Old 09-06-2022, 01:40 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
C&D article - How far can an EV truck tow ?
This article is from the spet/22 issue of car and driver magazine.
it shows that most EV trucks loose between 50-70% of their range when towing a 6K lb trailers.
i wonder how they tow and how much range is lost with an aero dynamic airstream?
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 09-06-2022, 02:38 PM   #2
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
The 50 to 70% loss of range seems about right. Even internal combustion engine vehicles lose a lot of range when towing.
Of course the actual loss will depend on a great many factors besides the aerodynamic shape of the load being towed. Other variables include how much wind there is, the grade of the highway, how much starting and stopping there is, the driving habits of the driver, specifically how quickly they accelerate, coast, or stop, and the ambient temperature, to name a few.
But most reports indicate a loss of at least half for planning purposes. Most modern BEVs include an onboard computer that constantly calculates range remaining and will display the nearest available charging stations, their distance, and how full they are.
skyguyscott is offline   Reply With Quote
Old 09-06-2022, 02:45 PM   #3
jcl
Vancouver , British Columbia
I think 50% range loss is the minimum for a travel trailer, and more depending on travel speed, one's propensity to take advantage of all the available hp, etc.
Can Am modified an AS27 to remove the roof AC to further reduce drag. We may see more options in that regard, perhaps a split AC like Bowlus are using.
We find with our EV that for range, grade doesn't matter much, compared to travel speed, as we come down all the hills we go up.
I think the on board range computers that skyguyscott mentions will get a lot better over the coming year or two. These are first generation EV trucks, and there is much room for improvement. I was impressed with the Lightning's ability to store multiple trailer profiles and customize the towing consumption figures. One problem with road tests such as the one C&D did is that the vehicles they are driving haven't had a chance to learn the trailer details yet, so the range estimates the testers saw are cruder.
jcl is offline   Reply With Quote
Old 09-14-2022, 06:41 PM   #4
Northern , California
According to GM towing is the same for EV’s and ICE, averaging a 25% loss. If you keep your speed reasonable (under 60) that’s generally accurate, it goes to 50% loss if you drive 70 and otherwise aren’t careful. Otherwise there’s nothing special about towing with an EV other than you have more control authority, downhill is a breeze and range might be an issue, unless you have a 400+ mi battery like the Silverado EV.
C&Ds test is what I’d call ‘worst case’ or maybe ‘stupid case’, just be a grandpa driver, why scream down the highway at those speeds in your expensive EV towing an expensive Airstream?
DrivingDan is offline   Reply With Quote
Old 09-14-2022, 07:30 PM   #5
2023 27' Globetrotter
Williamsburg , Virginia
Puhleese! Not another EV thread! They all end poorly.
AgBullet is offline   Reply With Quote
Old 09-15-2022, 08:32 AM   #6
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
While that's true, it won't be the last EV thread.... the future is inevitable, even if you don't like it...
-Leslie
WBCCI #1051
LNBright is offline   Reply With Quote
Old 09-15-2022, 09:49 AM   #7
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Excellent report from CanAm RV on Tesla towing on long trip
See this latest blog from Andy Thompson' s trip through the mountains etc.
https://www.canamrv.ca/blog/post/tes...rado-and-back/
TRIPPPIN is offline   Reply With Quote
Renovation & Rigs so far on 24' Argosy Katty Upholstery, Blinds, Walls & Interior Finishes 2 07-19-2018 01:25 PM
Truck Camper Magazine article about our trip! jornvango On The Road... 3 09-16-2014 03:28 PM
Far, far, away.... Terry C. Tullier Our Community 19 07-26-2005 09:42 PM
How far can you drive in a day? Stefrobrts On The Road... 55 08-06-2004 07:06 PM
Snowbird Migration...Spring Can't be far behind wahoonc On The Road... 0 04-03-2004 06:45 AM
