Old 01-31-2020, 11:57 AM   #1
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Curt BetterWeight system?
I have a New Curt Better weight system and have been impressed so far.
It plugs into your vehicles OBD plug, enter your VIN # and BAM! It does the math from there. This thing has been accurate enough to sense a 30lb propane bottle added to the bed of my GMC 2500HD bed.
https://www.curtmfg.com/betterweigh
Old 01-31-2020, 12:47 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
GMFL, thanks for sharing that about the CURT system. I wasn't aware they developed one. Just watched several of their videos about the product. Will definitely check it out at the local Farm & Fleet retail store. *I've got a $60 credit there so hopefully it's in stock soon.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1500#
WBCCI# 10258
April 3, 2020 Retirement Plan RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-04-2020, 08:57 PM   #3
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here are some photos or the BetterWeigh system in action.
ID:	360544   Click image for larger version
ID:	360546   Click image for larger version
ID:	360548   Click image for larger version
Old 02-04-2020, 09:36 PM   #4
2007 22' International CCD
Ok, now you’re talking facts and measurements. Thanks for taking the time to do so.
Have you been able to check the numbers with a CAT scale, by chance?
Now I gotta figure out how to add one to my system...the forums are costing me boku bucks occasionally...
Old 02-05-2020, 07:10 AM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Numbers match pretty close.
Last time I weighed on the scales tongue weight was right at 980lbs
And Gross weight was 14200, but that was fully loaded and full tanks.
The BetterWeigh just plugs into your OBD plug on your Tow Vehicle.
Enter your VIN in the App and calibrate Level and your good to go.
I don’t think it will replace the scales but it’s a great way to reference your setup.
Old 04-08-2020, 08:01 AM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here is my review on the Better Weight system.
https://www.doityourselfrv.com/betterweigh-system/
Old 04-08-2020, 08:23 AM   #7
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
I'd be interested in something like this as I tow various trailers.
I'm curious about the "Terms Of Service" though. Connecting any app to your phone opens up potential issues depending on the companies TOS.
Too often, we pay to give things away...
Ian
Iansk is offline   Reply With Quote
Old 04-08-2020, 09:50 AM   #8
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Very interesting!
I could not find the list price. Does anyone know?
Old 04-08-2020, 11:19 AM   #9
Iansk's Avatar
1977 31' Sovereign
Originally Posted by Hans627 View Post
Very interesting!
Less than $90 on Amazon. He has a link in his review he links to.
Ian
Old 04-08-2020, 12:07 PM   #10
2018 25' International
Slidell , Louisiana
The Curt system seems to be licensed from HaulGauge, which I own. The application looks identical. I like this product and also find it to be accurate within about 5% and precise enough to detect about 50 lb added or removed.
Brian
Old 04-08-2020, 03:18 PM   #11
2020 Classic 33
Box Elder , South Dakota
Haul Gauge was bought by Curt.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 04-08-2020, 04:53 PM   #12
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Very interesting!
Around $89.00
Old 04-08-2020, 05:55 PM   #13
turk123's Avatar
2019 30' Classic
Canfield , Ohio
That is amazing!
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 04-08-2020, 06:11 PM   #14
Slidell , Louisiana
okay then, that explains it.
Brian
Old 04-09-2020, 09:43 AM   #15
2019 30' International
Florence , Alabama
Standard Transmission Functions Question
I see that all functions will not be available for vehicles with standard transmissions and air suspensions, could some one provide insights to specific loss of functions? I have a manual six speed in my RAM 2500. Thank you 😎
Michael and Anna Fennell
Florence, AL
Michael Anna is offline   Reply With Quote
Old 04-09-2020, 10:35 AM   #16
Slidell , Louisiana
Yes, the way it works, it compares transmission output torque to measure acceleration and with a manual transmission, a torque estimate becomes problematic so calculating vehicle and combined weight is out. Payload, tongue weight and weight distribution use static geometry so that all works. Without weight I wonder if it is worth the $90. I'd say not.
Brian
Old 04-09-2020, 11:00 AM   #17
2020 Classic 33
I have the Haul Gauge. After getting it setup it was pretty accurate. But I to wouldn't buy again. About $30 to make multiple passes at a CAT scale and once you have decided what settings are best on your WD setup then it's likely you aren't going to change anything unless you make a major modification to the trailer/tow vehicle.
Gary
NØVPN
Old 04-09-2020, 03:31 PM   #18
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
I recently purchased the Curt BetterWeight device. Plugs in easily and finds your vehicle by inputting your VIN. Calibration was fairly easy just accelerate at 1/2 throttle from 0 to 15 mph. Problem is keeping the tires from loosing contact and spinning with the 6.7L Cummins. If you don’t do half throttle accelerations you don’t get accurate readings. I haven’t tried with the Airstream hooked up yet due to staying home order. It was able to sense me in the truck bed. Customer support is very good. The bad part, IMHO, is either you use a known weight from the CAT scale for your TV or you have to do the calibration (0 to 15mph) each time and then hook your Airstream up and do it again. Subtract first weight (unhooked TV) from second weight (Airstream plus TV) to find your Airstream weight. It does not store any information from one pull to the next. Kind of a hassle to go through each time. It can be unplugged from the OBD port when not towing as the Bluetooth part does have small current drain if left plugged in all the time. Seems to be very accurate as long as you can get the half throttle acceleration without wheel spin.
JDG is offline   Reply With Quote
Anyone tried the Curt Betterweigh Digital Towing Scale System? brainwash Towing, Tow Vehicles & Hitches 17 04-09-2020 06:53 PM
Curt Mfg. Weight Distributing Hitch Setup COArgosy78 Hitches, Couplers & Balls 20 06-28-2016 07:42 AM
Best receiver: Curt, Drawtite, or Hidden Pacerized Hitches, Couplers & Balls 7 03-21-2011 08:13 PM
Curt Hitch Receiver- Comments Needed Bluto Hitches, Couplers & Balls 17 07-08-2009 04:49 PM
Curt Hitch Silver Threads Hitches, Couplers & Balls 5 01-27-2007 01:04 AM
