimum...please relate your experiences and knowledge about this stressful dimension.
Thank you!
2019 Flying Cloud 30RB
2015 Ford F-150 Sport 4x4
2016 Ford Explorer
MimiandRandy is offline   Reply With Quote
Old 11-01-2020, 10:00 AM   #2
2020 27' Globetrotter
Greater Salt Lake City , Utah
Think Twice with only 6" Clearance
Thank you!
Might be too low................thinking of transition points into/out of driveways, fuel stations, parking lots etc.
If you did hit bottom, what we be the consequence of bending the shank? Catastrophic failure and coupler is also damaged ? Inability to remove shank from TB?
Found this from eTrailer's website.
https://www.etrailer.com/question-59772.html
ExploreUT is online now   Reply With Quote
Old 11-01-2020, 10:28 AM   #3
Mollysdad's Avatar
IMO, it's enough.
Mine is about the same, and it almost never hits. My driveway is the exception where, without the trailer, it might go bump at the curb.
It doesn't hurt anything. The safety chains are lower and the jack foot is higher.
I've never hit on speed bumps or gas station transitions.
Old 11-01-2020, 10:47 AM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I have a 2019 F350. I bought a Curt that is described as having a 5" drop when used with trunnion bars and 7" with round bars. I use trunnions. I have one hole left on the bottom. I have never dragged the bottom. I have thought about cutting the unused portion off, though.
CRH is offline   Reply With Quote
Reese 3344 drop shank outdoors717 Hitches, Couplers & Balls 3 04-04-2016 05:31 PM
Equalizer Shank with 3ā€¯ drop/7ā€¯ rise Thorsten S Airstream Classifieds 0 11-25-2015 02:18 PM
Combining 4" drop reciever to Hensley 8" drop shank Rascal0729 Hitches, Couplers & Balls 18 07-20-2015 06:52 AM
Deep drop WD hitch shank ground clearance? mountainboy Hitches, Couplers & Balls 5 07-20-2009 05:56 AM
Need a Weight Dist. Shank with more drop!!! JeepinAudiophile Hitches, Couplers & Balls 11 07-19-2004 01:30 PM
